Help: MS5607 Altimeter using SPI, C Code, and Propeller Activity Board
I am trying to get the MS5607 Altimeter to work using the SPI Mode in C code on the Propeller Activity Board. A picture of the setup and the current (messy) iteration of the code are attached. I also attached the datasheet (it is not currently available on the Parallax website), and a screenshot of the output. I am pulling in numbers from the PROM and ADC, but they do not appear to be reasonable. The math for the conversion is probably also off, because I was not sure of the best way to implement the exponentials, so I used the pow() function from math.h after testing its basic functionality and ability to give reasonable integer results for basic calculations. At the very least, the SENS variable calculation is wrong, but I am not sure where the problem is happening and it is hard to believe the D1 and D2 numbers being read from the sensor. I would appreciate any help in identifying what I may be doing wrong. I am including a stripped-down version of my code in text form below. I am using Simple IDE and the associated libraries for all my coding. I started with the SPI tutorial for the Accelerometer module and used that as the basic template for this project. The code below does not include any loops or writing to the SD card yet because I wanted to get data that made sense first before adding on those layers... the loops and SD card writing are commented out in the attached code.
#include "simpletools.h" // Include simpletools lib
const int SDI=3; // Chip SDI/SDA pin
const int SDO=1; // Chip SDO pin
const int SCL=5; // Chip CLK pin
const int CS=0; // Chip CS pin
const int PS=8; // Chip PS pin
const int pt=500; // Pause time between data points
const int RESET = 0x1E; // Reset command
const int ADCread = 0x00; // ADC Read command
const int PROMreadC1 = 0xA2; // Prompt read PROM C1
const int PROMreadC2 = 0xA4; // Prompt read PROM C2
const int PROMreadC3 = 0xA6; // Prompt read PROM C3
const int PROMreadC4 = 0xA8; // Prompt read PROM C4
const int PROMreadC5 = 0xAA; // Prompt read PROM C5
const int PROMreadC6 = 0xAC; // Prompt read PROM C6
const int ConvertD1 = 0x48; // Convert D1 for ADC read (OSR=4096)
const int ConvertD2 = 0x58; // Convert D2 for ADC read (OSR=4096)
unsigned int Cread(int READ); //Function prototype
/* Initialize calculation values */
unsigned long int D1, D2;
signed long int dT, TEMP, P;
signed long long int OFF, SENS;
unsigned int c1, c2, c3, c4, c5, c6;
int main() // Main function
low(PS); // Select SPI Protocol
high(CS); // CS high (inactive)
low(CS);
shift_out(SDI, SCL, MSBFIRST, 8, RESET); // Reset to ensure coeff loaded into PROM
high(CS);
pause(500);
c1 = Cread(PROMreadC1); //Reads c1 value
c2 = Cread(PROMreadC2); //Reads c2 value
c3 = Cread(PROMreadC3); //Reads c3 value
c4 = Cread(PROMreadC4); //Reads c4 value
c5 = Cread(PROMreadC5); //Reads c5 value
c6 = Cread(PROMreadC6); //Reads c6 value
print("%cc1 = %d, c2 = %d, c3 = %d \n", HOME, c1, c2, c3);
print("c4 = %d, c5 = %d, c6 = %d\n", c4, c5, c6);
/* Read digital pressure and temperature value */
low(CS); // CS low selects chip
shift_out(SDI, SCL, MSBFIRST, 8, ConvertD1); // Prompt D1 ADC conversion
high(CS);
pause(100);
low(CS);
shift_out(SDI, SCL, MSBFIRST, 8, ADCread); // Prompt D1 ADC read
D1 = shift_in(SDO, SCL, MSBPOST, 24); // Read D1 value
high(CS);
low(CS);
shift_out(SDI, SCL, MSBFIRST, 8, ConvertD2); // Prompt D2 ADC conversion
high(CS);
pause(100);
low(CS);
D2 = shift_in(SDO, SCL, MSBPOST, 24); // Read D2 value
high(CS); // De-select chip
print("D1=%d, D2=%d\n", D1, D2);
/* Calculate temperature */
dT=D2-(c5*pow(2,8)); // Difference between actual and ref temp
TEMP=2000+((dT*c6)/pow(2,23)); // Actual Temperature
print("dT = %d, TEMP = %d\n", dT, TEMP);
/* Calculate temperature-compensated pressure */
OFF=(c2*pow(2,17))+((c4*dT)/pow(2,6));
SENS=c1*pow(2,16)+(c3*dT)/pow(2,7);
P=(D1*SENS/pow(2,21)-OFF)/pow(2,15);
print("OFF=%d, SENS=%d, P=%d\n", OFF, SENS, P);
unsigned int C;
low(CS);
shift_out(SDI, SCL, MSBFIRST, 8, READ); // Prompt Coeff PROM read
C = shift_in(SDO, SCL, MSBPOST, 16); // Read coeff value
high(CS);
return C;
Personal notes: I am pretty new to this community, only having been working on this for the last couple weeks. The purpose of this project is to make sensors available for students for launching high altitude balloons. I don't necessarily need the altitude calculations to work because I could have the students do that as part of the post-processing, but ideally, I would like to do the altitude calculations on-board so the students could compare them to post-processing. So far, I have successfully implemented the 3-axis gyroscope (L3G4200D) and 3-axis accelerometer (MMA7455) sensor modules.
Board not yet assembled
unsigned short int Cread(int READ) { unsigned short int C; low(CS); shift_out(SDI, SCL, MSBFIRST, 8, READ); // Prompt Coeff PROM read high(CS); low(CS); C = shift_in(SDO, SCL, MSBPRE, 16); // Read coeff value high(CS); return C; }
