Would like to paste and enter a string into PST input window — Parallax Forums
Don MDon M Posts: 1,653
edited 2014-04-06 18:57 in Propeller 1
Currently I enter 12 characters one at a time as I type them in into memory using this code:
  repeat while bytesread < 12
    tmp := term.Rx
    if ((tmp == 10) OR (tmp ==13) OR (tmp == "*"))
      QUIT
    if ((tmp => ("0")) and (tmp =< ("9"))) OR ((tmp => ("A")) and (tmp =< ("F")))
      byte[@MachID][bytesread] := tmp
      i2c.WriteByte(i2c#BOOTPIN, EE_DEVICE_ADDR, (EE_BASE_ADDR + bytesread), tmp)
      term.tx(tmp)                                    ' For debugging message
      bytesread++
It works well for 1 character at a time but I would also like to be able to paste a string of 12 characters into the PST input window and press the Return key to have them entered in.
How do I modify my code in order to do this?
Any help or suggestions appreciated.
Thanks.
Don
    edited 2014-04-06 18:11
    No code changes required, problem is that PST seems to ignore paste'd content, i.e. while it's displayed in the input window it's not sent down the line.
  • Don MDon M Posts: 1,653
    edited 2014-04-06 18:44
    Ok so I tried using Putty instead. I can do it with Putty.
    Thanks for your comment.
    I had to add a 50msec pause after the write to eeprom command otherwise it would not store it. But works cool now with Putty.
