Hot Propeller
I'm using the Parallax Propeller Quickstart board. I created a simple circuit to prototype a design and supplied an external 3.3v. Then had a Prop pin connected to capture the result. The Prop immediately quit responding. So I disconnected everything and reconnected just the Prop to the computer. I can run my program but I'm noticing the Prop chip getting too hot to touch. If I recall correctly this chip normally generates very little heat. Is that correct?
Lee
Lee
Welcome to the forums.
Were you trying to interface with a 5 volt device?
A simple schematic would be helpful to check the problem.
A picture of your setup would also be helpful.
Lee
Have you doubled checked the voltage of the 3.3v supply for the propeller on the Quickstart? You might have damaged the regulator. Another thing to watch out for is an external supply in your device feeding back to the propeller's supply. Linear regulators generally do nothing if there output voltage is above the set point.
Marty
Time to call Parallax Tech Support. 888-512-1024
