WS2812 Demo - OBEX - Pulsing & POV — Parallax Forums
JBWolfJBWolf Posts: 405
edited 2014-07-05 19:12 in Propeller 1
This is specifically regarding OBEX 703 Johnny Mac's awesome WS2812 LED driver.
I am using batteries for my led's and need as much running time as possible.
The LED strips are very bright, even at 1/2 brightness using strip.set, ColorX, WheelX and modifying the Chakras RGB hex values to 1/2.
Pulsing the LED's through the main 'driver' at a sepcific hz/ms to create an appearance of continuous power while saving on battery time would be a great help.
I would love to use this for POV purposes at a later time as well. Something such as a method I could call to set a frames per sec value at any time so as to keep up with any moving object.
  • JonnyMacJonnyMac Posts: 9,649
    edited 2014-04-13 21:04
    I don't think -- if you adjust the color registers to create the same apparent brightness -- that you'll end up saving any energy. I could be wrong. That said, I'm not going to modify my code; you'll have to create your own version.
    I suggest you create a secondary output in the cog that will control a FET to switch the LED string on and off. Turn on the string, update everything, then finish your "on" period. Turn the string off, wait to create the desired duty cycle. Repeat.
    BTW... there is no H in my awesome [first] name. :)
    edited 2014-04-14 13:06
    I read WS2812 LEDs don't make good POV displays. Apparently the WS2811 chip drives the LEDs with a PWM frequency of about 200Hz (IIRC). So you won't be able to control the colors any faster than 200Hz in your display.
  • JBWolfJBWolf Posts: 405
    edited 2014-04-15 03:17
    Well I guess I need to understand one thing about the 2811 operation first... lets say I use "strip.set_all(wheelx(color & $FF, 120))" to get a color at lower power.
    Does your driver just send a single signal to turn them on, and now the each chip on the led strip holds this data until changed? or does your driver constantly update?
    I thought about trying a TTL circuit similar to how I've done for controlling pulsing on a "DDL" style laser driver with the prop... I have used transistors for this purpose and was greatly successful. But using a transistor wouldnt work if your driver doesnt constantly update.
    Wouldnt using an FET just reduce the signal strength unless utilized like a transistor? (full on/off)
    edited 2014-04-15 07:29
    Hi Duane, Jonny commented before that he did a project for limp bizkit with WS2801 and a refresh rate of 300hz... i assumed the 2811/2812 was a newer revision chip with better capabilities... guess not?
    edited 2014-04-15 08:11
    Yes. The reason for the refresh rate of my driver is that I tend to run very dynamic color animations, and I want the refresh rate to be faster than my animation rate.
    The WS2811/12 is a single-wire protocol; the WS2801 uses clock and data lines (not timing finicky). Luckily, the Propeller makes dealing with WS2811/12 timing pretty easy.
    edited 2014-04-15 08:45
    It looks like I was wrong about the 200Hz refresh rate. According to Addafruit Uberguide it's 400Hz. Adafruit is where I read the WS2812 LEDs don't make good POV displays.
  • TubularTubular Posts: 4,771
    edited 2014-04-16 00:49
    But what number of leds are Adafruit basing that 400 Hz "refresh rate" on? And is it being hardware limited because they're running a long string, or an arduino that has limited ram or something?
    For a minimal 8 led pov, you have 192 bits of data (8 leds * 24 bits) = 240 uSec, + 50 uSec latch time, 290uS altogether. That's a refresh rate of 3448 Hz, and the Prop can sustain that nicely.
    Is the PWM frequency actually driving the leds unusually slow or something? They'd get flicker on tv cameras if they did that. I doubt it but don't know for sure.
    Need to solder up a ws2811 IC by itself and look at the actual waveforms. There's a frustrating lack of detail on these ws2812s
    edited 2014-04-16 01:04
    Tubular wrote: »
    I think the 400Hz figure is the WS2811's PWM frequency. If this is the case then, sending data to the chip at a higher frequency than 400 Hz doesn't do you any good.
    edited 2014-04-17 00:58
    Jonny, so your driver does do constant refreshing by using the 'frameloop' ASM code?
    For creating a refresh delay, could I add a short pause right before "jmp #rgbmain" ?
    edited 2014-04-17 08:10
    My name JON!!!!
    The label frameloop is where the program jumps back to in order to read the next rgb value to transmit. The actual program loop begins at rgbmain with the required delay between data bursts.
    BTW... if you're creating your own driver I insist that you take my name off of anything you produce -- at the most you may use the phrase, "based on code by Jon McPhalen." I can only be responsible for my own programming; I will not be held responsible for what you do.
    edited 2014-04-21 05:36
    Duane Degn wrote: »
    Duane you're exactly right. Dug the propscope out tonight and measured it at 424 Hz PWM frequency, which is lower than I expected.
    I guess having such a low pwm frequnecy spares them most EMC issues
  • varnonvarnon Posts: 184
    edited 2014-07-05 10:29
    Tubular, I have been looking for that exact information.
    Just to clarify, was that the frequency during PWM where the LEDs were not a 100% duty cycle? I think that is what you mean, but I have seen some other people (not on these forms) use PWM frequency very loosely. Based on what I see here, and the data sheet. It looks like the WS2811 operates at 4 to 8 kHz and supports a PWM frequency of at least 4 Hz. The WS2812 operates at 8 kHz, but I'm not sure the PWM frequency is any better.
    I think for me 400 Hz is fine. I am not interested in POV. I just want to ensure that any species I work with perceives PWM as a change in intensity, not a change in flicker rate. I do not know any species that has a flicker fusion threshold of ~400 Hz. It may be 300 Hz for honey bees, so I suppose it is possible. But much lower flicker fusion thresholds appear more common. I think these will work fine. The "neopixel" packages adafruit makes are just so super convenient for me.
    edited 2014-07-05 15:33
    Yes, the 424 Hz was the frequency of the pwm cycle.
    You can think of the WS2811's as having a latch that is "dual ported" - the incoming data stream getting written to the internal latch, and the outgoing pwm read from the latch that drives the leds.
    The WS2811 data stream "operates" at 400 to 800 kHz and beyond (not the 4 to 8 kHz you mention) - this is the rate at which bits are clocked into the internal latch on each IC, 24 bits per LED means you can work out the time required to load up a string of leds, and how many times you can load per second. Note its possible to load the latches many times faster than the pwm displays the results, especially for short strings.
    Going from the internal latch to the led itself, happens approx 424 times a second and seems independent of the input data clock (400 to 800 kHz). I would think this could be a minor issue recording on a 50 Hz camera as some leds would be on for 8 and some 9 cycles per 50 Hz frame.
    There's some good timing investigation and results worth checking out at Josh.com
    edited 2014-07-05 17:13
    Thanks for the elaboration and the link. I misread 400-800 on the datasheet as 4-8 somehow. It makes much more sense the way you describe it. I think these will work fine for me. I have a few I have been playing with but I wanted to understand it a little better before buying more.
    No problem, varnon. Good luck with the experimenting.
