BS2e (not so) random resets
I have been lurking around here for a while, but have come across an issue that has perplexed me for the past year or two. Before I dive into details, my education is as a mechanical engineer and work as a software engineer, so while I am familiar with basic circuit design, I am no expert. I also am working on the schematic, it is quite involved.
So what I have is an electric 1/8 scale locomotive. Basically the BS2e takes the input from a pot through an rc circuit and other inputs from switches (direction, etc) and then controls a Dimension Engineering SyRen 50 controller as a servo. It is powered by a 12 deep cycle battery. Off that same battery is the headlights as well (2 12 volt lamps controlled by 2 relays via 2 SPST switches on the control box). One of the relays switches the lamps from parallel to series to dim them. About 30% of the time when that relay deenergizes, the BS2e resets.
The issue is I have startup code that I want to use to verify all controls are in a home position before it will allow motion for safety reasons. Even with that code commented out, it is still a rough ride when that happens as the SyRen 50 has regenerative braking.
I have a couple working theories...
1. Grounding problem? Everything shares a common ground. The drive system is 24V, but it still does it with the 24 V removed.
2. Low voltage for the Stamp. I am running a lcd, and accelerometer off the same 5v regulator the stamp is powered off of.
3. Picking up interference, I use a 18 conductor cable going to the control box, so plenty of places to pick up interference.
So that's the basics, and I know I need a schematic out here and I am working on it. Any thoughts would be appreciated.
Thanks!
Andy
Thanks!
Andy
I do not have any diodes on the relays. I will try that tomorrow. I'll try the cap as well.
Thanks!
