Quick question regarding converting datatypes — Parallax Forums
BasilBasil Posts: 380
edited 2014-04-01 12:24 in Propeller 1
Hi All,
A nice easy one. I am just double checking as im sure I know the answer...
If I write a long to an index in an array of bytes, will the long be written across 4 bytes or truncated to 1 byte?
  • Mike GMike G Posts: 2,702
    edited 2014-04-01 04:30
    You could write a quick test to verify what happens.
  • BasilBasil Posts: 380
    edited 2014-04-01 11:32
    I would if I had a dev board...
    I am waiting on my pcb to be made so am developing without hardware for a little while :)
  • JonnyMacJonnyMac Posts: 9,789
    edited 2014-04-01 12:03
    You will only get the lower byte because the destination is a byte.
    If you want to write across an array of bytes use bytemove().
    JonnyMac wrote: »
    Thanks!
