Strain Gauge Ampliferying problems
i am working on strain gauge training kit which will help the incoming students after me to apply the concepts of one of the force sensors
but since i live in the 3rd world none of the instrumentation amplifiers are available such as INA122...etc
the only Op/Amps available are :
LM358
LM386
LM324
uA741
TO072
and i know most of them are poor
i used LM358 as first amplification which made a gain approx 100 then i used anther one but it ends up with complete unstable system
and i am thinking of building instrumentation amplifier from one of the above Op/Amps
but i have no idea about how? that's my problem or if anyone could have another solution
thanks you and sorry for my bad English
LM358
LM386
LM324
uA741
TO072
and with another different thing which is i used +6 and 0 as power to the amps instead of +12 -12
the output was constant to approx 4.42V
thanks you for reply
Take a look at the attached LM358 data sheet. Try the "High Impedance Differential Amplifier" circuit on page 5.
http://www.scribd.com/doc/14256112/AN002OpAmp-LM358-as-Instrumentation-Amplifier
The LM324 is a Quad version of the LM358. Both use less current than the TL072.
The 741 can only pull its output to within about 2V of its positive and negative supply voltages.
