Int declaration location difference makes .text/hub overflow. Why? — Parallax Forums
pmrobertpmrobert Posts: 677
edited 2014-04-07 14:50 in Propeller 1
I have two ints, x1 & y1 that, if globally declared, give the following error message when compiled. If I declare them in their own local cog function everything is fine.
Here's a partial but specific section of the compiler output:
c:/program files (x86)/simpleide/propeller-gcc/bin/../lib/gcc/propeller-elf/4.6.1/../../../../propeller-elf/bin/ld.exe: lmm/PGCCEFI.elf section `.text' will not fit in region `hub'
c:/program files (x86)/simpleide/propeller-gcc/bin/../lib/gcc/propeller-elf/4.6.1/../../../../propeller-elf/bin/ld.exe: region `hub' overflowed by 15024 bytes
Here's the code that causes the overflow message - x1 & y1 are declared on lines 27 & 28. If I comment them out of the main section and declare them on lines 83 & 84, in the cog they're actually active in, all is good. I would like to know what I'm doing wrong - similar use of global vars for debug/dev purposes in other GCC platforms hasn't been a problem. I'm surely hope it's just some rule that I've tripped over. I use ints hirpm and hiload (declared in lines 35,36, modified in lines 100 & 112 in the cog code and displayed in main code in 71 & 72) in a very similar manner and they work without issue. I did try declaring x1 & y1 volatile and unsigned - no change. If I declare them global, the .text section of the program grows by ~15K no matter what. I included the full compiler output as I'm using EditPlus, not SimpleIDE. The batch file I'm running is included in another code section below.
#include "simpletools.h"    // Include simpletools library
//#include "fdserial.h"       // Include Full Duplex Serial library
#define reboot() __builtin_propeller_clkset(0x80)
// For LMM cog 160 bytes declared as int
// Add enough for stack & calcs
unsigned int stack[(160 + (50 * 4)) / 4];
// Initialize the arrays
//int verpm[] = {500,1000,1500,2000,2500,3000,3500,4000,4500,5000,5500,6000,6500,7000,7500,8000,8500,9000,9500,10000};
volatile unsigned int verpm[20];
//int veload[] = {20,25,30,35,40,45,50,55,60,75,80,85,90,95,100,110,115,120,125,130};
unsigned int veload[20];
unsigned int vetable[20][20];
volatile unsigned int rpm,load;
unsigned int baseaddr = 40000; //EEPROM Adress
unsigned int veresult;
volatile unsigned int verpmsize = (sizeof(verpm)/4);
unsigned int veloadsize = (sizeof(veload)/4);
unsigned int cog2;
//Candidates for moving declarations to interp cog - here now for debug purposes.
//signed int x1;
//signed int y1;
int x1;            // Here there be dragons
int y1;			 //	More dragons here.....
//volatile int x1;
//volatile int y1;
//Debug vars
volatile int hirpm;
volatile int hiload;
// Function prototype
void interp(void *par);
// Cog 0 starts here
int main()
  for ( int i = 0; i < 20; i++ )
     verpm[i]=ee_getInt(baseaddr+2000+(i*4));
     veload[i]=ee_getInt(baseaddr+2080+(i*4));
     print("Loaded verpm[%2d] : %5d from EEPROM Address %x    ",i,verpm[i],baseaddr+2000+(i*4));
     print("Loaded veload[%2d]: %5d from EEPROM Address %x\n",i,veload[i],baseaddr+2080+(i*4));
     for (int i2 = 0; i2 < 20; i2++)
        vetable[i][i2]=ee_getInt(baseaddr+(i*80)+(i2*4));
  //serial *SPORT = fdserial_open(31, 30, 0, 115200);
  print("\n\n                   =->FIN<-=\n");
  cog2 = cogstart(&interp, NULL, stack, sizeof(stack)); // Start interp cog
  while(1)
	 for ( rpm = 0, load = 0; rpm < 12000; rpm=rpm+500,load=load+10 )
		pause(500);
		print("**************\n");
		print("RPM - %d\n",rpm);
		print("LOAD - %d\n",load);
		//print("SizeofRpm - %d\n",verpmsize-1);
		print("hirpm: %d\n",hirpm);
		print("hiload: %d\n",hiload);
	//int x1;			// These work fine when declared here
	//int y1;			// and here.....
	while(1)
	{	// Sanity check of rpm & load, make sure in bounds of table edges
		if (rpm > verpm[verpmsize-1]) rpm = verpm[verpmsize-1];
		else if(rpm < verpm[0]) rpm = verpm[0];
		if (load > veload[veloadsize-1]) load = veload[veloadsize-1];
		else if(load < veload[0]) load = veload[0];
		// Done with Sanity check of rpm & load, make sure in bounds of table edges
		// Get highest index into rpmtable
		for(x1 = 19; x1+1 > 0; x1--)
		if(rpm > verpm[x1])
				hirpm = verpm[x1];
				break;
		// Done with Get highest index into rpmtable
		// Get highest index into loadtable
		for(y1 = 19; y1+1>0; y1--)
		if(load > veload[y1])
				hiload = veload[y1];
				break;
		pause(300);
		// Done with Get highest index into loadtable
Batch file that compiles and loads:
propeller-elf-gcc -v -I . -L . -I %1/SimpleLibraries/Utility/libsimpletools -L %1/SimpleLibraries/Utility/libsimpletools/lmm/ -I %1/SimpleLibraries/TextDevices/libsimpletext -L %1/SimpleLibraries/TextDevices/libsimpletext/lmm/ -I %1/SimpleLibraries/Protocol/libsimplei2c -L %1/SimpleLibraries/Protocol/libsimplei2c/lmm/ -I %1/SimpleLibraries/TextDevices/libfdserial -L %1/SimpleLibraries/TextDevices/libfdserial/lmm/ -o lmm/%2.elf -Os -mlmm -Wall -m32bit-doubles -fno-exceptions -std=c99 -save-temps %2.c -lm -lsimpletools -lsimpletext -lsimplei2c -lfdserial -lm -lsimpletools -lsimpletext -lsimplei2c -lm -lsimpletools -lsimpletext -lm -lsimpletools -lm
rem propeller-load -v -s %1\lmm\%2.elf
propeller-load -v -e -r %1\lmm\%2.elf
Compiler output:
---------- Compile C Source ----------
Using built-in specs.
COLLECT_GCC=propeller-elf-gcc
COLLECT_LTO_WRAPPER=c:/program files (x86)/simpleide/propeller-gcc/bin/../libexec/gcc/propeller-elf/4.6.1/lto-wrapper.exe
Target: propeller-elf
Configured with: ../../propgcc/gcc/configure --target=propeller-elf --prefix=/opt/parallax --disable-nls --disable-libssp --disable-lto --disable-shared --with-pkgversion=propellergcc_v1_0_0_2162 --with-bugurl=http://code.google.com/p/propgcc/issues : (reconfigured) ../../propgcc/gcc/configure --target=propeller-elf --prefix=/opt/parallax --disable-nls --disable-libssp --disable-lto --disable-shared --with-pkgversion=propellergcc_v1_0_0_2162 --with-bugurl=http://code.google.com/p/propgcc/issues
Thread model: single
gcc version 4.6.1 (propellergcc_v1_0_0_2162)
COLLECT_GCC_OPTIONS='-v' '-I' '.' '-L.' '-I' 'C:\PropGCC_EFI/SimpleLibraries/Utility/libsimpletools' '-LC:\PropGCC_EFI/SimpleLibraries/Utility/libsimpletools/lmm/' '-I' 'C:\PropGCC_EFI/SimpleLibraries/TextDevices/libsimpletext' '-LC:\PropGCC_EFI/SimpleLibraries/TextDevices/libsimpletext/lmm/' '-I' 'C:\PropGCC_EFI/SimpleLibraries/Protocol/libsimplei2c' '-LC:\PropGCC_EFI/SimpleLibraries/Protocol/libsimplei2c/lmm/' '-I' 'C:\PropGCC_EFI/SimpleLibraries/TextDevices/libfdserial' '-LC:\PropGCC_EFI/SimpleLibraries/TextDevices/libfdserial/lmm/' '-o' 'lmm/PGCCEFI.elf' '-Os' '-mlmm' '-Wall' '-m32bit-doubles' '-fno-exceptions' '-std=c99' '-save-temps'
 c:/program files (x86)/simpleide/propeller-gcc/bin/../libexec/gcc/propeller-elf/4.6.1/cc1.exe -E -quiet -v -I . -I C:\PropGCC_EFI/SimpleLibraries/Utility/libsimpletools -I C:\PropGCC_EFI/SimpleLibraries/TextDevices/libsimpletext -I C:\PropGCC_EFI/SimpleLibraries/Protocol/libsimplei2c -I C:\PropGCC_EFI/SimpleLibraries/TextDevices/libfdserial -imultilib short-doubles -iprefix c:\program files (x86)\simpleide\propeller-gcc\bin\../lib/gcc/propeller-elf/4.6.1/ PGCCEFI.c -mlmm -m32bit-doubles -std=c99 -Wall -fno-exceptions -Os -fpch-preprocess -o PGCCEFI.i
ignoring nonexistent directory "c:\program files (x86)\simpleide\propeller-gcc\bin\../lib/gcc/propeller-elf/4.6.1/../../../../propeller-elf/sys-include"
ignoring duplicate directory "c:/program files (x86)/simpleide/propeller-gcc/lib/gcc/../../lib/gcc/propeller-elf/4.6.1/include"
ignoring duplicate directory "c:/program files (x86)/simpleide/propeller-gcc/lib/gcc/../../lib/gcc/propeller-elf/4.6.1/include-fixed"
ignoring nonexistent directory "c:/program files (x86)/simpleide/propeller-gcc/lib/gcc/../../lib/gcc/propeller-elf/4.6.1/../../../../propeller-elf/sys-include"
ignoring duplicate directory "c:/program files (x86)/simpleide/propeller-gcc/lib/gcc/../../lib/gcc/propeller-elf/4.6.1/../../../../propeller-elf/include"
#include "..." search starts here:
#include <...> search starts here:
 c:\program files (x86)\simpleide\propeller-gcc\bin\../lib/gcc/propeller-elf/4.6.1/include
 c:\program files (x86)\simpleide\propeller-gcc\bin\../lib/gcc/propeller-elf/4.6.1/include-fixed
 c:\program files (x86)\simpleide\propeller-gcc\bin\../lib/gcc/propeller-elf/4.6.1/../../../../propeller-elf/include
End of search list.
