3D Printer - Have Any Experience Using A 0.125 Inch DIA. Core Bore For 3MM Filament?
idbruce
Hello Everyone
Please excuse another thread for 3D printing, but this thread pertains to a very specific question.
I am designing an extruder for a 3D printer, which will use 3MM filament. 3MM is the nominal diameter of the filament and the actual diameter of the filament is 2.85MM. To simplify this discussion, 2.85MM equates to 0.112IN, which is the actual imperial measurement of our filament.
To put it all in a nutshell, this thread pertains to the bore of the core, but more particularly the minimum and maximum bore diameter, for 3MM filament.
As we all know, or at least a fair portion of us, drilling deep accurate holes is not an easy task. To be perfectly honest, this is the machining task that I hate the most, because it oftens results in failure. However the fact remains that I need a deep hole for the 3MM filament to pass through. As applied to the imperial conversion completed above, I have several common options available, which are:
Does anyone have any experience with the optimized bore diameters for 3D printer extruders?
EDIT: I now see that several extruder barrels utilize a 3.2MM (0.126" rounded) bore. However this size bore still seems excessive.
- #33 Drill bit 0.113" (0.113" hole - 0.112" filament diameter = 0.001" clearance) (way too tight for my liking)
- #32 Drill bit 0.116" (0.116" hole - 0.112" filament diameter = 0.004" clearance) (seems perfect to me, but maybe too tight)
- 3MM Drill bit 0.118" (0.118" hole - 0.112" filament diameter = 0.006" clearance) (seems perfect to me, but maybe too tight)
- #31 Drill bit 0.120" (0.120" hole - 0.112" filament diameter = 0.008" clearance) (seems a little loose to me, but I could be wrong)
- 1/8" Drill bit 0.125" (0.125" hole - 0.112" filament diameter = 0.013" clearance) (seems extremely loose to me, but again, I could be wrong)
Materials change in diameter as you heat them.
It's quite possible that the 0.113 clearance measured on a cold piece of
plastic might quite possibly be needed to push it through the tube when
the plastic is heated above about 175 degrees F.
In a past life, I've had lots of trouble with not allowing enough clearance
when running warm materials through a not large enough orifice.
Just my 2 cents worth.
I follow your 3d printer related threads each day.
Garyg
Having said that, I think you want the bore, at least the portion that conducts heat, to be a short as possible. The original MakerBot sort of solved this by using a PET(?) tube. Now they just use as short of bore as possible. If the filament spends too much time in the bore it will soften, expand, increase the amount of force required to feed it, strip more easily and possibly jam.
Unless you are dead set on 3mm, I would recommend switching to 1.75mm. It takes less force to feed and spends less time in the bore.
@ Rich - In all likelihood, my design of the core and heatsink are probably inefficient, but as mentioned elsewhere, I like the concept and theory, so I at least want to try it. If necessary, I may add a thermal barrier of PEEK. As far as going all plastic, I don't want to go that route, because they have problems also.
I agree 100%, however with the current design, I am going for a centered 3MM filament, with the hope that the required offset for 1.75MM will not be too great for the extruder to overcome. Luckily I have plenty of material on hand to make various design changes. I was originally shooting for a 1.75MM filament and then later opted for the 3MM, but in reality, I want to be able to use both.
The important thing with deep holes is to keep clearing the flutes on the drill bit - otherwise
it jams, friction rises dramatically, bit heats up and expands, siezes and snaps. Aluminium
is bad for this IMO. Don't even think about doing this without a good drill press and vice.
So peck-drill, withdraw frequently to clear flutes (a pointy tool of some sort is needed, and
use oil liberally. Choose an alloy with good machinability (not pure Al, a hard alloy will
cut better).
Definitely drill slightly undersize then the final drill will have no problems and cut cleanly
with no danger of jamming.
I will have to remember that.... I think Walt was talking about something similar for his project, but he did not say it the same way, or go in depth.
Lights cigar, lifts eyebrows, then deadpans to audience
