Control the Boe-Bot with Raspberry Pi
Hello,
My question is, can I connect my Boe-Bot with the Raspberry Pi?
I want to program the Boe-Bot with the raspberry pi instead of the standard Pc
is it possible?
thanks in advance
is it possible?
thanks in advance
Electrically I believe the RaspberryPi is a 3.3 volt device, so you would need to use a level shifter to protect it from the Stamp's 5 v output. Here's an article on it: http://www.instructables.com/id/Pi-Cubed-How-to-connect-a-33V-Raspberry-Pi-to-a-5V/
What I would probably do is use one of the RaspberryPi's GPIO pins to send control signals to the Boe-bot. There are several serial slave clients written in PBasic which allow another computer to control it via a serial link. Bluetooth is often used to remotely control the Boe-bot. See: http://forums.parallax.com/showthread.php/112822-How-to-%E2%80%93-Boe-Bot-Robot-with-Easy-Bluetooth-Module . But the RaspPi can send the signals the Bluetooth controller would send and the Boe-bot wouldn't know any difference. There's also the MS Robotics Studio client PBasic client that would work as well.
Method 1:
Grab a copy of the Feb.2014 Servo magazine, read the "SPRITE" article - in it, I show a very simple, inexpensive method for interfacing to 5V digital I/O and servos.
Method 2: (far more powerful)
http://www.mikronauts.com/raspberry-pi/robopi/
RoboPi adds a 100Mhz 8 core Propeller for doing the hard real time I/O with
- 24 digital I/O (5V safe, 3 pin servo style connector for each, each of which can be INPUT/OUTPUT/SERVO/PWM)
- 8 analog inputs (0-5V, 12 bits, 3 pin servo style connector for reach channel)
- easy C API for the Raspberry Pi to control RoboProp (similar to Wiring/Arduino)
If you go to the web page above, you can look at the documentation and API for RoboPi.
In both cases:
you can directly mount
http://www.mikronauts.com/proto/ezaspieproto300/
on a Boe-Bot (I've done this for some of my experiments)
and then you can just build the SPRITE circuit on it, or mount a Pi + RoboPi on it.
I'll take some photos of my Pi on one of my Boe-Bots later today and post it here.
Check out Parallax's page on SimpleIDE for Raspberry Pi: http://learn.parallax.com/propeller-c-set-simpleide/raspberrypi
dgately
Yes, you could connect it, however the Stamp software does not run on the Pi.
You would have to devise a serial protocol, that would send commands to the Boe-Bot from the Pi.
The file is called BoeBotControlForMsrsCtp2.bs2 and a Google search for it returns this link:
https://www.google.com/url?sa=t&source=web&rct=j&ei=3r54U7T8JJOkqAa55YKQAQ&url=http://forums.parallax.com/attachment.php%3Fattachmentid%3D61366%26d%3D1244261652&cd=1&ved=0CCoQFjAA&usg=AFQjCNH1DGiBZVMGfw5mrBLSSBUQIvnViA&sig2=WBQTC1X2Z8yh05KKBeEo4w