 c:/program files (x86)/simpleide/propeller-gcc/bin/../libexec/gcc/propeller-elf/4.6.1/cc1.exe -fpreprocessed PGCCEFI.i -quiet -dumpbase PGCCEFI.c -mlmm -m32bit-doubles -auxbase PGCCEFI -Os -Wall -std=c99 -version -fno-exceptions -o PGCCEFI.s
GNU C (propellergcc_v1_0_0_2162) version 4.6.1 (propeller-elf)
	compiled by GNU C version 4.6.2, GMP version 5.0.2, MPFR version 3.0.1, MPC version 0.9
GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072
Compiler executable checksum: b164ade464d31b01e5f340d6fe7b3f00
 c:/program files (x86)/simpleide/propeller-gcc/bin/../lib/gcc/propeller-elf/4.6.1/../../../../propeller-elf/bin/as.exe -lmm -o PGCCEFI.o PGCCEFI.s
COMPILER_PATH=c:/program files (x86)/simpleide/propeller-gcc/bin/../libexec/gcc/propeller-elf/4.6.1/;c:/program files (x86)/simpleide/propeller-gcc/bin/../libexec/gcc/;c:/program files (x86)/simpleide/propeller-gcc/bin/../lib/gcc/propeller-elf/4.6.1/../../../../propeller-elf/bin/
LIBRARY_PATH=c:/program files (x86)/simpleide/propeller-gcc/bin/../lib/gcc/propeller-elf/4.6.1/short-doubles/;c:/program files (x86)/simpleide/propeller-gcc/bin/../lib/gcc/propeller-elf/4.6.1/../../../../propeller-elf/lib/short-doubles/;c:/program files (x86)/simpleide/propeller-gcc/bin/../lib/gcc/propeller-elf/4.6.1/;c:/program files (x86)/simpleide/propeller-gcc/bin/../lib/gcc/;c:/program files (x86)/simpleide/propeller-gcc/bin/../lib/gcc/propeller-elf/4.6.1/../../../../propeller-elf/lib/
 c:/program files (x86)/simpleide/propeller-gcc/bin/../libexec/gcc/propeller-elf/4.6.1/collect2.exe -mpropeller -o lmm/PGCCEFI.elf c:/program files (x86)/simpleide/propeller-gcc/bin/../lib/gcc/propeller-elf/4.6.1/short-doubles/spinboot.o c:/program files (x86)/simpleide/propeller-gcc/bin/../lib/gcc/propeller-elf/4.6.1/short-doubles/_crt0.o c:/program files (x86)/simpleide/propeller-gcc/bin/../lib/gcc/propeller-elf/4.6.1/short-doubles/_crtbegin.o -L. -LC:\PropGCC_EFI/SimpleLibraries/Utility/libsimpletools/lmm/ -LC:\PropGCC_EFI/SimpleLibraries/TextDevices/libsimpletext/lmm/ -LC:\PropGCC_EFI/SimpleLibraries/Protocol/libsimplei2c/lmm/ -LC:\PropGCC_EFI/SimpleLibraries/TextDevices/libfdserial/lmm/ -Lc:/program files (x86)/simpleide/propeller-gcc/bin/../lib/gcc/propeller-elf/4.6.1/short-doubles -Lc:/program files (x86)/simpleide/propeller-gcc/bin/../lib/gcc/propeller-elf/4.6.1/../../../../propeller-elf/lib/short-doubles -Lc:/program files (x86)/simpleide/propeller-gcc/bin/../lib/gcc/propeller-elf/4.6.1 -Lc:/program files (x86)/simpleide/propeller-gcc/bin/../lib/gcc -Lc:/program files (x86)/simpleide/propeller-gcc/bin/../lib/gcc/propeller-elf/4.6.1/../../../../propeller-elf/lib PGCCEFI.o -lm -lsimpletools -lsimpletext -lsimplei2c -lfdserial -lm -lsimpletools -lsimpletext -lsimplei2c -lm -lsimpletools -lsimpletext -lm -lsimpletools -lm -lgcc --start-group -lc -lgcc --end-group -lgcc c:/program files (x86)/simpleide/propeller-gcc/bin/../lib/gcc/propeller-elf/4.6.1/short-doubles/_crtend.o
collect2: ld returned 1 exit status
Output completed (0 sec consumed) - Normal Termination
Thanks to all in advance..... -Mike
  • jazzedjazzed Posts: 11,803
    edited 2014-04-07 12:59
    Can you look at a .map file and tell where things are being placed?
    In SimpleIDE, right click on a file in the project manager and select Show Map File.
    Or use this on the command line:
    propeller-elf-gcc -Xlinker -Map=somefile.map somefile.c
  • SRLMSRLM Posts: 5,045
    edited 2014-04-07 13:08
    Interesting. Here's the same program, with the simpletools things taken out and replaced with stdio.h and propeller.h. I also switched out your verpm and veload variables for the constant versions you've defined:
    #include <stdio.h>
    #include "propeller.h"
    volatile int verpm[] = {500,1000,1500,2000,2500,3000,3500,4000,4500,5000,5500,6000,6500,7000,7500,8000,8500,9000,9500,10000};
    //volatile unsigned int verpm[20];
    volatile int veload[] = {20,25,30,35,40,45,50,55,60,75,80,85,90,95,100,110,115,120,125,130};
    //unsigned int veload[20];
    unsigned int cog2;
    //signed int x1;
    //signed int y1;
    //volatile int x1;
    //volatile int y1;
    //Debug vars
    volatile int hirpm;
    int main()
         //verpm[i]=ee_getInt(baseaddr+2000+(i*4));
         //veload[i]=ee_getInt(baseaddr+2080+(i*4));
         printf("Loaded verpm[%2d] : %5d from EEPROM Address %x    ",i,verpm[i],baseaddr+2000+(i*4));
         printf("Loaded veload[%2d]: %5d from EEPROM Address %x\n",i,veload[i],baseaddr+2080+(i*4));
            //vetable[i][i2]=ee_getInt(baseaddr+(i*80)+(i2*4));
      printf("\n\n                   =->FIN<-=\n");
      while(1)
    		waitcnt(CLKFREQ/2 + CNT);
    		printf("**************\n");
    		printf("RPM - %d\n",rpm);
    		printf("LOAD - %d\n",load);
    		printf("hirpm: %d\n",hirpm);
    		printf("hiload: %d\n",hiload);
    	while(1)
    		if(rpm > verpm[x1])
    				hirpm = verpm[x1];
    				break;
    				break;
    		waitcnt(CLKFREQ*300/1000 + CNT);
    And here's the compilation:
    $ propeller-elf-g++ -Os main.cpp; propeller-elf-size a.out
       text	   data	    bss	    dec	    hex	filename
      23380	      0	   2664	  26044	   65bc	a.out
    With this version it works. I'm not sure what to conclude from this. Just another data point I guess.
    Edit: I've added the map file, just in case.
