Very Simple Uart Debug
Sometimes you just want to keep a tab on a hub variable, to debug pasm make your cog wrlong to this hub location.
Once started it will keep resending the status of this variable forever, you never have to tell your spin code to send it each time.
If you want burst of data due to some pin state etc then add this at the end:
test _mypin,ina wz
if_z add cnt,_second 'restart main loop with 1sec delay
if_nz add cnt,#500 'restart main loop nearly right away
Save this to you PropTool library folder as: debug_uart
Here is an example how to use it, just add two lines to your code you want to debug
Under OBJ> debug : "debug_uart"
In Main> debug.start(@symbol)
test _mypin,ina wz
{ Sends a 8 character HEX of a HUB Address value, at a fixed interval } PUB start(address) cognew (@entry,address) DAT org 0 entry mov DIRA,_bit30 mov cnt,#7 '7 cycle overhead add cnt,cnt 'add current cnt loop1 waitcnt cnt,#100 'wait and then add 100 for below overhead rdlong temp,PAR mov charcnt,#9 '8 chars in a long + space loop2 rol temp,#4 'visually send msb hex first mov uartTx,temp and uartTx,#%1111 'get nibble add uartTx,#48 'start at ASCII for "0" cmp uartTx,#58 wc 'over letter 9? if_nc add uartTx,#7 'if so add for letters A-F cmp charcnt,#1 wz 'last char? if_z mov uartTX,#32 'replace with space or uartTx,#$100 'set stopbit shl uartTx,#1 'merge in startbit mov bitcnt,#10 '10bit uart loop3 waitcnt cnt,_baud shr UartTx,#1 wc muxc OUTA,_bit30 djnz bitcnt,#loop3 djnz charcnt,#loop2 add cnt,_second 'restart main loop with 1sec delay jmp #loop1 _second long 80_000_000 '/2 or /4 if you want shorter delay _baud long 80_000_000/115200 _bit30 long |<30 temp res 1 charcnt res 1 bitcnt res 1 uartTx res 1
{Demo for debug_uart} CON _clkmode = xtal1 + pll16x 'Standard clock mode * crystal frequency = 80 MHz _xinfreq = 5_000_000 VAR long symbol OBJ debug : "debug_uart" PUB main debug.start(@symbol) ' start it by pointing to long hub variable repeat symbol +=1 ' forever loop that increase a variable
Save this to you PropTool library folder as: debug_uart_dec
