Arlo motors with encoder — Parallax Forums
indyindy Posts: 13
edited 2014-03-20 18:55 in General Discussion
Will motors operate without encoder circuits connected? Don't need the encoder function at this time and this is my first go with robotics and encoder motors. Just need motors to operate in forward and reverse in a very simple circuit configuration whereas applying voltage via relays (not using motor controllers). Thanks for your help. Have a great day.
    edited 2014-03-20 09:26
    Sure, they are brushed DC motors which could be switched via relays. Encoders are a completely seperate circuit.
  • Mark_TMark_T Posts: 1,981
    edited 2014-03-20 16:48
    The only time you have to worry is with an engineering brushless motor which can
    be supplied with an absolute encoder and no hall-sensors. Typically they have hall-sensors
    though, since encoders are often incremental (and thus not useful for commutation).
  • indyindy Posts: 13
    Thanks for the prompt reply.