  • pmrobertpmrobert Posts: 677
    edited 2014-04-07 13:26
    I found the problem. Another "silent conflict" - it looks like "x1" & "y1" are used in some part of the library but not prototyped. I renamed them to xq1 and yq1 and all is well. I had a similar problem last week or so with using the var name "pw" - it's used in the pwm module but not prototyped so there is no error or warning message, just stuff goes dead for no apparent reason or an odd compiler cratering like today's situation. I hope Parallax addresses this stuff as this is exactly the kind of thing that will make an educator unhappy. Anyway, here's the .map file. Thank you, sir, and appreciate your assistance.
    -Mike
    Archive member included because of file (symbol)
    C:\PropGCC_EFI/SimpleLibraries/Utility/libsimpletools/lmm/\libsimpletools.a(pause.o)
                                  PGCCEFI.o (_pause)
    C:\PropGCC_EFI/SimpleLibraries/Utility/libsimpletools/lmm/\libsimpletools.a(setPauseDt.o)
                                  C:\PropGCC_EFI/SimpleLibraries/Utility/libsimpletools/lmm/\libsimpletools.a(pause.o) (_set_pause_dt)
    C:\PropGCC_EFI/SimpleLibraries/Utility/libsimpletools/lmm/\libsimpletools.a(eeprom_getInt.o)
                                  PGCCEFI.o (_ee_getInt)
    C:\PropGCC_EFI/SimpleLibraries/Utility/libsimpletools/lmm/\libsimpletools.a(i2c_in.o)
                                  C:\PropGCC_EFI/SimpleLibraries/Utility/libsimpletools/lmm/\libsimpletools.a(eeprom_getInt.o) (_i2c_in)
    C:\PropGCC_EFI/SimpleLibraries/Utility/libsimpletools/lmm/\libsimpletools.a(eeprom_init.o)
                                  C:\PropGCC_EFI/SimpleLibraries/Utility/libsimpletools/lmm/\libsimpletools.a(eeprom_getInt.o) (_ee_init)
    C:\PropGCC_EFI/SimpleLibraries/Utility/libsimpletools/lmm/\libsimpletools.a(i2c_init.o)
                                  C:\PropGCC_EFI/SimpleLibraries/Utility/libsimpletools/lmm/\libsimpletools.a(eeprom_init.o) (_i2c_newbus)
    C:\PropGCC_EFI/SimpleLibraries/TextDevices/libsimpletext/lmm/\libsimpletext.a(print.o)
                                  PGCCEFI.o (_print)
    C:\PropGCC_EFI/SimpleLibraries/TextDevices/libsimpletext/lmm/\libsimpletext.a(putStr.o)
                                  C:\PropGCC_EFI/SimpleLibraries/TextDevices/libsimpletext/lmm/\libsimpletext.a(print.o) (_putStr)
    C:\PropGCC_EFI/SimpleLibraries/TextDevices/libsimpletext/lmm/\libsimpletext.a(putChar.o)
                                  C:\PropGCC_EFI/SimpleLibraries/TextDevices/libsimpletext/lmm/\libsimpletext.a(putStr.o) (_putChar)
    C:\PropGCC_EFI/SimpleLibraries/TextDevices/libsimpletext/lmm/\libsimpletext.a(simpleterm.o)
                                  C:\PropGCC_EFI/SimpleLibraries/TextDevices/libsimpletext/lmm/\libsimpletext.a(putChar.o) (_dport_ptr)
    C:\PropGCC_EFI/SimpleLibraries/TextDevices/libsimpletext/lmm/\libsimpletext.a(dosprint.o)
                                  C:\PropGCC_EFI/SimpleLibraries/TextDevices/libsimpletext/lmm/\libsimpletext.a(print.o) (__dosprnt)
    C:\PropGCC_EFI/SimpleLibraries/TextDevices/libsimpletext/lmm/\libsimpletext.a(serial_rxtx.o)
                                  C:\PropGCC_EFI/SimpleLibraries/TextDevices/libsimpletext/lmm/\libsimpletext.a(simpleterm.o) (_serial_rxChar)
    C:\PropGCC_EFI/SimpleLibraries/TextDevices/libsimpletext/lmm/\libsimpletext.a(floatToString.o)
                                  C:\PropGCC_EFI/SimpleLibraries/TextDevices/libsimpletext/lmm/\libsimpletext.a(dosprint.o) (_float2string)
    C:\PropGCC_EFI/SimpleLibraries/Protocol/libsimplei2c/lmm/\libsimplei2c.a(simplei2c.o)
                                  C:\PropGCC_EFI/SimpleLibraries/Utility/libsimpletools/lmm/\libsimpletools.a(i2c_in.o) (_i2c_start)
    C:\PropGCC_EFI/SimpleLibraries/Utility/libsimpletools/lmm/\libsimpletools.a(fpucog.o)
                                  C:\PropGCC_EFI/SimpleLibraries/TextDevices/libsimpletext/lmm/\libsimpletext.a(floatToString.o) (___subsf3)
    c:/program files (x86)/simpleide/propeller-gcc/bin/../lib/gcc/propeller-elf/4.6.1/short-doubles\libgcc.a(gesf2.o)
                                  C:\PropGCC_EFI/SimpleLibraries/TextDevices/libsimpletext/lmm/\libsimpletext.a(floatToString.o) (___gesf2)
    c:/program files (x86)/simpleide/propeller-gcc/bin/../lib/gcc/propeller-elf/4.6.1/short-doubles\libgcc.a(lesf2.o)
                                  C:\PropGCC_EFI/SimpleLibraries/TextDevices/libsimpletext/lmm/\libsimpletext.a(floatToString.o) (___ltsf2)
    c:/program files (x86)/simpleide/propeller-gcc/bin/../lib/gcc/propeller-elf/4.6.1/short-doubles\libgcc.a(fixsfsi.o)
                                  C:\PropGCC_EFI/SimpleLibraries/TextDevices/libsimpletext/lmm/\libsimpletext.a(floatToString.o) (_(float, int, long long, short, float, short, int))
    c:/program files (x86)/simpleide/propeller-gcc/bin/../lib/gcc/propeller-elf/4.6.1/short-doubles\libgcc.a(fixunssfsi.o)
                                  C:\PropGCC_EFI/SimpleLibraries/TextDevices/libsimpletext/lmm/\libsimpletext.a(floatToString.o) (___fixunssfsi)
    c:/program files (x86)/simpleide/propeller-gcc/bin/../lib/gcc/propeller-elf/4.6.1/short-doubles\libgcc.a(floatunsisf.o)
                                  C:\PropGCC_EFI/SimpleLibraries/TextDevices/libsimpletext/lmm/\libsimpletext.a(floatToString.o) (___floatunsisf)
    c:/program files (x86)/simpleide/propeller-gcc/bin/../lib/gcc/propeller-elf/4.6.1/../../../../propeller-elf/lib/short-doubles\libc.a(ctype.o)
                                  C:\PropGCC_EFI/SimpleLibraries/TextDevices/libsimpletext/lmm/\libsimpletext.a(dosprint.o) (___ctype)
    c:/program files (x86)/simpleide/propeller-gcc/bin/../lib/gcc/propeller-elf/4.6.1/../../../../propeller-elf/lib/short-doubles\libc.a(thread.o)
                                  c:/program files (x86)/simpleide/propeller-gcc/bin/../lib/gcc/propeller-elf/4.6.1/short-doubles/_crt0.o (__TLS)
    c:/program files (x86)/simpleide/propeller-gcc/bin/../lib/gcc/propeller-elf/4.6.1/../../../../propeller-elf/lib/short-doubles\libc.a(cogstart.o)
                                  PGCCEFI.o (_cogstart)
    c:/program files (x86)/simpleide/propeller-gcc/bin/../lib/gcc/propeller-elf/4.6.1/../../../../propeller-elf/lib/short-doubles\libc.a(memset.o)
                                  c:/program files (x86)/simpleide/propeller-gcc/bin/../lib/gcc/propeller-elf/4.6.1/short-doubles/_crtbegin.o (_memset)
    Allocating common symbols
    Common symbol       size              file
    _eeInitFlag         0x4               C:\PropGCC_EFI/SimpleLibraries/Utility/libsimpletools/lmm/\libsimpletools.a(eeprom_getInt.o)
    _rpm                0x4               PGCCEFI.o
    _eeprom             0x4               C:\PropGCC_EFI/SimpleLibraries/Utility/libsimpletools/lmm/\libsimpletools.a(eeprom_getInt.o)
    _verpm              0x50              PGCCEFI.o
    _hiload             0x4               PGCCEFI.o
    _veload             0x50              PGCCEFI.o
    _cog2               0x4               PGCCEFI.o
    _vetable            0x640             PGCCEFI.o
    _yq1                0x4               PGCCEFI.o
    _xq1                0x4               PGCCEFI.o
    _veresult           0x4               PGCCEFI.o
    _debug_serial       0x14              C:\PropGCC_EFI/SimpleLibraries/TextDevices/libsimpletext/lmm/\libsimpletext.a(simpleterm.o)
    _hirpm              0x4               PGCCEFI.o
    _stack              0x168             PGCCEFI.o
    _load               0x4               PGCCEFI.o
    Memory Configuration
    Name             Origin             Length             Attributes
