I want to build an Amp Probe
Has anyone built an AC Amp Probe. I need to measure current 0 - 50 amps of AC. I also want to measure AC volts but I can figure that out. The main issue is that I need a small current coil that I can operate about 3M away from the Stamp. I would like to only use "1 wire".
Greg
Greg
I am looking for some sort of 1 wire sub-assembly.
I would like to use RCTime for the measurement.
Does anyone know of a clamp-on or pass through module that converts AC Current to 0-5 DC volts so it can directly be read by RCTIME.
Greg
http://www.digikey.com/product-detail/en/CR9580-20/582-1034-ND/1045190
Looks like it would be perfect.
THANKS
