SRI Micro Robots. The smallest, fastest, robots you have ever seen! — Parallax Forums
Heater.Heater. Posts: 21,230
edited 2014-04-25 03:22 in General Discussion
Here is an amazing video of micro robots from SRI doing construction work:
http://www.youtube.com/watch?v=uL6e3co4Qqc
I've never seen anything like it before.
  • TCTC Posts: 1,019
    edited 2014-04-25 02:48
    That is impressive, thanks for sharing.
    edited 2014-04-25 03:15
    That is amazing! Thanks Heater.
  • ErNaErNa Posts: 1,853
    I just wound a wire in serpentines to a protoboard, place a sheet of paper on it. Then I have some small supermagnets and with the help of a 5A power supply I could move the magnets! To do it better you need 2 separate phases, cross them in X and Y and, here you go. A perfect application for a multi-core processor! And, if you do energize the tracks all separately or in groups it should be possible to save energy and run a few of them.
    You could use the flex connections for parallel interfaces e.g. LCD-screens to make the wires. They are flexible, thin and rock solid.
