Help with program flow in large BS2 program — Parallax Forums
RockoRocko Posts: 8
edited 2014-05-14 09:23 in BASIC Stamp
Hello everyone,
I need help with writing the program flow for a large BS2 program for my Boe-Bot.
A little background on this project:
I've been involved in a robotics competition at my robotics club for over 6 months now.
The competition (called, "The Challenge") involves using a robot (I am using a Boe-Bot) to:
1) Locate a 1-1/2" sq. block of wood on a tabletop
(I am using an SRF04 ultrasonic sensor and the code from a program called, "PingDar_GoToClosetObject.bs2".
Note: Although the "PingDar_GoToClosetObject.bs2" program uses a Parallax PingDar, I have successfully modified and run this program using a generic SRF04.
I have also modified this program so that the "PingDar" code, if you will, only goes through finding the edges & aligning itself to the block only 1 time, then it should move forward indefinitely or until:
2) It detects block. (I am using a Parallax QTI line sensor as a switch to stop the Boe-Bot at this point.)
3) gripper closes around block
4) Boe-Bot makes an About Face (turns 180* or around)
5) Boe-Bot moves forward until:
6) Parallax ColorPal detects a 3" dia. red circle on tabletop & stops
7) Boe-Bot backs up ~4" so block is on top of red circle
As the program stands now, it will successfully go through the process of locating the block and heading toward it. It then continues to move forward even though the QTI sensor has been tripped. (I know that the sensor is being tripped because I've run a DEBUG program to watch it switch on screen from 1 (no block detected) to 0 (block detected)
Here is the code:
' -----[ Title ]--------------------------------------------------------------
' PARTS_Challenge.bs2
' {$STAMP BS2}                     ' Target device = BASIC Stamp 2
' {$PBASIC 2.5}                    ' Language = PBASIC 2.5
' -----[ I/O Definitions ]----------------------------------------------------
' ColorPal pin
ColorPal       PIN     15
' Ping))) Ultrasonc Rangefinder and Mounting Bracket
PingServo      PIN     14          ' Servo that directs Ping))) snsr
Ping           PIN     1           ' Ping))) sensor signal pin
' Boe-Bot servo pins (Left and right are from driver's seat perspective.)
BotServoLeft   PIN     13          ' Left drive servo
BotServoRight  PIN     12          ' Right drive servo
' Gripper servo pins
GrprServo      PIN     11          ' directs gripper servo motor
' QTI Line Sensor pins
FQTIPwr        PIN     6           ' front QTI sensor power
FQTIIn         PIN     3           ' front QTI sensor input
StartLED       PIN     0           ' display start delay
' -----[ Constants ]----------------------------------------------------------
' Baud rate for ColorPal
baud           CON     119 + 32768
' Ping))) mounting bracket constants
LimitLeft      CON     1200                   ' Bracket 90-degrees Left
LimitRight     CON     275                    ' Bracket 90-degrees Right
Limits         CON     LimitLeft + limitRight ' this added from FORUM
Center         CON     750                    ' Center/0-degree pulse duration
Increment      CON     15                     ' Increment for pulse sweeping
MinSweep       CON     40                     ' Pulses -> 90-degree right
' Boe-Bot continuous rotation servo control constants
FwdLeftFast    CON     850                    ' Fast settings - straight ahead
FwdRightFast   CON     660
RotateRight    CON     765                    ' Boe-Bot rotate right pulse
RotateLeft     CON     735                    ' Boe-Bot rotate left pulse
'Gripper servo constants
Open           CON     800                    ' gripper open position
Closed         CON     1200                   ' gripper closed position
BtwnPulses     CON     20                     ' ms between servo pulses
' Ping))) Ultrasonic Rangefinder constants
CmConstant     CON     2260                   ' Echo time -> cm with **
SinCosTo256    CON     517                    ' For */ -127..127 -> -256..256
Ms20           CON     330                    ' 20 ms worth of cm
' MSB sign (twos complement)
Negative       CON     1                      ' Negative sign (bit-15)
Positive       CON     0                      ' Positive sign (bit-15)
' Ping and turning axis geometry
PingDirToAngle CON     8454                   ' Servo pulse to angle ** con
PingAxleOffset CON     7                      ' 7 cm between ping))) and axis
' -----[ Variables ]----------------------------------------------------------
time           VAR     Word                  ' Ping))) echo time
pingDir        VAR     Word                  ' Pulse duration -> direction
pingRev        VAR     Word                  ' Pulse duration -> direction for reversed servo
                                             ' added from FORUM
x              VAR     Word                  ' x coordinate