    hub              0x00000000         0x00008000
    cog              0x00000000         0x000007c0
    coguser          0x00000000         0x000007c0
    ram              0x20000000         0x10000000
    rom              0x30000000         0x10000000
    drivers          0xc0000000         0x00100000
    dummy            0xe0000000         0x00100000
    *default*        0x00000000         0xffffffff
    Linker script and memory map
    LOAD c:/program files (x86)/simpleide/propeller-gcc/bin/../lib/gcc/propeller-elf/4.6.1/short-doubles/spinboot.o
    LOAD c:/program files (x86)/simpleide/propeller-gcc/bin/../lib/gcc/propeller-elf/4.6.1/short-doubles/_crt0.o
    LOAD c:/program files (x86)/simpleide/propeller-gcc/bin/../lib/gcc/propeller-elf/4.6.1/short-doubles/_crtbegin.o
    LOAD PGCCEFI.o
    LOAD c:/program files (x86)/simpleide/propeller-gcc/bin/../lib/gcc/propeller-elf/4.6.1/../../../../propeller-elf/lib/short-doubles\libm.a
    LOAD C:\PropGCC_EFI/SimpleLibraries/Utility/libsimpletools/lmm/\libsimpletools.a
    LOAD C:\PropGCC_EFI/SimpleLibraries/TextDevices/libsimpletext/lmm/\libsimpletext.a
    LOAD C:\PropGCC_EFI/SimpleLibraries/Protocol/libsimplei2c/lmm/\libsimplei2c.a
    LOAD C:\PropGCC_EFI/SimpleLibraries/TextDevices/libfdserial/lmm/\libfdserial.a
    LOAD c:/program files (x86)/simpleide/propeller-gcc/bin/../lib/gcc/propeller-elf/4.6.1/short-doubles\libgcc.a
    START GROUP
    LOAD c:/program files (x86)/simpleide/propeller-gcc/bin/../lib/gcc/propeller-elf/4.6.1/../../../../propeller-elf/lib/short-doubles\libc.a
    END GROUP
    LOAD c:/program files (x86)/simpleide/propeller-gcc/bin/../lib/gcc/propeller-elf/4.6.1/short-doubles/_crtend.o
    .boot           0x00000000       0x20
     *(.boot)
     .boot          0x00000000       0x20 c:/program files (x86)/simpleide/propeller-gcc/bin/../lib/gcc/propeller-elf/4.6.1/short-doubles/spinboot.o
                    0x00000000                __clkfreq
                    0x00000004                __clkmode
                    0x00000008                __sys_mbox
    .lmmkernel      0x00000000      0x794 load address 0x00000020
     *(.lmmkernel)
     .lmmkernel     0x00000000      0x790 c:/program files (x86)/simpleide/propeller-gcc/bin/../lib/gcc/propeller-elf/4.6.1/short-doubles/_crt0.o
                    0x00000000                r0
                    0x00000000                __LMM_entry
                    0x00000004                r1
                    0x00000008                r2
                    0x0000000c                r3
                    0x00000010                r4
                    0x00000014                r5
                    0x00000018                r6
                    0x0000001c                r7
                    0x00000020                r8
                    0x00000024                r9
                    0x00000028                r10
                    0x0000002c                r11
                    0x00000030                r12
                    0x00000034                r13
                    0x00000038                r14
                    0x0000003c                lr
                    0x00000040                sp
                    0x00000044                pc
                    0x000000ac                __LMM_MVI_r0
                    0x000000b8                __LMM_MVI_r1
                    0x000000c4                __LMM_MVI_r2
                    0x000000d0                __LMM_MVI_r3
                    0x000000dc                __LMM_MVI_r4
                    0x000000e8                __LMM_MVI_r5
                    0x000000f4                __LMM_MVI_r6
                    0x00000100                __LMM_MVI_r7
                    0x0000010c                __LMM_MVI_r8
                    0x00000118                __LMM_MVI_r9
                    0x00000124                __LMM_MVI_r10
                    0x00000130                __LMM_MVI_r11
                    0x0000013c                __LMM_MVI_r12
                    0x00000148                __LMM_MVI_r13
                    0x00000154                __LMM_MVI_r14
                    0x00000160                __LMM_MVI_lr
                    0x0000016c                __LMM_CALL
                    0x00000174                __LMM_CALL_INDIRECT
                    0x00000180                __LMM_JMP
                    0x00000188                __LMM_PUSHM
                    0x000001a8                __LMM_PUSHM_ret
                    0x000001b0                __LMM_POPRET
                    0x000001b8                __LMM_POPRET_ret
                    0x000001bc                __LMM_POPM
                    0x000001dc                __LMM_POPM_ret
                    0x000001e0                __MASK_0000FFFF
                    0x000001e4                __MASK_FFFFFFFF
                    0x000001e8                __TMP0
                    0x000001fc                __CLZSI
                    0x00000200                __CTZSI
                    0x00000238                __CLZSI_ret
                    0x00000244                __UDIVSI
                    0x00000288                __UDIVSI_ret
                    0x00000290                __DIVSI
                    0x000002b8                __DIVSI_ret
                    0x000002c8                __MULSI
                    0x000002e8                __MULSI_ret
                    0x000002ec                __C_LOCK_PTR
                    0x000002f0                __CMPSWAPSI
                    0x00000310                __CMPSWAPSI_ret
                    0x0000031c                __LMM_RET
                    0x00000320                __LMM_FCACHE_LOAD
                    0x00000390                __LMM_FCACHE_START
     *(.kernel)
     .kernel        0x00000790        0x4 c:/program files (x86)/simpleide/propeller-gcc/bin/../lib/gcc/propeller-elf/4.6.1/../../../../propeller-elf/lib/short-doubles\libc.a(thread.o)
                    0x00000790                __TLS
    .init           0x000007b4       0xb8
     *(.init*)
     .init          0x000007b4       0xa0 c:/program files (x86)/simpleide/propeller-gcc/bin/../lib/gcc/propeller-elf/4.6.1/short-doubles/_crtbegin.o
                    0x000007b4                start
                    0x000007b4                entry
                    0x000007fc                ___init
     .init          0x00000854       0x18 c:/program files (x86)/simpleide/propeller-gcc/bin/../lib/gcc/propeller-elf/4.6.1/short-doubles/_crtend.o
    .text           0x0000086c     0x19bc
     *(.text*)
     .text          0x0000086c        0x0 c:/program files (x86)/simpleide/propeller-gcc/bin/../lib/gcc/propeller-elf/4.6.1/short-doubles/spinboot.o
     .text          0x0000086c        0x0 c:/program files (x86)/simpleide/propeller-gcc/bin/../lib/gcc/propeller-elf/4.6.1/short-doubles/_crt0.o
     .text          0x0000086c        0x0 c:/program files (x86)/simpleide/propeller-gcc/bin/../lib/gcc/propeller-elf/4.6.1/short-doubles/_crtbegin.o
     .text          0x0000086c      0x4ac PGCCEFI.o
                    0x0000086c                _interp
                    0x00000a40                _main
     .text          0x00000d18       0x6c C:\PropGCC_EFI/SimpleLibraries/Utility/libsimpletools/lmm/\libsimpletools.a(pause.o)
                    0x00000d18                _pause
     .text          0x00000d84       0x10 C:\PropGCC_EFI/SimpleLibraries/Utility/libsimpletools/lmm/\libsimpletools.a(setPauseDt.o)
                    0x00000d84                _set_pause_dt
