gas separation project
This project has been rolling around my head for awhile ,it came to me a day or so after my mom started using a oxygen concentrator. I went to the store to get a tank of argon welding gas and started envisioning a device that could produce argon so that I wouldn't have to run to the welding shop all the time.
I did a little research and found that argon is in the air we breath and can be separated out by fractional distillation or by using a molecular sieve (or at least oxygen can be separated that way).
Is argon ( or other gasses) generation / separation something that can be done in the home shop ?
Any thoughts or feedback would be greatly appreciated.
Brian
Brian
That is the route I'm headed, I bought the book "Illustrated Guide to Home Chemistry Experiments: All Lab, No Lecture" By Robert Bruce Thompson and have been working through the experiments to make sure I fully understand chemistry before I move forward. I figure it will take me all summer to get done with the book and then I can move forward next winter.
Thanks'
Brian
nitrogen leaving argon (I presume CO2 will split to yield oxygen).
Its not a cheap route to argon and needs high temperatures.
Also found this: http://www.restek.com/Technical-Resources/Technical-Library/Petroleum-Petrochemical/petro_A009
Here's one transcript: http://web.lemoyne.edu/~giunta/ea/RAYLEIGHann.html
Thanks' for the info , I'll check that stuff out.
Here is another thought that crossed my mind ,being that oxygen ,nitrogen and argon are different in molecular size (see pdf), would it be possible to build a air "gravel screening plant" on a silicon chip ? I've seen some amazing sensors out there that have micro passage ways on them.
Thanks'
Brian
Well running at a clock speed of 80 MPS ( 80,000,000 argon molecules per second) , 20 lbs of argon would take 90,000,000,000,000 years to separate (give or take a year)
Brian
LOL
Is this the way that lighting releases nitrogen in a thunderstorm ?
Thanks'
Brian
a list of chemicals readily avaliable, I may be able to come up with the Stociemetric equation to calculate the moles, in oz, grams, lbs, or tons.
Just need to add a pre-cooler to condense out water and CO2 then a distillation stage onto the end. Easy right? :-P
Safety should be used when using any system like this. whatever process you decide on, energy will be consumed and/or released in each stage. Structures inplace will have to withstand
elements corrosion, or unusual reactions. Internal seperation membranes will follow suit. If too much of an undesired product is produced, a purge in put inplace; assuming the
elements purges are enviromentally safe.
