jm_ds1307_demo.spin as alarm clock — Parallax Forums
stargazer2050stargazer2050 Posts: 89
edited 2014-03-21 06:58 in Propeller 1
Quickstart board
Jm_ds1307.spin
Ds1307 running on 28 and 29
Fullduplexserial
Tried to capture the hex into a variable
Minute := term.hex(clock[1], 2)
Tried variable as word and as long.
How to do it?????
  • stargazer2050stargazer2050 Posts: 89
    edited 2014-03-20 10:03
    Jm_Ds1307 uses fullduplexserial
    Could i break that into two units and:
    [code]
    PRI hexToInteger(h) : v
    if h => "0" and h =< "9" v := h - "0"
    elseif h => "A" and h=< "F" v := h - "A" + 10
    elseif h => "a" and h =< "f" v := h = "a" + 10
    PRI twoHextoInteger (h2,h1) : v
    v := hexToInteger(h2) << 4 | hexToInteger(h1)
    [\code]
  • ChrisGaddChrisGadd Posts: 311
    edited 2014-03-20 13:14
    The DS1307 outputs time in binary-coded-decimal (BCD) format, so 12:34:56 is output as $56 seconds, $34 minutes, $12 hours.
    Without seeing the code, I'm guessing all of the parameters are read into an array of clock bytes. So...
      seconds     := clock[0]
      minutes     := clock[1]
      hours       := clock[2]
      day_of_week := clock[3]
      date        := clock[4]
      month       := clock[5]
      year        := clock[6]
    If you want to convert that to a hexadecimal value, where $34 minutes = decimal 34 ($22)
    minutes := (clock[1] >> 4 * 10) + (clock[1] & $0F)
    edited 2014-03-20 13:48
    Would like to convert to regular decimal so i can capture it in a variable,
    Then i can use the variables to figure out the alarm setting.
    edited 2014-03-20 14:44
    I may be asking for ascii
    If the clock speaks 4 digit bcd
    Then is displayed on 7 digit lcd with hex
    And i only speak regular numbers im in a heap of trouble.
    Thats why im askii..ing
    edited 2014-03-21 03:57
    To Chris, thats it, got it!
    Thankyou!
  • JonnyMacJonnyMac Posts: 9,835
    edited 2014-03-21 05:02
    Maybe you have an old version of my DS1307 object -- the one on my computer has conversion routines to go from BCD to decimal and vice-versa.
    pub bcd2dec(bcd)
      return ((bcd >> 4) * 10) + (bcd & $0F)
    pub dec2bcd(dec)
      return ((dec / 10) << 4) | (dec // 10)
    Tip: If you're using the Propeller Tool, but the object you're using in Summary view so you can more easily see the public methods in the object.
    No, it doesn't. JM_DS1307 is an object for an RTC that uses an I2C interface. Your application may use serial, the object itself does not.
    edited 2014-03-21 06:53
    Hi jm
    I chose yer prog because 1. It works 2. It expresses.using fullduplexserial instead of tv or lcd so i could stay consistant.
    Ive downloaded your new one and will upgrade to it!
    I'm glad it works for you. That said, let's be accurate so we don't confuse newcomers. The file jm_ds1307 is an object that uses I2C to connect to the DS1307 RTC. The file jm_ds1307_demo.spin uses the jm_ds1307 object and outputs data to a terminal program. Some may think me pedantic on this, but I see a lot of inaccurate statements in the forums vis-a-vis object (library) code versus demo/application code.