     .text          0x00000d94       0xd0 C:\PropGCC_EFI/SimpleLibraries/Utility/libsimpletools/lmm/\libsimpletools.a(eeprom_getInt.o)
                    0x00000d94                _ee_getInt
     .text          0x00000e64        0x0 C:\PropGCC_EFI/SimpleLibraries/Utility/libsimpletools/lmm/\libsimpletools.a(i2c_in.o)
     .text          0x00000e64       0x44 C:\PropGCC_EFI/SimpleLibraries/Utility/libsimpletools/lmm/\libsimpletools.a(eeprom_init.o)
                    0x00000e64                _ee_init
     .text          0x00000ea8       0x70 C:\PropGCC_EFI/SimpleLibraries/Utility/libsimpletools/lmm/\libsimpletools.a(i2c_init.o)
                    0x00000ea8                _i2c_newbus
     .text          0x00000f18       0x4c C:\PropGCC_EFI/SimpleLibraries/TextDevices/libsimpletext/lmm/\libsimpletext.a(print.o)
                    0x00000f18                _print
     .text          0x00000f64       0x38 C:\PropGCC_EFI/SimpleLibraries/TextDevices/libsimpletext/lmm/\libsimpletext.a(putStr.o)
                    0x00000f64                _putStr
     .text          0x00000f9c       0x6c C:\PropGCC_EFI/SimpleLibraries/TextDevices/libsimpletext/lmm/\libsimpletext.a(putChar.o)
                    0x00000f9c                _putChar
     .text          0x00001008      0x10c C:\PropGCC_EFI/SimpleLibraries/TextDevices/libsimpletext/lmm/\libsimpletext.a(simpleterm.o)
                    0x00001008                _simpleterm_open
                    0x00001104                _simpleterm_pointer
     .text          0x00001114      0x3a0 C:\PropGCC_EFI/SimpleLibraries/TextDevices/libsimpletext/lmm/\libsimpletext.a(dosprint.o)
                    0x00001200                __dosprnt
     .text          0x000014b4      0x130 C:\PropGCC_EFI/SimpleLibraries/TextDevices/libsimpletext/lmm/\libsimpletext.a(serial_rxtx.o)
                    0x00001534                _serial_rxChar
                    0x0000158c                _serial_txChar
     .text          0x000015e4      0x380 C:\PropGCC_EFI/SimpleLibraries/TextDevices/libsimpletext/lmm/\libsimpletext.a(floatToString.o)
                    0x000015e4                _float2string
     .text          0x00001964        0x0 C:\PropGCC_EFI/SimpleLibraries/Protocol/libsimplei2c/lmm/\libsimplei2c.a(simplei2c.o)
     .text          0x00001964      0x370 C:\PropGCC_EFI/SimpleLibraries/Utility/libsimpletools/lmm/\libsimpletools.a(fpucog.o)
                    0x00001a44                _start_fpu_cog
                    0x00001aa4                _stop_fpu_cog
                    0x00001acc                ___adddf3
                    0x00001af8                ___subdf3
                    0x00001b24                ___muldf3
                    0x00001b50                ___divdf3
                    0x00001b7c                ___addsf3
                    0x00001b9c                ___subsf3
                    0x00001bbc                ___mulsf3
                    0x00001bdc                ___divsf3
                    0x00001bfc                ___floatsisf
                    0x00001c20                ___floatunssisf
                    0x00001c44                ___floatsidf
                    0x00001c68                ___floatunssidf
                    0x00001c8c                ___extendsfdf2
                    0x00001cb0                ___truncdfsf2
     .text          0x00001cd4      0x118 c:/program files (x86)/simpleide/propeller-gcc/bin/../lib/gcc/propeller-elf/4.6.1/short-doubles\libgcc.a(gesf2.o)
                    0x00001cd4                ___gesf2
                    0x00001cd4                ___gtsf2
     .text          0x00001dec      0x118 c:/program files (x86)/simpleide/propeller-gcc/bin/../lib/gcc/propeller-elf/4.6.1/short-doubles\libgcc.a(lesf2.o)
                    0x00001dec                ___ltsf2
                    0x00001dec                ___lesf2
     .text          0x00001f04       0x7c c:/program files (x86)/simpleide/propeller-gcc/bin/../lib/gcc/propeller-elf/4.6.1/short-doubles\libgcc.a(fixsfsi.o)
                    0x00001f04                _(float, int, long long, short, float, short, int)
     .text          0x00001f80       0x7c c:/program files (x86)/simpleide/propeller-gcc/bin/../lib/gcc/propeller-elf/4.6.1/short-doubles\libgcc.a(fixunssfsi.o)
                    0x00001f80                ___fixunssfsi
     .text          0x00001ffc      0x10c c:/program files (x86)/simpleide/propeller-gcc/bin/../lib/gcc/propeller-elf/4.6.1/short-doubles\libgcc.a(floatunsisf.o)
                    0x00001ffc                ___floatunsisf
     .text          0x00002108        0x0 c:/program files (x86)/simpleide/propeller-gcc/bin/../lib/gcc/propeller-elf/4.6.1/../../../../propeller-elf/lib/short-doubles\libc.a(ctype.o)
     .text          0x00002108        0x4 c:/program files (x86)/simpleide/propeller-gcc/bin/../lib/gcc/propeller-elf/4.6.1/../../../../propeller-elf/lib/short-doubles\libc.a(thread.o)
     .text          0x0000210c       0x80 c:/program files (x86)/simpleide/propeller-gcc/bin/../lib/gcc/propeller-elf/4.6.1/../../../../propeller-elf/lib/short-doubles\libc.a(cogstart.o)
                    0x0000210c                _cogstart
     .text          0x0000218c       0x9c c:/program files (x86)/simpleide/propeller-gcc/bin/../lib/gcc/propeller-elf/4.6.1/../../../../propeller-elf/lib/short-doubles\libc.a(memset.o)
                    0x0000218c                _memset
     .text          0x00002228        0x0 c:/program files (x86)/simpleide/propeller-gcc/bin/../lib/gcc/propeller-elf/4.6.1/short-doubles/_crtend.o
                    0x00002228                _etext = .
    .fpu.cog        0x00000000      0x71c load address 0x00002228
     .fpu.cog       0x00000000      0x71c C:\PropGCC_EFI/SimpleLibraries/Utility/libsimpletools/lmm/\libsimpletools.a(fpucog.o)
    .fini           0x00002944       0x3c
     *(.fini*)
     .fini          0x00002944       0x28 c:/program files (x86)/simpleide/propeller-gcc/bin/../lib/gcc/propeller-elf/4.6.1/short-doubles/_crtbegin.o
                    0x00002944                _exit
     .fini          0x0000296c       0x14 c:/program files (x86)/simpleide/propeller-gcc/bin/../lib/gcc/propeller-elf/4.6.1/short-doubles/_crtend.o
                    0x00002970                __Exit
                    0x00002970                __exit
                    0x0000297c                __ExitHook
    .hub            0x00002980      0x744
     *(.hubstart)
     *(.hubtext*)
     .hubtext       0x00002980       0xc8 C:\PropGCC_EFI/SimpleLibraries/Utility/libsimpletools/lmm/\libsimpletools.a(i2c_in.o)
                    0x00002980                _i2c_in
     .hubtext       0x00002a48      0x4d4 C:\PropGCC_EFI/SimpleLibraries/Protocol/libsimplei2c/lmm/\libsimplei2c.a(simplei2c.o)
                    0x00002acc                _i2c_start
                    0x00002b80                _i2c_stop
                    0x00002c00                _i2c_open
                    0x00002c68                _i2c_writeByte
                    0x00002d24                _i2c_readByte
                    0x00002e20                _i2c_writeData
                    0x00002e80                _i2c_readData
                    0x00002eec                _i2c_poll
     *(.hubdata*)
     *(.hub)
     .hub           0x00002f1c       0x2c C:\PropGCC_EFI/SimpleLibraries/TextDevices/libsimpletext/lmm/\libsimpletext.a(simpleterm.o)
                    0x00002f1c                _debug_port
                    0x00002f44                _dport_ptr
     .hub           0x00002f48        0x4 C:\PropGCC_EFI/SimpleLibraries/Utility/libsimpletools/lmm/\libsimpletools.a(fpucog.o)