y              VAR     Word                  ' y coordinate
distance       VAR     Time                  ' Object centimeter distance
markDir        VAR     y                     ' Pulse points to closest object
rightMark      VAR     x                     ' Pulse to object's right side
leftMark       VAR     pingDir               ' Pulse to object's left side
pulses         VAR     x                     ' +/- brads to turn toward object
PrevDist       VAR     Byte                  ' Previous distance measurement
angle          VAR     Byte                  ' Servo angle from right in brads
counter        VAR     angle                 ' Loop counter
minDist        VAR     angle                 ' Minimum distance measurement
sweepInc       VAR     Nib                   ' Increment for servo sweep
sweepDir       VAR     Bit                   ' Increment/decrement pingDir
xSign          VAR     Bit                   ' Stores sign of x variable
ySign          VAR     xSign                 ' Stores sign of x variable
pSign          VAR     Bit                   ' Sign of pulses variable
edgesFound     VAR     Bit                   ' Navigation flag
QTIRaw         VAR     Word                  ' front QTI sensor raw reading
QTIDig         VAR     Bit                   ' decoded sensor value
QTIBit         VAR     Bit
temp           VAR     Byte
pulseCount     VAR     Byte                  ' Used for measuring turns
red            VAR     Word                  ' Received RGB values from ColorPAL.
grn            VAR     Word
blu            VAR     Word
' -----[ EEPROM Data ]-------------------------------------------
RunStatus    DATA       $00    ' run status
' -----[ Initialization ]-----------------------------------------------------------------------
Reset:
  READ RunStatus, temp         ' read current status
  temp = ~temp                 ' invert status
  WRITE RunStatus, temp        ' save for next reset
  IF (temp > 0) THEN END       ' run now?
Start_Delay:
  HIGH StartLED                ' show active
  PAUSE 5000                   ' start delay
  LOW StartLED                 ' LED off
' PAUSE 2000                    ' Removed (Delay program start by 2 s.)
' PULSOUT PingServo, pingDir   ' FORUM said remove & replace with next 2 lines
  pingRev = Limits - pingDir
  PULSOUT PingServo, pingRev
' -----[ Main Routine ]-------------------------------------------------------------------------
' This first part of this program is from Smart Sensors and Applications - GoToClosestObject.bs2
' Sweep Ping))) Ultrasonic Rangefinder across 180-degrees and find the closest object.
' Then calculate and execute the turn required to face the object.
' Travel forward until the object is less than or equal to 5 cm from the front of the rangefinder.
' Note: This program has been modified to use a generic SRF04 ultra sonic sensor and travel forward
' until a QTI line Sensor is tripped.
GOSUB Get_Ping_Cm                            ' First distance measurement
'DO UNTIL distance <= 5                      ' Removed from GoToClosestObject.bs2 (Repeat until distance <= 5 cm)
DO
  edgesFound = 0                             ' Clear edges found flag
  DO UNTIL edgesFound = 1                    ' Repeat until edges found = 1
    GOSUB Face_Closest_Object                ' Find & face closest object
  LOOP
  GOSUB Get_Ping_Cm                          ' Get current distance
  'DO UNTIL distance <= 5                    ' Removed from GoToClosestObject.bs2 (Drive toward object)
  DO
    prevDist = distance MAX 255              ' Current distance -> previous
    GOSUB Get_Ping_Cm                        ' Get new distance
    PULSOUT BotServoLeft, FwdLeftFast        ' Boe-Bot forward
    PULSOUT BotServoRight, FwdRightFast
    PAUSE BtwnPulses - (distance / Ms20)     ' 20 ms pause between pulses
    'IF distance >= prevDist + 5 THEN EXIT   ' Removed from GoToClosestObject.bs2 (Exit if distance increasing)
  LOOP
LOOP
GOSUB Read_QTI_Sensor                        ' Read QTI sensor value
  DO UNTIL QTIDig = 0
  LOOP
  DO
    GOSUB Hold_Position                      ' Hold position
  LOOP
  DO
    GOSUB Close_Gripper                      ' Close Gripper
  LOOP
  DO
  GOSUB Turn_Around                          ' About 180 degree Turn Around to the Right
  LOOP
  DO
  GOSUB Keep_Straight                        ' Keep Straight
  LOOP
  DO
  GOSUB Reset_ColorPal                       ' ColorPal
  LOOP
  DO
  GOSUB color_check                          ' ColorPal
  LOOP
  DO
    IF (red <= 124) AND (grn >= 100) AND (blu >= 125) THEN      ' Current tabletop color values here
      GOSUB Keep_Straight
    ELSEIF (red > 125) AND (grn < 50) AND (blu < 50) THEN       ' Red Circle values
      GOSUB Hold_Position
    ENDIF
  LOOP
  DO
    GOSUB Back_Up
  LOOP
END
' -----[ Subroutines - BoeBot_Turn_Brads ]-----------------------------------
' Boe-Bot turns a certain number of binary radians to face an object.
