Propeller and VGA don´t work
Hello, good morning:
I have a TFT with VGA connection, connect the propeller with the adapter and program my P8X32A, the screen starts, and after a few seconds turns off and stops working, the screen turns off and then not work until I turn off the P8X32A or reset, the question is that I connect the VGA computer monitor and it works perfectly with absolutely no interruption. The chip that runs the TFT is the RTD2660.
Someone has something happened?
Any idea?
Thank you.
That is the TFT:
http://www.ebay.com/itm/LCD-Controller-for-5-7-TFT-LCD-Module-with-2-AV-VGA-Board-800-x-480Dots-40Pin-/170751974412?pt=LH_DefaultDomain_0&hash=item27c19c5c0c
http://www.ebay.com/itm/5-5-0-inch-TFT-LCD-Display-Module-w-VGA-AV-Video-Driving-Board-Touch-Panel-/291020314714?pt=LH_DefaultDomain_0&hash=item43c229985a
Any idea?
Thank you.
That is the TFT:
Is it just using an unsupported scan rate for your display? Do any of the other VGA demos run with this display? Some use different resolutions at a given scan rate. I have seem some displays that don't support a specific resolution at a certain rate.
I have 3 VGA monitors from different sources and all behave differently. Could it be that the TFT device is just a problem device?
Some of brands of VGA are notorious for poor firmware.
What is more strange to me that the VGA computer work without any problem. I have no idea that it can happen, as I ke buy the developer to put him back to drivers RTD2660.
Have a look at ray's logic to see examples of interfacing to various LCD screens. hopefully that will give you some ideas.
http://www.rayslogic.com/Propeller/Products/PTP2/PTP2.htm
Not sure if this will fix the issue, but this is the thread PropGuy2 was reffering to:
http://forums.parallax.com/showthread.php/146944-Propeller-Project-Board-USB-VGA-issues/page2
Thank you.
