External IP locking port 80 Tachyon web server - can you help?
Peter Jakacki
I've been using my Tachyon servers for months, making constant little improvements and everything has been working well, but today I have a problem with port 80. It's not a problem with the web server software itself as the web ports work fine but it's only when I connect to the WAN that it locks up on port 80, but only just today. Wireshark wasn't picking anything suspicious up although that is probably the switch's doing but I did interact with the server and stopped the process so I could issue commands directly to the WIZnet chip.
The IP is originating from Montreal but even though I've blocked that address in the router it is still playing up, time to bridge the interfaces so Wireshark can take a look. Destination port is 80 which is odd.
Here's a capture from my Tachyon console while I access a page successfully on port 81.
Any ideas?
Any ideas?
[FONT=courier new]************ W5200 STATUS ************ LINK *UP* CHIP VER 0003[/FONT] [FONT=courier new]SRC IP 192.168.016.150. MASK 255.255.255.000. GATEWAY 192.168.016.001. MAC 02.FF.62.F3.95.AE. *** SOCKETS *** #0 13:44:24 MODE= CLSD PORT# TXRW= . .RXRW= . .RXSZ= .IR=00 ST=00 CLOSED #1 13:44:24 MODE= TCP PORT# 21 TXRW= . .RXRW= . .RXSZ= .IR=00 ST=14 LISTEN #2 13:44:24 MODE= CLSD PORT# TXRW= . .RXRW= . .RXSZ= .IR=00 ST=00 CLOSED #3 13:44:24 MODE= TCP PORT#10001 TXRW= . .RXRW= . .RXSZ= .IR=00 ST=14 LISTEN #4 13:44:24 MODE= TCP PORT# 80 80 TXRW=7ACF. .RXRW= . .RXSZ= .IR=00 ST=16 SYNRECV 069.165.095.246. #5 13:44:24 MODE= TCP PORT# 81 34084 TXRW= 888. 888.RXRW= . 133.RXSZ= 133.IR=05 ST=17 ESTABLISHED 192.168.016.019. #6 13:44:24 MODE= TCP PORT# 82 TXRW= . .RXRW= . .RXSZ= .IR=00 ST=14 LISTEN #7 13:44:24 MODE= TCP PORT# 83 TXRW= . .RXRW= . .RXSZ= .IR=00 ST=14 LISTEN [/FONT]
why? It is the most obvious port, isn't it?
I just see a SYNCRECV. What is the actual request?
more input