     *(.data)
     .data          0x00002f4c        0x0 c:/program files (x86)/simpleide/propeller-gcc/bin/../lib/gcc/propeller-elf/4.6.1/short-doubles/spinboot.o
     .data          0x00002f4c        0x0 c:/program files (x86)/simpleide/propeller-gcc/bin/../lib/gcc/propeller-elf/4.6.1/short-doubles/_crt0.o
     .data          0x00002f4c        0x0 c:/program files (x86)/simpleide/propeller-gcc/bin/../lib/gcc/propeller-elf/4.6.1/short-doubles/_crtbegin.o
     .data          0x00002f4c       0xd0 PGCCEFI.o
                    0x00003010                _veloadsize
                    0x00003014                _verpmsize
                    0x00003018                _baseaddr
     .data          0x0000301c        0x0 C:\PropGCC_EFI/SimpleLibraries/Utility/libsimpletools/lmm/\libsimpletools.a(pause.o)
     .data          0x0000301c        0x0 C:\PropGCC_EFI/SimpleLibraries/Utility/libsimpletools/lmm/\libsimpletools.a(setPauseDt.o)
     .data          0x0000301c        0x0 C:\PropGCC_EFI/SimpleLibraries/Utility/libsimpletools/lmm/\libsimpletools.a(eeprom_getInt.o)
     .data          0x0000301c        0x0 C:\PropGCC_EFI/SimpleLibraries/Utility/libsimpletools/lmm/\libsimpletools.a(i2c_in.o)
     .data          0x0000301c        0x0 C:\PropGCC_EFI/SimpleLibraries/Utility/libsimpletools/lmm/\libsimpletools.a(eeprom_init.o)
     .data          0x0000301c        0x0 C:\PropGCC_EFI/SimpleLibraries/Utility/libsimpletools/lmm/\libsimpletools.a(i2c_init.o)
     .data          0x0000301c        0x0 C:\PropGCC_EFI/SimpleLibraries/TextDevices/libsimpletext/lmm/\libsimpletext.a(print.o)
     .data          0x0000301c        0x0 C:\PropGCC_EFI/SimpleLibraries/TextDevices/libsimpletext/lmm/\libsimpletext.a(putStr.o)
     .data          0x0000301c        0x0 C:\PropGCC_EFI/SimpleLibraries/TextDevices/libsimpletext/lmm/\libsimpletext.a(putChar.o)
     .data          0x0000301c        0x0 C:\PropGCC_EFI/SimpleLibraries/TextDevices/libsimpletext/lmm/\libsimpletext.a(simpleterm.o)
     .data          0x0000301c       0x14 C:\PropGCC_EFI/SimpleLibraries/TextDevices/libsimpletext/lmm/\libsimpletext.a(dosprint.o)
     .data          0x00003030        0x0 C:\PropGCC_EFI/SimpleLibraries/TextDevices/libsimpletext/lmm/\libsimpletext.a(serial_rxtx.o)
     .data          0x00003030        0x8 C:\PropGCC_EFI/SimpleLibraries/TextDevices/libsimpletext/lmm/\libsimpletext.a(floatToString.o)
     .data          0x00003038        0x0 C:\PropGCC_EFI/SimpleLibraries/Protocol/libsimplei2c/lmm/\libsimplei2c.a(simplei2c.o)
     .data          0x00003038        0x0 C:\PropGCC_EFI/SimpleLibraries/Utility/libsimpletools/lmm/\libsimpletools.a(fpucog.o)
     .data          0x00003038        0x0 c:/program files (x86)/simpleide/propeller-gcc/bin/../lib/gcc/propeller-elf/4.6.1/short-doubles\libgcc.a(gesf2.o)
     .data          0x00003038        0x0 c:/program files (x86)/simpleide/propeller-gcc/bin/../lib/gcc/propeller-elf/4.6.1/short-doubles\libgcc.a(lesf2.o)
     .data          0x00003038        0x0 c:/program files (x86)/simpleide/propeller-gcc/bin/../lib/gcc/propeller-elf/4.6.1/short-doubles\libgcc.a(fixsfsi.o)
     .data          0x00003038        0x0 c:/program files (x86)/simpleide/propeller-gcc/bin/../lib/gcc/propeller-elf/4.6.1/short-doubles\libgcc.a(fixunssfsi.o)
     .data          0x00003038        0x0 c:/program files (x86)/simpleide/propeller-gcc/bin/../lib/gcc/propeller-elf/4.6.1/short-doubles\libgcc.a(floatunsisf.o)
     .data          0x00003038       0x84 c:/program files (x86)/simpleide/propeller-gcc/bin/../lib/gcc/propeller-elf/4.6.1/../../../../propeller-elf/lib/short-doubles\libc.a(ctype.o)
                    0x00003038                ___ctype
     .data          0x000030bc        0x4 c:/program files (x86)/simpleide/propeller-gcc/bin/../lib/gcc/propeller-elf/4.6.1/../../../../propeller-elf/lib/short-doubles\libc.a(thread.o)
                    0x000030bc                ___yield_ptr
     .data          0x000030c0        0x0 c:/program files (x86)/simpleide/propeller-gcc/bin/../lib/gcc/propeller-elf/4.6.1/../../../../propeller-elf/lib/short-doubles\libc.a(cogstart.o)
     .data          0x000030c0        0x0 c:/program files (x86)/simpleide/propeller-gcc/bin/../lib/gcc/propeller-elf/4.6.1/../../../../propeller-elf/lib/short-doubles\libc.a(memset.o)
     .data          0x000030c0        0x0 c:/program files (x86)/simpleide/propeller-gcc/bin/../lib/gcc/propeller-elf/4.6.1/short-doubles/_crtend.o
     *(.data*)
     *(.rodata)
     *(.rodata*)
     *(.gnu.linkonce.d*)
                    0x000030c0                PROVIDE (__C_LOCK, .)
                    0x000030c0        0x4 LONG 0x0
    .ctors          0x000030c4        0xc
     *(.ctors*)
     .ctors         0x000030c4        0x4 C:\PropGCC_EFI/SimpleLibraries/TextDevices/libsimpletext/lmm/\libsimpletext.a(simpleterm.o)
     .ctors         0x000030c8        0x4 C:\PropGCC_EFI/SimpleLibraries/Utility/libsimpletools/lmm/\libsimpletools.a(fpucog.o)
     .ctors         0x000030cc        0x4 c:/program files (x86)/simpleide/propeller-gcc/bin/../lib/gcc/propeller-elf/4.6.1/short-doubles/_crtend.o
                    0x000030cc                __argv
                    0x000030cc                __environ
    .dtors          0x000030d0        0x4
     *(.dtors*)
     .dtors         0x000030d0        0x4 c:/program files (x86)/simpleide/propeller-gcc/bin/../lib/gcc/propeller-elf/4.6.1/short-doubles/_crtend.o
    .data           0x000030d4        0x0
                    0x000030d4                . = ALIGN (0x4)
    .bss            0x000030d4      0xa0c
                    0x000030d4                PROVIDE (__bss_start, .)
     *(.bss)
     .bss           0x000030d4        0x0 c:/program files (x86)/simpleide/propeller-gcc/bin/../lib/gcc/propeller-elf/4.6.1/short-doubles/spinboot.o
     .bss           0x000030d4        0x0 c:/program files (x86)/simpleide/propeller-gcc/bin/../lib/gcc/propeller-elf/4.6.1/short-doubles/_crt0.o
     .bss           0x000030d4        0x0 c:/program files (x86)/simpleide/propeller-gcc/bin/../lib/gcc/propeller-elf/4.6.1/short-doubles/_crtbegin.o
     .bss           0x000030d4        0x0 PGCCEFI.o
     .bss           0x000030d4        0x4 C:\PropGCC_EFI/SimpleLibraries/Utility/libsimpletools/lmm/\libsimpletools.a(pause.o)
                    0x000030d4                _pauseTicks
     .bss           0x000030d8        0x0 C:\PropGCC_EFI/SimpleLibraries/Utility/libsimpletools/lmm/\libsimpletools.a(setPauseDt.o)
     .bss           0x000030d8        0x0 C:\PropGCC_EFI/SimpleLibraries/Utility/libsimpletools/lmm/\libsimpletools.a(eeprom_getInt.o)
     .bss           0x000030d8        0x0 C:\PropGCC_EFI/SimpleLibraries/Utility/libsimpletools/lmm/\libsimpletools.a(i2c_in.o)
     .bss           0x000030d8        0x0 C:\PropGCC_EFI/SimpleLibraries/Utility/libsimpletools/lmm/\libsimpletools.a(eeprom_init.o)
     .bss           0x000030d8       0xa4 C:\PropGCC_EFI/SimpleLibraries/Utility/libsimpletools/lmm/\libsimpletools.a(i2c_init.o)
                    0x000030d8                _buscnt
     .bss           0x0000317c        0x0 C:\PropGCC_EFI/SimpleLibraries/TextDevices/libsimpletext/lmm/\libsimpletext.a(print.o)
     .bss           0x0000317c        0x0 C:\PropGCC_EFI/SimpleLibraries/TextDevices/libsimpletext/lmm/\libsimpletext.a(putStr.o)
     .bss           0x0000317c        0x0 C:\PropGCC_EFI/SimpleLibraries/TextDevices/libsimpletext/lmm/\libsimpletext.a(putChar.o)
     .bss           0x0000317c        0x0 C:\PropGCC_EFI/SimpleLibraries/TextDevices/libsimpletext/lmm/\libsimpletext.a(simpleterm.o)
