About the Color Pal camera and distance sensing — Parallax Forums
whiteoxewhiteoxe Posts: 794
edited 2014-05-15 09:06 in General Discussion
I need to go the cheapest way but i am still curious as to the differences. The Color Pal is a cheap camera about ohh..$14 and it can pick up colours, so could that sensor be used to pick up on a red snooker ball or does it have to be larger like a red t-shirt ?
The two distance sensors as far as i can see are IR and the ulta sonic. I imagine by the price the ultrasonic might do a better job of sensing distance. The IR distance sensor talked about triangulation but this docent mean i need more than one for front and one for back ? The IR is much less pricy .
Now the Wide Angle PIR Sensor....... it senses motion but from what i gathered only motion from something warm, a pet or a person. It would not detect motion from say a robot or a ping pong ball ? ?
    edited 2014-05-15 06:58
    whiteoxe wrote: »
    The ColorPAL is not really a camera, but a color sensor. It can pick up ambient light, but is made to used in very close proximity to an object to determine it's color. It's only on sale today for 12.99 US. It's normally $19.99 US
    The PING has a larger range than the IR detector. It's range is 1" to 10' (2 cm to 3 m). The Sharp IR sensor only has a range of 3.9" to 31.5" (10 cm to 80 cm).
    The PING is easier to use as it is a digital output easily read by a BS2. The IR has an Analog output.
  • whiteoxewhiteoxe Posts: 794
    Thanks again, i know what ill get, i have a BS2 REV d HOMEWORK BOARD i had already ordered geared motors and wheels and motor controllers and foam board from ebay to make a second robot, some parts have arrived. but if i get the Scribbler fixed i might power the seond robot with a prop board i got from gadget gangster,!!!!
