Help needed with difficult Boe-Bot project — Parallax Forums
dynamic_castdynamic_cast Posts: 2
edited 2014-04-22 17:54 in General Discussion
Hello all,
I have a project where I need my robot to navigate to a maze, navigate through the maze and acquire and dispose bombs (lights) at a disposal site. Referring to the picture, I would start in front of one maze and must cross the middle area, which will be covered white with random black tape, to get to my enemy's maze and then navigate that maze. Upon exiting the maze, I must then pick up a bomb and get to the disposal site. There is one disposal site on each side of the middle area denoted by a rectangular area of black tape. The long piece of tape on the sides of each maze lead straight down to the disposal site. There are 3 bombs that need to be disposed of. I am using IR LEDs and photoresistors.
I am stuck on how to develop a good piece of code to do this project as accurate as possible. Please help me and thanks in advance for any help given.
1024 x 768 - 71K
    edited 2014-04-22 17:45
    First work on navigating the maze. You will need prioritized rules for how to proceed when you reach a junction. For example the rules could be:
    1 - go straight ahead if the line continues ahead.
    2 - go left if there is a line to the left.
    3 - go right if there is a line to the right.
    4 - look for the bomb if the line stops.
  • dynamic_castdynamic_cast Posts: 2
    I'm focusing on maze navigation at this point like you said. This is the code I had come up with but then I realized I overlooked getting back into the maze after disposing of a bomb.
    ' __BoeBotProject.bs2
    ' {$STAMP BS2}
    ' {$PBASIC 2.5}
    DEBUG "Program Running!"
    ' ----- [ Variables ] ------------------------------------------------------------------
    PIN_SPEAKER             VAR Nib
    PIN_LEFT_WHEEL          VAR Nib
    PIN_RIGHT_WHEEL         VAR Nib
    PIN_LED_LEFT            VAR Nib
    PIN_LED_RIGHT           VAR Nib
    PIN_LED_CENTER          VAR Nib
    STATUS_MAZE_END         VAR Bit
    STATUS_LED_LEFT         VAR Bit
    STATUS_LED_CENTER       VAR Bit
    STATUS_LED_RIGHT        VAR Bit
    STATUS_BOMB_ACQUIRED    VAR Bit
    SPEAKER_FREQUENCY       VAR Byte
    SPEAKER_DURATION        VAR Byte
    PULSE_COUNT             VAR Byte
    SLOW_SPEED_LEFT_WHEEL   VAR Byte
    SLOW_SPEED_RIGHT_WHEEL  VAR Byte
    FULL_SPEED_LEFT_WHEEL   VAR Byte
    FULL_SPEED_RIGHT_WHEEL  VAR Byte
    ' ----- [ Initialization ] -------------------------------------------------------------
    PIN_SPEAKER = 4
    PIN_LEFT_WHEEL = 13
    PIN_RIGHT_WHEEL = 12
    PIN_LED_LEFT =
    PIN_LED_RIGHT =
    PIN_LED_CENTER =
    STATUS_MAZE = 0
    STATUS_BOMB_ACQUIRED = 0
    SPEAKER_DURATION = 1000
    SPEAKER_FREQUENCY = 3000
    SLOW_SPEED_LEFT_WHEEL = 730
    SLOW_SPEED_RIGHT_WHEEL = 770
    FULL_SPEED_LEFT_WHEEL = 650
    FULL_SPEED_RIGHT_WHEEL = 850
    FREQOUT PIN_SPEAKER, SPEAKER_DURATION, SPEAKER_FREQUENCY
    ' ----- [ Main Routine ] ---------------------------------------------------------------
    ' Go straight to the entrance of the maze
    FOR PULSE_COUNT = 1 TO 122
        PULSOUT PIN_LEFT_WHEEL, FULL_SPEED_LEFT_WHEEL
        PULSOUT PIN_RIGHT_WHEEL, FULL_SPEED_RIGHT_WHEEL
        PAUSE 20
    NEXT
    ' Navigation
    DO
        GOSUB GetLedStatus
        GOSUB MakeDecision
    LOOP
    ' ----- [ Subroutine: GetLedStatus ] ---------------------------------------------------
    ' Get the status of the LEDs.
