BS Homework Board USB - Power Supply Voltage Range?
Hi. What is the voltage range that I can use to replace the 9 volt battery with a power supply? The reason I ask is that I have 12 volt dc outputs (via a relay), and it would be handy if I could use the same source to eliminate the battery that feeds the board. Thanks for your help. Joe