     .bss           0x0000317c       0x20 C:\PropGCC_EFI/SimpleLibraries/TextDevices/libsimpletext/lmm/\libsimpletext.a(dosprint.o)
     .bss           0x0000319c        0x0 C:\PropGCC_EFI/SimpleLibraries/TextDevices/libsimpletext/lmm/\libsimpletext.a(serial_rxtx.o)
     .bss           0x0000319c        0x0 C:\PropGCC_EFI/SimpleLibraries/TextDevices/libsimpletext/lmm/\libsimpletext.a(floatToString.o)
     .bss           0x0000319c        0x0 C:\PropGCC_EFI/SimpleLibraries/Protocol/libsimplei2c/lmm/\libsimplei2c.a(simplei2c.o)
     .bss           0x0000319c       0x18 C:\PropGCC_EFI/SimpleLibraries/Utility/libsimpletools/lmm/\libsimpletools.a(fpucog.o)
     .bss           0x000031b4        0x0 c:/program files (x86)/simpleide/propeller-gcc/bin/../lib/gcc/propeller-elf/4.6.1/short-doubles\libgcc.a(gesf2.o)
     .bss           0x000031b4        0x0 c:/program files (x86)/simpleide/propeller-gcc/bin/../lib/gcc/propeller-elf/4.6.1/short-doubles\libgcc.a(lesf2.o)
     .bss           0x000031b4        0x0 c:/program files (x86)/simpleide/propeller-gcc/bin/../lib/gcc/propeller-elf/4.6.1/short-doubles\libgcc.a(fixsfsi.o)
     .bss           0x000031b4        0x0 c:/program files (x86)/simpleide/propeller-gcc/bin/../lib/gcc/propeller-elf/4.6.1/short-doubles\libgcc.a(fixunssfsi.o)
     .bss           0x000031b4        0x0 c:/program files (x86)/simpleide/propeller-gcc/bin/../lib/gcc/propeller-elf/4.6.1/short-doubles\libgcc.a(floatunsisf.o)
     .bss           0x000031b4        0x0 c:/program files (x86)/simpleide/propeller-gcc/bin/../lib/gcc/propeller-elf/4.6.1/../../../../propeller-elf/lib/short-doubles\libc.a(ctype.o)
     .bss           0x000031b4       0xa8 c:/program files (x86)/simpleide/propeller-gcc/bin/../lib/gcc/propeller-elf/4.6.1/../../../../propeller-elf/lib/short-doubles\libc.a(thread.o)
                    0x000031b4                ___napuntil_ptr
     .bss           0x0000325c        0x0 c:/program files (x86)/simpleide/propeller-gcc/bin/../lib/gcc/propeller-elf/4.6.1/../../../../propeller-elf/lib/short-doubles\libc.a(cogstart.o)
     .bss           0x0000325c        0x0 c:/program files (x86)/simpleide/propeller-gcc/bin/../lib/gcc/propeller-elf/4.6.1/../../../../propeller-elf/lib/short-doubles\libc.a(memset.o)
     .bss           0x0000325c        0x0 c:/program files (x86)/simpleide/propeller-gcc/bin/../lib/gcc/propeller-elf/4.6.1/short-doubles/_crtend.o
     *(.bss*)
     *(COMMON)
     COMMON         0x0000325c      0x868 PGCCEFI.o
                    0x0000325c                _rpm
                    0x00003260                _verpm
                    0x000032b0                _hiload
                    0x000032b4                _veload
                    0x00003304                _cog2
                    0x00003308                _vetable
                    0x00003948                _yq1
                    0x0000394c                _xq1
                    0x00003950                _veresult
                    0x00003954                _hirpm
                    0x00003958                _stack
                    0x00003ac0                _load
     COMMON         0x00003ac4        0x8 C:\PropGCC_EFI/SimpleLibraries/Utility/libsimpletools/lmm/\libsimpletools.a(eeprom_getInt.o)
                    0x00003ac4                _eeInitFlag
                    0x00003ac8                _eeprom
     COMMON         0x00003acc       0x14 C:\PropGCC_EFI/SimpleLibraries/TextDevices/libsimpletext/lmm/\libsimpletext.a(simpleterm.o)
                    0x00003acc                _debug_serial
                    0x00003ae0                PROVIDE (__bss_end, .)
    .hub_heap       0x00003ae0        0x4
                    0x00003ae4                . = (. + 0x4)
     *fill*         0x00003ae0        0x4 00
                    0x00003ae0                ___hub_heap_start = ADDR (.hub_heap)
    .drivers
     *(.drivers)
                    0x00000020                __load_start_kernel = LOADADDR (.lmmkernel)
                    0x000030c4                ___CTOR_LIST__ = ADDR (.ctors)
                    0x000030d0                ___DTOR_LIST__ = ADDR (.dtors)
    .hash
     *(.hash)
    .dynsym
     *(.dynsym)
    .dynstr
     *(.dynstr)
    .gnu.version
     *(.gnu.version)
    .gnu.version_d
     *(.gnu.version_d)
    .gnu.version_r
     *(.gnu.version_r)
    .rel.init
     *(.rel.init)
    .rela.init
     *(.rela.init)
    .rel.text
     *(.rel.text)
     *(.rel.text.*)
     *(.rel.gnu.linkonce.t*)
    .rela.text
     *(.rela.text)
     *(.rela.text.*)
     *(.rela.gnu.linkonce.t*)
    .rel.fini
     *(.rel.fini)
    .rela.fini
     *(.rela.fini)
    .rel.rodata
     *(.rel.rodata)
     *(.rel.rodata.*)
     *(.rel.gnu.linkonce.r*)
    .rela.rodata
     *(.rela.rodata)
     *(.rela.rodata.*)
     *(.rela.gnu.linkonce.r*)
    .rel.data
     *(.rel.data)
     *(.rel.data.*)
     *(.rel.gnu.linkonce.d*)
    .rela.data
     *(.rela.data)
     *(.rela.data.*)
     *(.rela.gnu.linkonce.d*)
    .rel.ctors
     *(.rel.ctors)
    .rela.ctors
     *(.rela.ctors)
    .rel.dtors
     *(.rel.dtors)
    .rela.dtors
     *(.rela.dtors)
    .rel.got
     *(.rel.got)
    .rela.got
     *(.rela.got)
    .rel.bss
     *(.rel.bss)
    .rela.bss
     *(.rela.bss)
    .rel.plt
     *(.rel.plt)
    .rela.plt
     *(.rela.plt)
    .stab
     *(.stab)
    .stabstr
     *(.stabstr)
    .stab.excl
     *(.stab.excl)
    .stab.exclstr
     *(.stab.exclstr)
    .stab.index
     *(.stab.index)
    .stab.indexstr
     *(.stab.indexstr)
    .comment
     *(.comment)
    .debug
     *(.debug)
    .line
     *(.line)
    .debug_srcinfo
     *(.debug_srcinfo .zdebug_srcinfo)
    .debug_sfnames
     *(.debug_sfnames .zdebug_sfnames)
    .debug_aranges  0x00000000       0xa0
     *(.debug_aranges .zdebug_aranges)
     .debug_aranges
                    0x00000000       0x20 c:/program files (x86)/simpleide/propeller-gcc/bin/../lib/gcc/propeller-elf/4.6.1/short-doubles\libgcc.a(gesf2.o)
     .debug_aranges
                    0x00000020       0x20 c:/program files (x86)/simpleide/propeller-gcc/bin/../lib/gcc/propeller-elf/4.6.1/short-doubles\libgcc.a(lesf2.o)
     .debug_aranges
                    0x00000040       0x20 c:/program files (x86)/simpleide/propeller-gcc/bin/../lib/gcc/propeller-elf/4.6.1/short-doubles\libgcc.a(fixsfsi.o)
     .debug_aranges
                    0x00000060       0x20 c:/program files (x86)/simpleide/propeller-gcc/bin/../lib/gcc/propeller-elf/4.6.1/short-doubles\libgcc.a(fixunssfsi.o)
     .debug_aranges
                    0x00000080       0x20 c:/program files (x86)/simpleide/propeller-gcc/bin/../lib/gcc/propeller-elf/4.6.1/short-doubles\libgcc.a(floatunsisf.o)
    .debug_pubnames
     *(.debug_pubnames .zdebug_pubnames)
    .debug_info     0x00000000      0xdba
     *(.debug_info .gnu.linkonce.wi.* .zdebug_info)
     .debug_info    0x00000000      0x300 c:/program files (x86)/simpleide/propeller-gcc/bin/../lib/gcc/propeller-elf/4.6.1/short-doubles\libgcc.a(gesf2.o)
     .debug_info    0x00000300      0x300 c:/program files (x86)/simpleide/propeller-gcc/bin/../lib/gcc/propeller-elf/4.6.1/short-doubles\libgcc.a(lesf2.o)
     .debug_info    0x00000600      0x28b c:/program files (x86)/simpleide/propeller-gcc/bin/../lib/gcc/propeller-elf/4.6.1/short-doubles\libgcc.a(fixsfsi.o)
     .debug_info    0x0000088b      0x27f c:/program files (x86)/simpleide/propeller-gcc/bin/../lib/gcc/propeller-elf/4.6.1/short-doubles\libgcc.a(fixunssfsi.o)
     .debug_info    0x00000b0a      0x2b0 c:/program files (x86)/simpleide/propeller-gcc/bin/../lib/gcc/propeller-elf/4.6.1/short-doubles\libgcc.a(floatunsisf.o)
