Audio recording
Hi!
I'm trying to record data to WAV from the mic, that is connected to MCP3202. The function for MCP3202 driver that takes a sample has the following view:
The main recording loop looks us follows:
Another function reads the buffer and writes the data to the SD card with required WAV header. The file is playable but too noisy. I can here just some fragments. Where can be the problem?
Thanks.
mov value, #0 andn outa, cs_mask ' begin communication or outa, di_mask ' start bit or outa, ck_mask andn outa, ck_mask or outa, di_mask ' single ended mode or outa, ck_mask andn outa, ck_mask andn outa, di_mask ' channel 0 or outa, ck_mask andn outa, ck_mask andn outa, di_mask ' MSB only format or outa, ck_mask andn outa, ck_mask or outa, ck_mask ' read 13 bits test do_mask, ina wc rcl value, #1 andn outa, ck_mask or outa, ck_mask test do_mask, ina wc rcl value, #1 andn outa, ck_mask or outa, ck_mask test do_mask, ina wc rcl value, #1 andn outa, ck_mask or outa, ck_mask test do_mask, ina wc rcl value, #1 andn outa, ck_mask or outa, ck_mask test do_mask, ina wc rcl value, #1 andn outa, ck_mask or outa, ck_mask test do_mask, ina wc rcl value, #1 andn outa, ck_mask or outa, ck_mask test do_mask, ina wc rcl value, #1 andn outa, ck_mask or outa, ck_mask test do_mask, ina wc rcl value, #1 andn outa, ck_mask or outa, ck_mask test do_mask, ina wc rcl value, #1 andn outa, ck_mask or outa, ck_mask test do_mask, ina wc rcl value, #1 andn outa, ck_mask and value, sample_mask ' trim value (12-bits) or outa, cs_mask ' end communication
void record() {
int32_t clocks_per_sample = CLKFREQ / 16000; /* 16KHz sample rate */
int32_t time_counter = clocks_per_sample + CNT;
uint16_t i = 0;
uint16_t j = 0;
uint16_t sample;
mcp3202_init();
while (1) {
time_counter = waitcnt2(time_counter, clocks_per_sample);
for (i = 0; i < BUFFER_BLOCK_SIZE; ++i) {
sample = mcp3202_get_sample();
buffer[j++] = sample;
j &= BUFFER_SIZE - 1;
blocks_counter = (blocks_counter + 1) & (BUFFER_NUM_BLOCKS - 1);
Thanks.
If you can read SPIN code take a look at this object: http://obex.parallax.com/object/330. It does WAV recording very well.
You're likely going to want a 2 cog solution. One producer and one consumer.
