Auto gain control AGC amplifier for 40 kHz ultrasonic transducer — Parallax Forums
bienlebienle Posts: 2
edited 2014-05-16 10:32 in Accessories
Hi, I need an Auto Gain Control amplifier for my 40 kHz ultrasonic transducer, but I couldn't find any.
Does any body know such an IC device ? Part number of the IC and name of the company would be helpful.
Thank you
    edited 2014-05-15 11:13
    Google TVG amplifier. TVG stands for "time varying gain." An example would be the AD600 series.
  • macrobeakmacrobeak Posts: 355
    edited 2014-05-15 16:53
    Does anyone have a working circuit detailing the use of the TVG amplifier with an ultrasonic sensor?
  • bienlebienle Posts: 2
    edited 2014-05-16 02:32
    Thanks Phil.
    I already search on google, but the problem is there is no AGC/TVC amplifier which has the appropriate frequency for my case 40kHz. Most of them are operating at frequency of MHz
    The amp I referenced is spec'd for ultrasonic apps. If an amp operates in the MHz range, it will work at lower frequencies, unless it's AC-coupled internally.