    .debug_abbrev   0x00000000      0x44e
     *(.debug_abbrev .zdebug_abbrev)
     .debug_abbrev  0x00000000       0xdc c:/program files (x86)/simpleide/propeller-gcc/bin/../lib/gcc/propeller-elf/4.6.1/short-doubles\libgcc.a(gesf2.o)
     .debug_abbrev  0x000000dc       0xdc c:/program files (x86)/simpleide/propeller-gcc/bin/../lib/gcc/propeller-elf/4.6.1/short-doubles\libgcc.a(lesf2.o)
     .debug_abbrev  0x000001b8       0xdc c:/program files (x86)/simpleide/propeller-gcc/bin/../lib/gcc/propeller-elf/4.6.1/short-doubles\libgcc.a(fixsfsi.o)
     .debug_abbrev  0x00000294       0xcd c:/program files (x86)/simpleide/propeller-gcc/bin/../lib/gcc/propeller-elf/4.6.1/short-doubles\libgcc.a(fixunssfsi.o)
     .debug_abbrev  0x00000361       0xed c:/program files (x86)/simpleide/propeller-gcc/bin/../lib/gcc/propeller-elf/4.6.1/short-doubles\libgcc.a(floatunsisf.o)
    .debug_line     0x00000000      0x3ea
     *(.debug_line .zdebug_line)
     .debug_line    0x00000000       0xe7 c:/program files (x86)/simpleide/propeller-gcc/bin/../lib/gcc/propeller-elf/4.6.1/short-doubles\libgcc.a(gesf2.o)
     .debug_line    0x000000e7       0xe7 c:/program files (x86)/simpleide/propeller-gcc/bin/../lib/gcc/propeller-elf/4.6.1/short-doubles\libgcc.a(lesf2.o)
     .debug_line    0x000001ce       0xa9 c:/program files (x86)/simpleide/propeller-gcc/bin/../lib/gcc/propeller-elf/4.6.1/short-doubles\libgcc.a(fixsfsi.o)
     .debug_line    0x00000277       0xad c:/program files (x86)/simpleide/propeller-gcc/bin/../lib/gcc/propeller-elf/4.6.1/short-doubles\libgcc.a(fixunssfsi.o)
     .debug_line    0x00000324       0xc6 c:/program files (x86)/simpleide/propeller-gcc/bin/../lib/gcc/propeller-elf/4.6.1/short-doubles\libgcc.a(floatunsisf.o)
    .debug_frame    0x00000000       0xc4
     *(.debug_frame .zdebug_frame)
     .debug_frame   0x00000000       0x2c c:/program files (x86)/simpleide/propeller-gcc/bin/../lib/gcc/propeller-elf/4.6.1/short-doubles\libgcc.a(gesf2.o)
     .debug_frame   0x0000002c       0x2c c:/program files (x86)/simpleide/propeller-gcc/bin/../lib/gcc/propeller-elf/4.6.1/short-doubles\libgcc.a(lesf2.o)
     .debug_frame   0x00000058       0x24 c:/program files (x86)/simpleide/propeller-gcc/bin/../lib/gcc/propeller-elf/4.6.1/short-doubles\libgcc.a(fixsfsi.o)
     .debug_frame   0x0000007c       0x24 c:/program files (x86)/simpleide/propeller-gcc/bin/../lib/gcc/propeller-elf/4.6.1/short-doubles\libgcc.a(fixunssfsi.o)
     .debug_frame   0x000000a0       0x24 c:/program files (x86)/simpleide/propeller-gcc/bin/../lib/gcc/propeller-elf/4.6.1/short-doubles\libgcc.a(floatunsisf.o)
    .debug_str
     *(.debug_str .zdebug_str)
    .debug_loc      0x00000000      0x46f
     *(.debug_loc .zdebug_loc)
     .debug_loc     0x00000000      0x101 c:/program files (x86)/simpleide/propeller-gcc/bin/../lib/gcc/propeller-elf/4.6.1/short-doubles\libgcc.a(gesf2.o)
     .debug_loc     0x00000101      0x101 c:/program files (x86)/simpleide/propeller-gcc/bin/../lib/gcc/propeller-elf/4.6.1/short-doubles\libgcc.a(lesf2.o)
     .debug_loc     0x00000202       0xa9 c:/program files (x86)/simpleide/propeller-gcc/bin/../lib/gcc/propeller-elf/4.6.1/short-doubles\libgcc.a(fixsfsi.o)
     .debug_loc     0x000002ab       0xbf c:/program files (x86)/simpleide/propeller-gcc/bin/../lib/gcc/propeller-elf/4.6.1/short-doubles\libgcc.a(fixunssfsi.o)
     .debug_loc     0x0000036a      0x105 c:/program files (x86)/simpleide/propeller-gcc/bin/../lib/gcc/propeller-elf/4.6.1/short-doubles\libgcc.a(floatunsisf.o)
    .debug_macinfo
     *(.debug_macinfo .zdebug_macinfo)
                    0x000007c0                PROVIDE (par, PAR)
                    0x000007c4                PROVIDE (cnt, CNT)
                    0x000007c8                PROVIDE (ina, INA)
                    0x000007cc                PROVIDE (inb, INB)
                    0x000007d0                PROVIDE (outa, OUTA)
                    0x000007d4                PROVIDE (outb, OUTB)
                    0x000007d8                PROVIDE (dira, DIRA)
                    0x000007dc                PROVIDE (dirb, DIRB)
                    0x000007e0                PROVIDE (ctra, CTRA)
                    0x000007e4                PROVIDE (ctrb, CTRB)
                    0x000007e8                PROVIDE (frqa, FRQA)
                    0x000007ec                PROVIDE (frqb, FRQB)
                    0x000007f0                PROVIDE (phsa, PHSA)
                    0x000007f4                PROVIDE (phsb, PHSB)
                    0x000007f8                PROVIDE (vcfg, VCFG)
                    0x000007fc                PROVIDE (vscl, VSCL)
                    0x00003af0                PROVIDE (__hub_end, (ADDR (.hub_heap) + 0x10))
                    0x00008000                PROVIDE (__stack_end, 0x8000)
    OUTPUT(lmm/PGCCEFI.elf elf32-propeller)
                    0x00002228                PROVIDE (__load_start_fpu_cog, LOADADDR (.fpu.cog))
                    0x00002944                PROVIDE (__load_stop_fpu_cog, (LOADADDR (.fpu.cog) + SIZEOF (.fpu.cog)))
    .debug_ranges   0x00000000      0x140
     .debug_ranges  0x00000000       0x68 c:/program files (x86)/simpleide/propeller-gcc/bin/../lib/gcc/propeller-elf/4.6.1/short-doubles\libgcc.a(gesf2.o)
     .debug_ranges  0x00000068       0x68 c:/program files (x86)/simpleide/propeller-gcc/bin/../lib/gcc/propeller-elf/4.6.1/short-doubles\libgcc.a(lesf2.o)
     .debug_ranges  0x000000d0       0x38 c:/program files (x86)/simpleide/propeller-gcc/bin/../lib/gcc/propeller-elf/4.6.1/short-doubles\libgcc.a(fixsfsi.o)
     .debug_ranges  0x00000108       0x38 c:/program files (x86)/simpleide/propeller-gcc/bin/../lib/gcc/propeller-elf/4.6.1/short-doubles\libgcc.a(fixunssfsi.o)
    edited 2014-04-07 13:38
    Thanks, SLRM. I do appreciate the insight. Oh well, back to coding that interp algorithm. I'll be looking at learning how to use standard libs and how to optimize memory use - it's ALL good!
    -Mike
    edited 2014-04-07 14:12
    Sorry about these name-space conflicts, I'm contacting Andy about scrubbing all source files today.
    edited 2014-04-07 14:35
    No worries, I'm glad the collective "we", despite our huge technical competency differences can ferret out these little oddities. Hijacking my own thread here - I've been trying to get "print" to spit out upper case hex - "%x" works, "%X" does not. Printf works fine, but bloats the code. Not complaining in any way, just wondering what I'm missing, if anything. also, simpletools is now at v0.98, something about the fpu_cog now not being autostarted. If I want to use FP properly do I have to manually start it or do the functions that need it have logic that starts it if necessary? My apologies for driving my own train off the track into a ravine :-) .
    -Mike
    pmrobert wrote: »
    -Mike
    Yes, %X does not work, only %x works. We are trying desperately to keep the libraries small ;-)
    You can use iprint() now to save around 2KB instead of the floating point enabled print() function.
    The format specifier documentation is in the code now, but hasn't made it to the html doc set yet. A new release is planned soon.
    Function printf (and friends) is for programming environments where we don't have to live in a straight-jacket.
    Floating point is still there. We just encountered a small issue with using fpu_cog.c (in the release branch), and had to remove it for now. If you like, you can manually add fpu_cog.c into your project and get the benefits of it.