BoeBot_Turn_Brads:
  IF pSign = Positive THEN
    FOR counter = 0 TO ABS(pulses)
      PULSOUT BotServoLeft, RotateRight
      PULSOUT BotServoRight, RotateRight
    NEXT
  ELSE
      PULSOUT BotServoLeft, RotateLeft
      PULSOUT BotServoRight, RotateLeft
    NEXT
  ENDIF
  RETURN
' -----[ Subroutines - Face_Closest_Object ]----------------------------------
' Scan for closest object using a Ping))) rangefinder mounted on a standard
' servo.  Locate the middle fo the object, and turn Boe-Bot to face it.
Face_Closest_Object:
  ' Initialize sweep increment.
  sweepInc = Increment
  ' Start Servo rotated to the far right.
  pingDir = LimitRight
  GOSUB Point_At_PingDir
  ' Make minDist large and sweepDir positive (0).  Single_Sweep sweeps
  ' left -> right while measuring object distances and stores the direction
  ' of the closest object in markDir.
  minDist = 65535
  sweepDir = Positive
  GOSUB Single_Sweep
  ' Point the servo in the direction of the closest distance measurement.
  pingDir = markDir
  ' Scan to find object's right side.
  GOSUB Find_Right_Side
  IF edgesFound = 0 THEN RETURN
  pingDir = markDir
  GOSUB Find_Left_Side
  ' Average the angles to the object's left and right sides.  That's the
  ' middle of the object.  Point rangefinder in that direction.
  pingDir = leftMark + rightMark / 2
  ' At this point, the Ping))) should be pointing directly at the closest
  ' object.
  ' Calculate the angle to the object's angle in brads, and turn the
  ' Boe-Bot to face that angle.
  GOSUB Turn_Angle_Adjust
  GOSUB BoeBot_Turn_Brads
  ' Face Ping))) rangefinder straight ahead.
  pingDir = Center
  RETURN
' -----[ Subroutines - Find_Left_Side ]---------------------------------------
' Scan left until the measured distance is 10 cm beyond the closest distance,
' which is assumed to mean the object's side has been found.
' If the object's side has been found within the 180-degree field of vision,
' set edgesFound = 1 and store the pulse duration (pingDir) at which the
' object was found in the leftMark variable.
' If the side was not found by the 180-degree point in the scan, rotate the
' Boe-Bot until the edge is found, and then set edgesFound to 0 signifying
' that the scan will have to be repeated because the Boe-Bot rotated
' to find the side, which would otherwise cause the markDir variable to
' store an incorrect value.
Find_Left_Side:
  sweepDir = Positive
  distance = minDist
  sweepInc = 1
  DO UNTIL distance > minDist + 10
    GOSUB Sweep_Increment
    GOSUB Get_Ping_Cm
    IF pingDir >= LimitLeft - 10 THEN
      pingDir = LimitLeft - 50
        GOSUB Get_Ping_Cm
        PAUSE 20
      LOOP
      edgesFound = 0
      RETURN
    ENDIF
  LOOP
  leftMark = pingDir
  edgesFound = 1
  RETURN
' -----[ Subroutines - Find_Right_Side ]--------------------------------------
' Mirror image of Find_Left_Side.
