UART API Question
DavidZemon
I've designed a configurable UART module in C++ (the language doesn't matter for this question though) and have now run into a question with no right answer. One of the configurable options is data width which can be anywhere from 1-16 bits with my current code - typical UART values are 5-9 bits and I want to keep at least that much flexibility. I use a 16-bit variable for data, which is no problem when you're just sending a single data word. However, I am now about to add functionality to send an array of data words, at which point data type size matters a lot. Of course, the most common data width is 8-bits - the width of a char (character). To allow the user to (easily) send a string, the function must accept an array of 8-bit variables NOT 16-bit variables. But that means the method will not work for all data widths allowed by the module. The choices that I can come up with are:
Also - shameless plug - this module is part of PropWare, linked to in my signature. At the time of writing it is only in the release-2.0-nightly branch.
David
- Create a single method such as send_array(uint8_t *array) and document that this method will not work for data-widths greater than 8-bits. Provide no alternative to users requiring more than 8-bits
- Create two methods such as send_array(uint8_t *array) and send_wide_array(uint16_t *array). Highly functional but... a little "smelly" to me
- Create a single method send_array(uint16_t *array) and provide no good alternative for users that want to send out a string of text
David
I've just recently been working on a Modbus project and even though Modbus uses 16-bit registers, the data is sent byte by byte. Is there a device other than a Propeller running your 16-bit data code that will be able to take advantage of these extra bits?
Just yesterday with the help of Tracy Allen I modified his serial driver to use even parity. I think adding the ability to use parity would be something useful for your driver but I'm not sure when a 16-bit driver would ever be used?
It actually already does odd, even, or no parity, any number of stop bits, and any baud up to 122,000. I want to get the max baud up higher but haven't yet looked at where the bottleneck is. I think it's on the receive side (so a receive_array() function would probably help).
I'm not sure how useful a 16-bit communication line would be. Often the limiting factor with serial communication on the Propeller is how fast the Propeller can move the bytes around internally. The actually sending of bits isn't the bottleneck. Still, I can see how it could be useful if you had a lot of 16-bit data to send and receive.
I take it from your comments (Mike and Duane) then, you are in favor of a single function send_array(uint8_t *array)? (i think this question is actually rhetorical lol)
Eric is right. The standard is 8 bits. In the past there were protocols that used anywhere from 5 to 8 and occasionally 9 data bits, but that is rare if it exists at all. One of the reasons a 16 bit protocol is not used is the synchronization problem. The start and stop bits guarantee that there will be no more than 8 (or is it 9?) bit times between a transition for the receiver to synchronize on. With 16 bit data the number of bit times between transitions could be twice as long. This is not usually a problem within a board or module but for long transmission distances it may lead to a lot of errors. Better to split the word into 2 byte transmissions.
