Do GPS modules work inside
Because my Nav Man needs to be outside or in the car ? I think im having an epiphany... no., just kidding, that's a word i hate because i hear it everyday and it starter about 7 years ago here in oz. If all the people on the tv could just look it up once they would not use it every day
however, you might find that you can get it to work in a particular building. sometimes. maybe. on certain days.
In a car, the GPS is seeing out through the front windscreen, not through the roof which is usually metal.
One could get multiple satellite locks while ten feet from the closest closed window in a few seconds and the other had to be outside and stationary for about ten minutes before it could establish a lock.
The units that work inside, it that due to the antenna being more sensative? Can we mod the anttenna on a cheap one to get better performance?
The most sensitive GPS I have used are uBlox and whatever is in a G1000 panel mount.
IMHO - The largest factor is where you are in relation to the GPS satellites. This is entirely disregarding environmental factors, as well as antenna issues. If you have GLONASS you'll have more sats available. Even still those satellites need to be revived in order to be effective.
The Bad Elf is a popular GPS rx, I'll show you what it looks like inside. This is nothing but a fix, you cannot use it to navigate "inside", so again it depends on specifics. If you just want a fix within a few meters, sure there are lots of GPS that work inside. If you want to navigate around a parking garage then the answer is GPS wasn't designed that way.
First you need to evaluate where the GPS sats are in the sky, and what you're receiving
Sometimes, depending on lots of factors you'll pull a good signal inside while you're stationary. That doesn't mean you'd get a good update if you moved. GPS positioning depends on lots of external factors, but most importantly your current fix is an average. Raw GPS data is near incomprehensible, it takes a lot of work to provide a fix. Sometimes this work degrades accuracy, especially when you don't have a clear view of the sky.
Here's the Bad Elf/GLONASS GPS deep within my compound, about as far as I can get it from a window. 4m of accuracy does me no good compared to what I'd get outside.
Everything is a factor when it comes to RF data that relies on timing. Sometimes things work well, other times, not so well. Essentially GPS was not made for anything less than a clear view of the entire sky.
You can mod for multipath, there's nothing you can do about weather other than evaluate the availability of what you're receiving.
Unfortunately there's an exception. We used to have a Pontiac Montana minivan. The radio antenna was a layer inside the entire windscreen.
On the bright side, radio reception was excellent. On the downside, the GPS couldn't get a read through it. I had to use an external antenna.
All of that changed with the newer chipsets. The old TomTom GPS used a Sirf Star II chipset, the newer Sirf Star III chipset is a completely different world. And the MTK chipset which is used in a tiny bluetooth receiver that I now use with the TomTom navigator. Works inside all cars, has no problems with the living room window, and even works inside most of the office building except when I get deep inside.
No problems in cities either.
I don't know what chipset is used inside my Asus Transformer T700T, but that one also seems to work inside many buildings.
-Tor
