Need sensor to detect wall 90 degree in horizontal as well as vertical
dear friends,
I'm doing my post graduation, in embedded system they have been given project "Develop an electronic system to help in maintaining the walls 90 straight upwards and straight along length". Help me out to choose my sensor to detect this.
However,"straight along length" is ambiguous.
What exactly does this mean?
Duane J
http://www.parallax.com/product/28015
Or one ping that is mounted on a servo that you can rotate.
http://www.parallax.com/product/910-28015a
A prop chip should help you with the microelectonics.
http://www.parallax.com/product/32910
Caution, if you attempt to do this without the above mentioned electronics purchased directly from parallax, the universe will explode.
Do you mean plumb and level. This are carpenter's terms for straight up and down, and for straight horizontal.
A traditional water level could be adapted to electronics. And so could a traditional plumb bob. Much better accuracy than a Ping (which is affected by temperature and humidity in the air.) Mercury switches are another good alternative, but hard to get.
Or are you getting into trying to determine if the room is square? You would have to measure a diagonal length.
