RoamingWithIr.bs2 -- Detecting objects from too far away?
Hey, guys. I was working on RoamingWithIr.bs2 (below), and I noticed that instead of detecting objects when it reaches them, the Boe-Bot is detecting and turning in response to objects that are 2-3 feet away. Could someone take a look at the script and see if there's something that can be changed to fix this, or if it's a wiring problem?
[ Title ]
' Robotics with the Boe-Bot - RoamingWithIr.bs2
' Adapt RoamingWithWhiskers.bs2 for use with IR object detectors.
' {$STAMP BS2}
' {$PBASIC 2.5}
[ Variables ]
irDetectLeft VAR Bit
irDetectRight VAR Bit
pulseCount VAR Byte
[ Initialization ]
FREQOUT 4, 2000, 3000
[ Main Routine ]
DO
FREQOUT 8, 1, 38500 'Store IR detection values in
irDetectLeft = IN9 'bit variables
FREQOUT 2, 1, 38500
irDetectRight = IN0
IF (irDetectLeft = 0) AND (irDetectRight = 0) THEN
GOSUB Back_Up
GOSUB Turn_Left
GOSUB Turn_Left
ELSEIF (irDetectLeft = 0) THEN
GOSUB Back_Up
GOSUB Turn_Right
ELSEIF (irDetectRight = 0) THEN
GOSUB Back_Up
GOSUB Turn_Left
ELSE
GOSUB Forward_Pulse
ENDIF
LOOP
[ Subroutines ]
Forward_Pulse:
PULSOUT 13,837
PULSOUT 12,678
PAUSE 20
RETURN
Turn_Left:
FOR pulseCount = 0 TO 20
PULSOUT 13,678
PULSOUT 12,678
PAUSE 20
NEXT
RETURN
Turn_Right:
PULSOUT 13,837
PULSOUT 12,837
PAUSE 20
NEXT
RETURN
Back_Up:
FOR pulseCount = 0 TO 40
PULSOUT 13,678
PULSOUT 12,837
PAUSE 20
NEXT
RETURN
Thanks, guys!
[ Title ]
' {$STAMP BS2}
' {$PBASIC 2.5}
[ Variables ]
pulseCount VAR Byte
[ Initialization ]
[ Main Routine ]
DO
FREQOUT 2, 1, 38500
irDetectRight = IN0
GOSUB Back_Up
GOSUB Turn_Left
GOSUB Turn_Left
GOSUB Back_Up
GOSUB Turn_Right
GOSUB Back_Up
GOSUB Turn_Left
ELSE
GOSUB Forward_Pulse
ENDIF
LOOP
[ Subroutines ]
Forward_Pulse:
PULSOUT 13,837
PULSOUT 12,678
PAUSE 20
RETURN
Turn_Left:
PULSOUT 13,678
PULSOUT 12,678
PAUSE 20
NEXT
RETURN
Turn_Right:
PULSOUT 13,837
PULSOUT 12,837
PAUSE 20
NEXT
RETURN
Back_Up:
PULSOUT 13,678
PULSOUT 12,837
PAUSE 20
NEXT
RETURN
Thanks, guys!
