wireless
what is the diff between the
433 MHz RF Transceiver
(#27982)
$39.99
and xbee. especially the higher cost of the 433 MHz RF Transceiver ? what are its advantages,
(#27982)
$39.99
Also, if its for a sellable project, the XBee has the appropriate government approvals already. As mentioned, the XBee can do some things without a micro.
Cheers,
I think this $4 board would work fine with lots of microcontrollers. If the uC is a 5V variety, you'll want to use a level sifter on the data lines.
I think the $35 board make it easier to configure the XBee with a PC. Nope, I just checked. It's just an expensive (but I'm sure high quality) way to use a XBee with a 5V microcontroller. There are lots of less expensive ways to connect a XBee to a 5V uC.
This is my cue to mention the inexpensive Nordic nRF24L01+ transceivers.
They cost a little more than a dollar (when you purchase several at once) provide two-way communication.
They're not as easy to use as the XBee and require more I/O pins (five or six). There's code available to use the nRF24L01+ transceivers for both the Propeller and the Basic Stamp.
I have more information about this transceivers in post #1 of my index (see signature).
The nRF24L01+ has to be powered with 3.3V but the I/O pins are 5V tolerate.
