Use an LED as a snubber diode?
I have some small relays (5v, 500 ohm coil) that will need a snubber diode to prevent inductive flyback. Would like to be able to use a SMD diode for speed of assembly (hot-plate soldering), but I don't have any on hand. But then I realized I do have a ton of cheap Chinese 0608 LEDs on hand. Any problem using those as the snubber diode? I do not have any real specs on the LEDs, only that they work well as LEDs with the normal in-line resistor...
Nate
Nate
I'm guessing these are reed relays? 500 ohms is pretty high for a 5V relay. I like low-current relays as they can be driven directly by a uC pin.
Not sure that they are really rated for high volts in the forward state, not high watts. Not exactly the ideal snubber diode.
http://www.daycounter.com/Calculators/Snubbers/Snubber-Design-Calculator.phtml
Over the years I am sure I have used the wrong diodes - either too slow or not robust enough. But I have never tried an LED.
LEDs have a reverse breakdown spec, if you cannot find it in data, you could measure a couple.
5V is likely ok, but 12V I would avoid.
With a 10mA peak and short duration, forward current is no problem to any LED .
You should be fine.
on the manufacturer's part as I don't believe every colour is the same, but it limits their usefulness
as general purpose diodes.
+1, others are chatting about the same issue.
http://www.eng-tips.com/viewthread.cfm?qid=175789
http://www.edaboard.com/thread300568.html
Interesting that the consensus seems to be... there is no consensus.
I hooked one of the 0603 LEDs up in serial w/ a 470 ohm resistor and then to my bench supply in reverse polarity. Ran the voltage up to 30VDC, no current showing on the ammeter.
Currently have the LED in series w/ 6.8k resistor and 30VAC transformer to see how it will handle that, since I also wanted to use the 0603 LEDs as an indicator for the switched power (which is 30VAC). If there is no change in performance after an overnight I will assume the reverse breakdown voltage is over ~42V.
