Regulator, SUmobot — Parallax Forums
Regulator, SUmobot
deetwistdeetwist Posts: 3
edited 2014-03-19 04:08 in Robotics
Hi ya'll just wondering does the parallax board has a built in regulator in it or do we still have to put in a regulator?, also what is the voltage limit of the board?
    edited 2014-03-18 21:00
    Depends on the board. Some have linear regulators, and those have voltage limits around 9V (+ or - a few volts depending on current draw). Boards with switching regulators can handle input voltages in the 5 to 16V range. The DIP modules need a regulated 3.3V or 5V input depending on which module.
    The last page of the SumoBot manual:
    http://www.parallax.com/sites/default/files/downloads/27400-SumoBot-Manual-v2.1.pdf
    shows a LM2936. This is a 5 volt regulator to provide VDD (5 volts) to the board. Anywhere on the board that you can access VDD, that will be a regulated 5 volts.
    The input on the board shows 6 Volts. Since this is the voltage used by the Servos, (VIN), you shouldn't go any higher, or else you will burn out the servos.
