Multitasking with P1+
As the current planned design does not include hardware multitasking, and the instruction set differs somewhat from P1, I figured I'd start this thread to discuss possible multitasking approaches (and maybe move some of that discussion out of the current P1+ thread). No, I do not want to argue about how a software approach is inferior to a hardware approach, or how this will be too slow to be useful, or introduce too much jitter, and so on. I think our time would be better spent coming up with constructive and useful ideas.
To get things started, here's how I imagine a simple, round-robin approach would work:
From here, I'm wondering if there's an effective way to use ALTDS in conjunction with JMPSW to uncouple the tasks from one another. Also, even those this is a contrived example, it would be nice to combine the JMPSW and JMP into a single instruction, though I don't see how.
mov taddr1, #task1 mov taddr2, #task2 mov taddr3, #task3 task0 xor outa, #1 jmpsw taddr0, taddr1 wc wz jmp #task0 task1 xor outa, #2 jmpsw taddr1, taddr2 wc wz jmp #task1 task2 xor outa, #4 jmpsw taddr2, taddr3 wc wz jmp #task2 task3 xor outa, #8 jmpsw taddr3, taddr0 wc wz jmp #task3 taddr0 res 1 taddr1 res 1 taddr2 res 1 taddr3 res 1
To clarify, it seems to me that JMPs are a natural place to perform context switches. Since the JMPSW is also a JMP, it would be nice to use JMPSW to JMP to something other than PC+1.
With this, each task only needs to know about its own taddrX, which reduces the coupling a bit.
He's got cooperative multitasking on the P1 going very nicely. It very simple, and very fast. Low overhead is the key.
I'm not familiar with propforth. I'm curious how the P1+ changes will affect that. And if there are any performance improvements to be gained.
The forth cooperative multitasker allows each task to run until it hits a "slow" operation. There are typically an I/O operation, or a the end of a loop, etc.
The idea is that the processor(s) can do something else while waiting for the I/O to complete.
Each task is in a queue, and after it completes a single pass, it is placed back in the queue.
Usually each task appears to have the full resources at its disposal.
In the case of propforth, the cogs are treated as a pool. The next cog in the pool is assigned the next task in the queue. Otherwise, the method is pretty much the same as traditional forth.
The affect is that when a slow task is encountered, it does not slow bog down the entire system. The slow task is processed, and the system capacity is only reduced by 1/#cogs. So if we have 8 cogs, an uncooperative task slows us down by 1/8th.
On a 16 cog parts, we would only be slowed 1/16th, which would have a very low impact.
Look for "Forth multitasker" if you are interested, its pretty neat. They've refined this for decades, it pretty good. And there's no reason you could do the same scheme in any environment
