Problems with TestLeftFrequencySweep.bs2 -- Getting errors with the DO...LOOP command
Hey, everyone. I recently started Chapter 8 in the Boe-Bot activities guide, and I had some problems with TestLeftFrequencySweep.bs2 (below). Whenever I run it, it'll highlight the LOOP and tell me it expected a variable, label, or NEXT. But when I change it to NEXT, it highlights the DO and says I have a DO without a LOOP... Any suggestions/fixes I can make to the script?
[ Title ]
' Robotics with the Boe-Bot - TestLeftFrequencySweep.bs2
' Test IR detector distance responses to frequency sweep.
' {$STAMP BS2}
' {$PBASIC 2.5}
[ Variables ]
freqSelect VAR Nib
irFrequency VAR Word
irDetect VAR Bit
distance VAR Nib
[ Initialization ]
DEBUG CLS,
" OBJECT", CR,
"FREQUENCY DETECTED", CR,
[ Main Routine ]
DO
distance = 0
FOR freqSelect = 0 TO 4
LOOKUP freqSelect, [37500,38250,39500,40500,41500], irFrequency
FREQOUT 8,1, irDetect
irDetect = IN9
distance = distance + irDetect
DEBUG CRSRXY, 4, (freqSelect +3), DEC5 irFrequency
DEBUG CRSRXY, 11, freqSelect + 3
IF (irDetect = 0) THEN DEBUG "Yes" ELSE DEBUG "No "
PAUSE 100
DEBUG CR,
", CR,
"Zone ", DEC1 distance
LOOP
Thanks for anything you guys can find that I missed. Any help would be appreciated.
[ Title ]
' {$STAMP BS2}
' {$PBASIC 2.5}
[ Variables ]
freqSelect VAR Nib
irDetect VAR Bit
distance VAR Nib
[ Initialization ]
DEBUG CLS,
" OBJECT", CR,
[ Main Routine ]
DO
distance = 0
irDetect = IN9
PAUSE 100
DEBUG CR,
", CR,
LOOP
Your missing a "NEXT" command above the the "LOOP". It's in the text. You must have missed it while typing.
