_xinfreq = 5_000_000 and 6_250_000 clock speed
Hello
I have a question on the xinfreq parm,
_clkmode = xtal1 + pll16x
_xinfreq = 5_000_000 'Set to standard clock mode and frequency (80 MHz)
I purchased the 6.250 crystal, so the statement looks like this
_xinfreq = 6_250_000 'Set to standard clock mode and frequency (100 MHz)
and replaced the crystal on the demo board,
then I wrote some assembler to test it, my scope results showed 12.5 ns as the min (toggling a pin)
1/80,000,000 = 0.0000000125
but when I replaced the crystal with 6.25 Mhz I expected 10 ns but I received the 12.5 again
1/100,000,000 = 0.000000010
but in reading it seems that 80Mhz is the limit, regardless, and above 6.25 mhz things get slightly unstable.
my assembler was simply
time = cnt
time + delta
:loop
xor pin ' toggle pin
waitcnt(time,delta) ' the lowest delta I could get was 4, below that there was no toggle
jmp #:loop
anyway, I was just curious, I would like 100Mhz, it I can get it.
regards
Jeff
time = cnt
time + delta
:loop
jmp #:loop
regards
Jeff
the minimum loop would be
mov dira,#1 ' enable P0 for output
loop xor outa,#1
jmp #loop
which would take 8 clock cycles
scope should show 5Mhz square wave with 5mhz xtal, and 6.25mhz with 6.25mhz crystal
5Mhz would give you 200ns, by using the x16 multipler you get much faster, but what I was getting at is that yes, there are 8 cycles, but the cycles are faster, therefore the switch is faster and the toggle should happen faster. but since I am not getting what it think I got it wrong.
regards
Jeff
Make sure and use code tags when posting code.
[noparse] [/noparse]
will show up as:
I moved over to the super carrier board, works correctly
thanks
Jeff
I'm confused. How did switching to a board for the Basic Stamp fix your Propeller issue?
regards
jeff
That explains things. Just a mix up on the name.
Thanks.
