Sumobot: Navigate using Infrared whilst detecting light soure (HELP)
I would like to ask for you help on coding my sumobot for Infrared navigation (avoid obstacles) whilst searching for light source. I am using Infrared sensor to avoid objects and light dependent resistor for detecting light source. I have created a code for each of the task but i am having trouble putting them together to become one code.
AVOID OBSTACLE:
[ I/O Definitions ]
IrLedLF PIN 4 ' Left IR LED connected to P4
IrSenseLF PIN 11 ' Left IR detector to P11
IrLedRF PIN 15 ' Right IR LED connected to P15
IrSenseRF PIN 14 ' Right IR detector to P14
[ Variables ]
irLF VAR Bit ' State of Left Front IR
irRF VAR Bit ' State of Right Front IR
frequency VAR Word ' Stores Frequencies
[ Initialization ]
DEBUG CLS, "FRONT IR DETECTORS", CR, ' Display heading
"Frequency Left Right", CR,
", CR
[ Main Routine ]
DO
FOR frequency = 0 TO 42000 STEP 75
FREQOUT IrLedLF, 1, frequency ' Left IRLED shines IR light
irLF = ~IrSenseLF ' Save IR receiver output
FREQOUT IrLedRF, 1, frequency ' Repeat for right IRLED/receiver
irRF = ~IrSenseRF
IF irLF = 0 AND irRF = 0 THEN
pulseLeft = 825
pulseRight = 650
PULSOUT 13,pulseLeft ' Apply the pulse.
PULSOUT 12,pulseRight
ELSEIF irLF = 1 THEN
pulseLeft = 850
ELSEIF irRF = 1 THEN
pulseRight = 650
ENDIF
PAUSE 10 ' Delay for slower PCs
NEXT
LOOP
Light search:(this code is not mine, i got this from boebot book)
[ Variables ]
' Declare variables for storing measured RC times of the
' left & right photoresistors.
timeLeft VAR Word
timeRight VAR Word
average VAR Word
difference VAR Word
[ Initialization ]
FREQOUT 4, 2000, 3000
[ Main Routine ]
DO
GOSUB Test_Photoresistors
GOSUB Average_And_Difference
GOSUB Navigate
LOOP
[ Subroutine - Test_Photoresistors ]
Test_Photoresistors:
HIGH 6 ' Left RC time Measurement.
PAUSE 3
RCTIME 6,1,timeLeft
HIGH 3 ' Right RC time measurement.
PAUSE 3
RCTIME 3,1,timeRight
RETURN
[ Subroutine - Average_And_Difference ]
Average_And_Difference:
average = timeRight + timeLeft / 2
difference = average / 6
RETURN
[ Subroutine - Navigate ]
Navigate:
' Shadow significantly stronger on left detector, turn right.
IF (timeLeft > timeRight + difference) THEN
PULSOUT 13, 850
PULSOUT 12, 850
' Shadow significantly stronger on right detector, turn left.
ELSEIF (timeRight > timeLeft + difference) THEN
PULSOUT 13, 650
PULSOUT 12, 650
' Shadows in same neighborhood of intensity on both detectors.
ELSE
PULSOUT 13, 850
PULSOUT 12, 650
ENDIF
PAUSE 10
RETURN
AVOID OBSTACLE:
[ I/O Definitions ]
[ Variables ]
[ Initialization ]
", CR
[ Main Routine ]
DO
irRF = ~IrSenseRF
pulseLeft = 825
pulseRight = 650
pulseLeft = 850
pulseRight = 650
ENDIF
NEXT
LOOP
[ Variables ]
timeLeft VAR Word
timeRight VAR Word
average VAR Word
difference VAR Word
[ Initialization ]
[ Main Routine ]
DO
GOSUB Navigate
LOOP
PAUSE 3
RCTIME 6,1,timeLeft
PAUSE 3
RETURN
RETURN
Navigate:
PULSOUT 13, 850
PULSOUT 12, 850
PULSOUT 13, 650
PULSOUT 12, 650
ELSE
PULSOUT 13, 850
PULSOUT 12, 650
ENDIF
PAUSE 10
RETURN
