SX48BD FUSEX Register
I have the interpreter chip BS2pe mounted on my PCB and was hoping to run it on a 3.3V PSU as the datasheet states between 3V to 5V, when running at the bottom end of this range to chip goes into an apparent reset mode and communication is halted until the supply voltage goes above 4.2V, is it possible to modify the FUSEX brownout detector value within the Parallax SX48BD to make it 2.6 Volt instead of 4.2 Volt..i.e through a software command within p-BASIC? as i suspect that it set for 4.2V as default perhaps?
---Dave
---Dave
Correction: The SX-based BASIC Stamps that have been rated for Industrial Temperature ranges have had their firmware changed so as NOT to use the internal brownout detector and instead use a brownout detector external to the interpreter chip.
The BS2pe, however, is not one that has had this change made. The BS2pe still has the fuses set for 4.2-volt brownout detection using the SX's "interpreter's" internal brownout detector.
As was mentioned, we did make a special version of the BS2pe interpreter for 3.3 volt use, but we do not stock those parts and only make them upon special-order request. If you'd like to order those, please contact me ( jmartin@parallax.com ) or our sales department directly to arrange for production and sale of these special-order parts. Sorry, I do not know the stock code.
NOTE: You'll have to ensure that the other components on the board (EEPROM especially) is compatible with that voltage. They often are these days and I "believe" the one we use is compatible, but I haven't confirmed that.
Yes, all the BS2pe Interpreters we stock and use on our BS2pe-IC modules have the option set for internal brownout at 4.2 v.
Sorry, we don't have any distributors that provide that service. The only way to get them would be for us to provide them from our Rocklin, CA headquarters.
It may be possible for us to reprogram them on your board, but there's chances that won't work depending on our circuit. If you like, we can talk about it to see what is possible and decide how to proceed from there.