Find_Right_Side:
  sweepDir  = Negative
  distance = minDist
  sweepInc = 1
    GOSUB Get_Ping_Cm
    IF pingDir <= LimitRight + 10 THEN
      pingDir = LimitRight + 50
        GOSUB Get_Ping_Cm
        PAUSE 20
      LOOP
      edgesFound = 0
      RETURN
    ENDIF
  LOOP
  rightMark = pingDir
  edgesFound = 1
  RETURN
' -----[ Subroutine - Get_Ping_Cm ]-------------------------------------------
' Gets Ping))) rangefinder measurement and converts time to centimeters.
' Distance may be declared as time to save variable space.
Get_Ping_Cm:
  PULSOUT Ping, 5
  PULSIN Ping, 1, time
  distance = time ** CmConstant
  RETURN
' -----[ Subroutine - Read_QTI_Sensor ]-------------------------------------------
' Activates and reads QTI sensor
Read_QTI_Sensor:
  HIGH FQTIPwr                               ' activate QTI sensor
  HIGH FQTIIn                                ' discharge caps
  PAUSE 1
  RCTIME FQTIIn, 1, QTIRaw                   ' read QTI sensor
  LOW FQTIPwr                                ' deactivate QTI sensor
  LOOKDOWN QTIRaw, >=[1000, 0], QTIDig       ' convert reading to bit
  RETURN
' -----[ Subroutines - Point_At_PingDir ]-------------------------------------
' Points servo mounted Ping))) rangefinder at an angle determined by the
' value of the pingDir variable.
Point_At_PingDir:
  FOR counter = 0 TO MinSweep
    PAUSE BtwnPulses
  NEXT
  RETURN
' -----[ Subroutine - Polar_To_Cartesian ]------------------------------------
' Calculates x and y (Cartesian coordinates) given distance and angle
' (polar coordinates).
Polar_To_Cartesian:
  ' Calculate left/right component.
  x = COS angle                              ' Polar to Cartesian
  xSign = x.BIT15                            ' Store sign bit
  x = ABS(x) */ SinCOsTo256                  ' Polar to Cartesian continued
  x = distance */ x
  IF xSign = negative THEN x = -x            ' Correct sign with sign bit
  ' Calculate straight ahead component.
  y = SIN angle                              ' Polar to Cartesian
  ySign = y.BIT15                            ' Store sign bit
  y = ABS(y) */ SinCOsTo256                  ' Polar to Cartesian continued
  y = distance */ y
  IF ySign = negative THEN y = -y            ' Correct sign with sign bit
  RETURN
' -----[ Subroutines - Single_Sweep ]-----------------------------------------
' Do one sweep, and find the closest distance measurement and the
' pulse value that points the servo in that direction.
Single_Sweep:
  DO UNTIL pingDir >= LimitLeft
    GOSUB Get_Ping_Cm
    IF distance < minDist THEN
      minDist = distance
      markDir = pingDir
    ENDIF
  LOOP
  RETURN
' -----[ Subroutine - Sweep_Increment ]---------------------------------------
' Increment/decrement the position of the servo that directs the Ping)))
' rangefinder. When pingDir goes outside either LimitRight or LimitLeft,
' the sweep direction toggles.
Sweep_Increment:
  ' Change sweepDir for adding/subtracting increment if at rotation limit.
  IF pingDir <= LimitRight THEN
    sweepDir = Positive
  ELSEIF pingDir >= LimitLeft THEN
    sweepDir = Negative
  ENDIF
  ' Add/subtract increment to/from pingDir.
  IF sweepDir = negative THEN
    pingDir = pingDir - sweepInc
  ELSEIF sweepDir = Positive THEN
    pingDir = pingDir + sweepInc
  ENDIF
  ' Send positioning pulse to Ping))) Mounting Bracket servo.
  ' PULSOUT PingServo, pingDir     ' This line of code removed & replaced by next 2 lines
  RETURN
' -----[ Subroutines - Turn_Angle_Adjust ]------------------------------------
' Adjusts required turn angle based on 7 mm offset of Ping))) rangefinder from
' Boe-Bot's turning axis.
Turn_Angle_Adjust:
  ' Get the object's distance at its center.
