Multiple objects for HM5883L Magnetometer
Hugh
I have tied myself in a knot.
I have been trying to use the Parallax code for the HM5883 Demo as the basis for trying to read two magnetometers simultaneously. By changing the pin numbers to reflect the hardware I can use the standard code to read data from either magnetometer attached to the prop - getting it to read two seems to have caused me to come unstuck.
The code has been pruned back to what I think is the minimum and a file 'TopObj.spin" written to start the two instances of the HM5883L object (passing the two pin numbers) and receive the x, y and z components from the magnetometers. These (six values) are then sent to the Serial terminal. The only values received are all '0'.
The attachment is the code as it currently is - trying to get a single magnetometer to working using this approach.
Any ideas welcome. I've spent the whole day working in VB.net so may be 'code blind'!
TopObj - Archive [Date 2014.05.12 Time 18.23].zip
The HM5883L isn't set up to be used as a child object.
I haven't tested the attached code, but I'm hoping it will allow you to access the values from the child object.
Let me know if it doesn't work and I'll test it out myself.
I was just looking from some HM588L code I previously wrote (this was before seeing this thread). Once I find it, I'll clean it up and post it. My version uses F32 to compute heading.
At the moment I am only trying to get one object / magnetometer started (to start with), then will expand the approach to two. The only difference (I hope) will be the pin numbers passed to each object.
Hugh
The top object uses this value to find the data after the raw data is read.
PUB GetData (xa, ya, za) setpointer(OUTPUT_X_MSB) getraw xa := x ya := y za := zI'm guessing you really want the follwoing?
PUB GetData (xa, ya, za) setpointer(OUTPUT_X_MSB) getraw x1 := x y1 := y z1 := zBut then there are no getters in HMC5883L_Demo to pass the value back to the top level object.
Edit: Are you trying to use pointers?
I thought I was lacking in some understanding why this piece of code existed:
After translating several C programs, it looks like some artifact caused by the difference between C and Spin. The above code does nothing useful.
I think the Arduino code used as a guide used pointers. The demo is Parallax's code not Hugh's.
I have a better version. I'll find it and post it.
Thanks Duane - that works brilliantly... ...but... the serial terminal is now showing three 'sensible' values and on the next row three larger values, three sensible values, three odd values, etc., , i.e.,
"-71,37,-642-18435,9727,32256"
I'm not sure whether this is happening as a result of different results on alternate calls.
I expanded your code to two magnetometers (below) and, with the exception of the good data / bad data rows, it works brilliantly! :thumb:
PUB Main | x1, y1, z1, x2, y2, z2 address[0] := mag[0].startMag(17, 16) address[1] := mag[1].startMag(13, 14) waitcnt(clkfreq/100_000 + cnt) 'Wait while compass has time to startup. term.start(31, 30, 0, 9600) 'start a terminal Object (rxpin, txpin, mode, baud rate) repeat mag[0].GetRaw longmove(@x1, address[0], 3) mag[1].GetRaw longmove(@x2, address[1], 3) term.dec(x1) term.tx(44) term.dec(y1) term.tx(44) term.dec(z1) term.tx(44) term.dec(x2) term.tx(44) term.dec(y2) term.tx(44) term.dec(z2) term.tx(13)(Output now:
-641,-71,40,-529,-142,66
32512,-17923,10495,-4864,28925,18431)
The TopObj code is mine. Yes, it is rough - I've started getting splinters from it...!
I cut the Parallax code down because I couldn't fully understand it.
In the code they all have trailing commas, expect the final number that has a <CR>.)
I found my HM5883L object. I'm trying to add enough comments so it can be used by others. I'll be posting it later today.
My version includes the heading averaged over several readings (even if the reading is near the rollover). It also includes a "field angle from horizontal" value.
I uploaded my version here.
It's pretty complicated in order to overcome the rollover issue when averaging readings. I'll likely make a pared down version with just the basics sometime soon.
Edit: I also added a simplified version of the code.
As I was trying to round out my HMC5883L code to allow the various registers on the sensor to be set, I found one of the setting was for the gain.
The default gain is set to 0.92 milli-Gauss per unit but it can be increased to 0.73 mG/unit.
This gain setting also allows the sensitivity to be decreased (down to 4.35 mG/unit).
There are a couple of other settings you may find useful. The default sample rate is 7.5Hz but this can be adjust down to 0.75Hz or increased up to 75Hz.
The sensor can average multiple readings internally. The default averages (if the the word even applies) a single reading but this can be increased to averaging 8 samples (all the averaging numbers are powers of 2 (1, 2, 4 & 8).
I think the demo program adequately shows how these various settings can be accessed. Hopefully these features will be useful to you.
The latest version is available in post #2 of the thread I linked to in my previous post (#15). I still intend to add a few more methods to the object before submitting it to the OBEX but I think the object is usable as it is now.
Wow! That is something I need to play with. Excellent work - thank you! ;-)
