Inexpensive Ozone sensor ?
I'm looking for some low cost O3 handheld meter that can sense indoor environment and alarm when it's over certain level.
A quick search (see ozonesolutions.com) has confirmed that there's very little below $500 range.
Did anybody try a diy approach or knows where to start?
John
John
But they are all over EBay China for $20 and "long life" is listed as a feature... http://www.ebay.com/itm/MQ131-Semiconductor-Sensor-for-Ozone-Also-Sensitive-To-O3-CL2-NO2-/181239089579
The next step up in cost and performance are the electrochemical cells such as the ones from Citytech and Alphasense. Those do require a potentiostat circuit, which will increase your cost an/or your electronic acumen. There are integrated solutions such as the LMP91000 analog front end from TI. For something that is going to be a portable instrument, compare an electrochemical cell at µA to a metal oxide sensor at hundreds of mA. The jury is still out on how good they really are in field apps. Interferences and drift have to be accounted for, so the manufacturers offer a range of premium sensors, at higher cost.
I observed an erroneous operation of 2 detectors placed in what supposed to be a neutral environment inside a sealed building.
Then suddenly it came to me that it might be just because of high concentration of seemingly non-existent vapours from freshly painted walls or fuming brand new Oriented strand board (OSB) material from which the building was made just few months ago. From http://www.hc-sc.gc.ca/ewh-semt/air/in/poll/construction/organi-eng.php
"Volatile organic compounds are chemicals that easily become gases at room temperatures, and therefore are released into indoor air in homes from a variety of products."
And that is exactly what those O3-sensors are sensitive to.
