Upside down Arlo?
I'm building a robot based on the Arlo platform. When I measured the threshold between my den and hallway, it is almost exactly the wheel clearance under the Arlo base which will make transitioning almost impossible. As I sat studying my Arlo, it occurred to me that the clearance between the top of the base and the top of the wheel was greater than the clearance below.
My question is this: Is there any engineering or design reason why I couldn't use the Arlo base upside down?
dogulas
dogulas
http://www.mcmaster.com/#standard-ball-transfers-for-conveyors/=r4uc4f
They look like the #4 version at the link above and I use the ones with a 1/4" thread. Just drill a hole in the front and rear of the base and use s 1/4" T nut for mounting. You can use either the steel ball or to be safe use the nylon version which is easier on floors.
The battery is then sitting on top of the base instead of hanging down.
The main issue you may run into is that this is meant for level surfaces and can only go over small obstacles. If you have a higher door threshold to go over that can be an issue for any robot. Not only clearance under the base but enough clearance so that when the front or rear castor hits that it doesn't lift a drive wheel off the floor.
Robert
Gordon, Thanks for the reply. Actually, there I a plate that goes across the bottom of the wheel kits that the batteries rest on but the documentation says is also necessary for structural strength. The motors also hang down to about the same level. There are two thresholds in question and they are wooden and about a inch and a quarter tall. I don't know the exact amount as I am not home right now. I measured them, though, and they are almost exactly the same distance as the edge of a wheel and the bottom of the battery tray.
Doug
Robert,
Yes, I have given a lot of thought about that and will be modifying the platform by putting both castors in the back. The batteries will be shifted back to move the center of gravity back and I plan to remove much material from the front half of the disk by drilling 1" holes partially through the disk from the bottom in a honeycomb fashion. This will allow the shape to still be a circle and will allow me to mount sensors along the front arc.
Having the wheels in this configuration will allow me to mount much more uneven terrain.
Doug
If that's the case that's fairly excessive for a robot of this design. Even if you manage to account for the clearance that height may snag a caster, or cause the robot to go severely off course when it lands on the other side. That sort of defeats the purpose of a finely tuned robot. You may want to think about creating a ramp both sides of the threshold to accommodate the robot. This is not uncommon, even in lab settings.
