Propeller Assembly: Memory Addressing
I'm trying to make my code a bit more flexible by allowing a caller to specify multiple parameters. I'm, however, as of yet unable to properly address the locations as received through the assembly parameter register (PAR).
Any ideas where I'm going wrong?
CON ADDRESS_INCREMENT_UNIT = 4 VAR LONG _id LONG _resources[4] PUB Start(pins, samples, rate) _resources[0] := pins _resources[1] := samples _resources[2] := rate _id := COGNEW(@SETUP, @_resources) + 1 RETURN _id > 1 PUB State RETURN _resources[3] PUB Stop IF _id <= 0 RETURN COGSTOP(_id~ - 1) DAT ORG SETUP MOV resources, PAR ' Move array address into writable register RDLONG sample_mask, resources ' Read array index 0 ADD resources, #ADDRESS_INCREMENT_UNIT ' Increment to next array element RDLONG sample_count, resources ' Read array index 1 ADD resources, #ADDRESS_INCREMENT_UNIT ' Increment to next array element RDLONG sample_rate, resources ' Read array index 2 ADD resources, #ADDRESS_INCREMENT_UNIT ' Increment to next array element MOV current_state, resources ' Retain address for future results MOV OUTA, sample_mask ' Prepare for reading MOV wait_time, CNT ' ADD wait_time, wait_delay ' :NEXTSTATE MOV current_sample, sample_mask ' Prepare for button state reading MOV current_count, sample_count ' :NEXTSAMPLE OR DIRA, sample_mask ' Sample button state sample_count times ANDN DIRA, sample_mask ' WAITCNT wait_time, wait_delay ' ANDN current_sample, INA ' DJNZ current_count, #:NEXTSAMPLE ' WRLONG current_sample, current_state ' Write array index 3 with current button state JMP #:NEXTSTATE ' Do it again! current_count RES 1 current_sample RES 1 current_state RES 1 resources RES 1 sample_count RES 1 sample_mask RES 1 sample_rate RES 1 wait_delay RES 1 wait_time RES 1
But I am not able to follow the rest of it. Maybe to tired.
Enjoy!
IF _id <= 0
does not what you want
use
IF _id =< 0
same with >= ... never (until you want that) ... use =>
el.al.
are all changing the first operant
Enjoy
Thank you both for your help.