  GOSUB Get_Ping_Cm
  ' Position servo & calculate angle from far-right in brads.
  angle = pingDir - 250 ** PingDirToAngle
  GOSUB Polar_To_Cartesian
  ' Add distance between Ping))) and center of Boe-Bot axis.
  y = y + PingAxleOffset
  ' Recalculate the turning angle with respect to Boe-Bot's turning axis.
  angle = x ATN y
  pulses = 64 - angle
  pSign = pulses.BIT15
  RETURN
' -----[ Subroutines - Hold_Position ]------------------------------------
  Hold_Position:
  FOR pulseCount = 0 TO 5
    PULSOUT BotServoLeft, 750
    PULSOUT BotServoRight, 750
    PAUSE 20
  NEXT
  RETURN
' -----[ Subroutines - Close_Gripper ]------------------------------------
  Close_Gripper:
    PULSOUT GrprServo, Closed      ' Close signal -> Gripper servo
    PAUSE BtwnPulses               ' 20 ms delay between pulses
  NEXT
  RETURN
' -----[ Subroutines - Turn_Around ]------------------------------------
  Turn_Around:                     'About 180 degree Turn Around to the Right
  FOR pulseCount = 0 TO 170
    PULSOUT BotServoLeft, 850
    PULSOUT BotServoRight, 850
    PAUSE 20
  NEXT
  RETURN
' -----[ Subroutines - Keep_Straight ]------------------------------------
  Keep_Straight:
  FOR pulseCount = 0 TO 20
    PULSOUT BotServoLeft, 850      ' Left Servo Forward Pulse Value
    PULSOUT BotServoRight, 650     ' Right Servo Forward Pulse Value
    PAUSE 20
  NEXT
  RETURN
' -----[ Subroutines - Back_Up ]------------------------------------
  Back_Up:
  FOR pulseCount = 0 TO 10       ' Number Of Pulses To Backup
    PULSOUT BotServoLeft, 650    ' Left Servo Backup Pulse Value
    PULSOUT BotServoRight, 850   ' Right Servo Backup Pulse Value
    PAUSE 20                     ' Refresh Delay
  NEXT
  RETURN
' -----[ Subroutines for ColorPal ]---------------------------------------------
  Reset_ColorPal:
  LOW ColorPal                   'Pull sio low to eliminate any residual charge.
  INPUT ColorPal                 'Return pin to input.
  DO UNTIL ColorPal : LOOP       'Wait for pin to be pulled high by ColorPAL.
  LOW ColorPal                   'Pull pin low.
  PAUSE 80                       'Keep low for 80ms to enter Direct mode.
  PAUSE 10                       'Pause another 10ms
  RETURN
  color_check:
  SEROUT ColorPal, baud, ["= m !"]
  SERIN ColorPal, baud, [HEX3 red, HEX3 grn, HEX3 blu] ' Receive RGB data back.
  RETURN
    edited 2014-05-13 16:15
    It's been over a day since you posted this and no replies. I suspect that's because you've posted a huge hunk of code, a lot of not so well organized information, and no questions really. I think you'll do better if you can formulate some very specific questions, either focusing on particular sections of code or outlining organizational questions.
  • RockoRocko Posts: 8
    edited 2014-05-13 22:16
    Thanks for replying, Mike.
    I'll try to be more specific.
    Why doesn't the Boe-Bot Hold_Position when it sees the block ?
    As I stated earlier, the first part of the code works correctly; the Boe-Bot identifies the wooden block and heads towards it.
    As I understand it, the way these programs work is that they go down through the program line by line, so the next thing it should do is go into the subroutine that reads the value of the QTI sensor (GOSUB Read_QTI_Sensor).
    Upon returning from that subroutine, let's say the value is 1 (hasn't seen the block yet), the next thing the program does is go into the first DO LOOP, looping UNTIL the value is 0 (QTI sensor has seen block). When the value is 1, it exits that loop, and goes into the next loop in line which is Hold_Position.
    Again, why doesn't the Boe-Bot Hold_Position when it sees the block ?
    Thanks for any further help on this!
    edited 2014-05-14 07:36
    Just glancing at your code, in Main Routine, your nested DO / LOOPs won't exit. In fact, you've got a lot of DO / LOOPs that are never executed and won't exit ever if started. Your program never gets to the call to Hold_Position.
    DO / LOOP means "loop forever" unless an EXIT (or GOTO) is executed.
    +1 to Mike's comment. Every DO loop needs an UNTIL or IF/THEN to exit when a condition is met and advance to the next part of the program.
