Help with propeller load
Almost working!
On the PropTool F10 sends to ram, and F11 sends to eeprom.
For large C programs (bigger than hub) there are several options and I'm using external ram as the equivalent of F10, and loading programs from SD card to external ram as the equivalent of F11.
Loading to ram with the -r option in propeller-load works fine.
However loading from eeprom doesn't quite seem to work. It is writing a file 'autorun.pex' on the SD card and this is the correct size. However it does not seem to reading this on startup.
The config file is
and the batch file is
and the output is (ignore the two cast warnings from spin2cpp)
rebooting the propeller runs from "Loading SD driver" onwards. So the problem appears to be loading ram from the SD card.
Is the syntax above correct?
And if so, would there be a way to find out if it is hanging, what it is doing on that last line etc?
Any help would be most appreciated
The config file is
# 23LC1024.cfg clkfreq: 80000000 clkmode: XTAL1+PLL16X baudrate: 115200 rxpin: 31 txpin: 30 cache-driver: spi_sram24_cache.dat cache-size: 8K cache-param1: 0x090B0A01 # 0xooiiccpp - oo=mosi ii=miso cc=sck pp=cs-protocol cache-param2: 0x08000000 # 0xssxxxxxx - ss=cs sd-driver: sd_driver.dat sdspi-do: 15 sdspi-clk: 14 sdspi-di: 13 sdspi-cs: 12 load-target: ram
spin2cpp --elf -o kyedos.elf -Os -mxmmc KyeDOS3.spin propeller-load.exe -I C:/propgcc/propeller-load/ -b 23LC1024 -p COM6 kyedos.elf -l -e -r -t pause
C:\Propeller\spin2cpp>spin2cpp --elf -o kyedos.elf -Os -mxmmc KyeDOS3.spin ASCII0_STREngine.cpp: In member function 'int32_t ASCII0_STREngine::Tokenizestring(int32_t)': ASCII0_STREngine.cpp:144:22: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast] ASCII0_STREngine.cpp:145:59: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast] C:\Propeller\spin2cpp>propeller-load.exe -I C:/propgcc/propeller-load/ -b 23LC1024 -p COM6 kyedos.elf -l -e -r -t Propeller Version 1 on COM6 Loading the serial helper to hub memory 9528 bytes sent Verifying RAM ... OK Loading 'kyedos.pex' to SD card 60024 bytes sent Loading sd_loader.elf to EEPROM via hub memory 16372 bytes sent Verifying RAM ... OK Programming EEPROM ... OK Verifying EEPROM ... OK [ Entering terminal mode. Type ESC or Control-C to exit. ] Loading SD driver Loading cache driver Initializing SD card Mounting filesystem Opening 'autorun.pex' Starting kernel Loading RAM at 0x30000000
Load from PC to ram seems to work. It is the load from SD to ram that seems to not be working. Cheers, Drac,
