question about using a crystal with a propeller — Parallax Forums
dhoyosdhoyos Posts: 2
edited 2014-03-20 10:18 in Propeller 1
Hi all,
This is my first post, I'm just starting to learn how to use the propeller, and analyzing some circuit diagrams on the internet and datasheets, I saw something I've never seen before in other microcontrollers.
Normally, both crystal pins are connected to each of the two leads of the crystal and also to a 22pF (or a similar value) which are connected to GND. However, I've seen a lot of circuits using the P8x32A that have the XI and XO pins just connected to an external crystal and nothing else. What's going on there?
Also, to be able to use the Propeller at full speed, which is the correct crystal value to use? Is it 5Mhz? Thanks!
    edited 2014-03-19 12:24
    dhoyos wrote: »
    Hi all,
    Welcome to the forums!
    The 5Mhz crystal:
    http://www.parallax.com/product/251-05000
    is already rate for 20pf. Drop in. This is rated for 80 Mhz operation.
    You could also use a 6.25 Mhz Xtal:
    http://www.parallax.com/product/251-06250
    to acheive 100 Mhz operation.
    Please ask more questions if need.
  • LeonLeon Posts: 7,620
    edited 2014-03-19 12:51
    The crystal feedback capacitors are internal on the Propeller.
  • dhoyosdhoyos Posts: 2
    edited 2014-03-19 13:37
    Cool! thanks!
    Parallax made crystals easy with the internal capacitors. Also by being able to multiple a 5Mhz to 16x.
    In many cases, people that were using external capacitors were getting the values wrong and their crystal would not clock. The microcontroller would never start.
    But it would be wisest to buy your crystals from Parallax as other source might have crystals that run with different capacitor requirements. This was the source of all the problems. A machine that tests the exact capacitance required is expensive (thousands of dollars) and people were buying crystals without knowing the right capacitance required.
    As I recall, the faster the crystal, the more you have to be careful. So a 5mhz crystal might worked even though it is not quite the right capacitance, but an 50mhz crystal might not work without precisely the right values.