    GetLedStatus:
    RETURN
    ' ----- [ Subroutine: MakeDecision ] ---------------------------------------------------
    ' Make decisions based on LED status.
    MakeDecision:
      IF (STATUS_LED_LEFT = 1) AND (STATUS_LED_CENTER = 0) AND (STATUS_LED_RIGHT = 0) THEN
          ' Basic left turn.
          GOSUB Turn_Left
      ELSEIF (STATUS_LED_LEFT = 0) AND (STATUS_LED_CENTER = 0) AND (STATUS_LED_RIGHT = 1) THEN
          ' Basic right turn.
          GOSUB Turn_Right
      ELSEIF (STATUS_LED_LEFT = 0) AND (STATUS_LED_CENTER = 0) AND (STATUS_LED_RIGHT = 0) THEN
          ' Dead end
          GOSUB Turn_Back
      ELSEIF (STATUS_LED_LEFT = 1) AND (STATUS_LED_CENTER = 1) AND (STATUS_LED_RIGHT = 0) THEN
          ' Choose left over straight.
          GOSUB Turn_Left
      ELSEIF (STATUS_LED_LEFT = 1) AND (STATUS_LED_CENTER = 0) AND (STATUS_LED_RIGHT = 1) THEN
          ' Choose right over left.
          GOSUB Turn_Right
      ELSE
          GOSUB Foward
      ENDIF
      GOSUB CheckMaze
      IF (STATUS_MAZE_END = 1) THEN
          GOSUB AcquireBomb
          GOSUB DisposeBomb
      ENDIF
    RETURN
    ' ----- [ Subroutine: Foward ] ---------------------------------------------------------
    ' Go foward slowly.
    Foward:
      FOR PULSE_COUNT = 1 TO 41
          PULSOUT PIN_LEFT_WHEEL, SLOW_SPEED_LEFT_WHEEL
          PULSOUT PIN_RIGHT_WHEEL, SLOW_SPEED_RIGHT_WHEEL
          PAUSE 20
      NEXT
    RETURN
    ' ----- [ Subroutine: Right ] ----------------------------------------------------------
    ' Turn right slowly.
    Turn_Right:
          PULSOUT PIN_LEFT_WHEEL, SLOW_SPEED_RIGHT_WHEEL
          PAUSE 20
      NEXT
    RETURN
    ' ----- [ Subroutine: Left ] -----------------------------------------------------------
    ' Turn left slowly.
    Turn_Left:
          PULSOUT PIN_RIGHT_WHEEL, SLOW_SPEED_LEFT_WHEEL
          PAUSE 20
      NEXT
    RETURN
    ' ----- [ Subroutine: Back ] -----------------------------------------------------------
    'Reverse and turn right.
    Turn_Back:
          PAUSE 20
      NEXT
      GOSUB Turn_Right
    RETURN
    ' ----- [ Subroutine: CheckMaze ] ------------------------------------------------------
    ' Look for light to signal end of maze.
    CheckMaze:
      IF THEN
          ' Signal end of maze.
          STATUS_MAZE_END = 1
      ENDIF
    RETURN
    ' ----- [ Subroutine: AcquireBomb ] ----------------------------------------------------
    ' After detecting light, get the bomb.
    AcquireBomb:
      IF THEN
          ' Bomb acquired.
          STATUS_BOMB_ACQUIRED = 1
      ENDIF
    RETURN
    ' ----- [ Subroutine: DisposeBomb ] ----------------------------------------------------
    ' Navigate to bomb disposal site.
    DisposeBomb:
      ' No longer have a bomb.
      ' No longer in the maze.
      STATUS_MAZE_END = 0
    RETURN
