Silicone Tube Dampers? C'mon...
While searching for vintage (jukebox amplifier) vacuum tubes on Ebay, I saw these silicone O-ring dampers to put around vacuum tubes. Wha...?
http://www.ebay.com/itm/2pcs-19mm-Tube-Dampers-Silicone-O-Ring-Fit-12AX7-12AU7-12AT7-EL84-Audio-Vaccum-/251504675369?pt=Vintage_Electronics_R2&hash=item3a8ed8ca29
And here are the big boys: http://www.ebay.com/itm/Tube-Damper-Pair-2-9-Pin-Miniature-fit-12AX7-6DJ8-/380149870736?pt=Vintage_Electronics_R2&hash=item5882b2b090
Keeps tubes cooler? Damps microphonics? Gimme a break. Anyone ever hear of these? Are these fodder for the tube freaks?
http://www.harmonycentral.com/forum/forum/guitar/acapella-29/1715837-
http://dynacotubeaudio.forumotion.com/t774-tube-dampers-are-they-for-real
And D-getters versus halo getters: http://en.wikipedia.org/wiki/Getter
http://www.diyaudio.com/forums/tubes-valves/86068-why-d-getters.html
Where does the madness end?
One interesting factoid about this 1954 jukebox is that the amplifier always has all the tube filaments preheated to 1.8 volts so that they heat up rapidly to 6 and 12V when someone makes a selection. Also avoids thermal shock to a cold tube, so the tubes have longer life.
You should hear how much better YouTube and Hulu sound with high quality cabling! These guys have Monster beat I think.....
These auidiofools are an embarrassment to tube lovers everywhere.
Turns out it's not just the HiFi (Whatever happened to that term) fanatics who are suckered:
http://news.sciencemag.org/brain-behavior/2014/04/elite-violinists-fail-distinguish-legendary-violins-modern-fiddles
Cables are something where people seem to go off the deep end the worst. They will pay thousands of dollars for interconnects, power cables, and speaker wire. It's insane.
I like the pretty wooden blocks to raise your speaker cables above the carpet so that static electricity (or something) doesn't pollute the signal.
http://www.audioadvisor.com/Cardas-Multi-Blocks/productinfo/CRMCB/
On the other hand, even though wildly over priced, something like the RCA jack caps actually may have some benefit.
http://www.audioadvisor.com/Cardas-Signature-RCA-Caps-Package-of-12/productinfo/CRRCASS/
