TFT Screen
Hi, I am coming from an Arduino area, and moving into using the Propeller because I'm starting to have limits with the Arduino.
I want to have a display that is around 7inches something like this: http://www.ebay.com/itm/7-TFT-LCD-Module-Display-800X480-Touch-Panel-Screen-/190367645601?pt=LH_DefaultDomain_0&hash=item2c52cbbfa1
But I have some questions:
1. Is the Propeller fast enougth to draw GUI displays or would you see the Processor draw the contents on the screen?
2. How would you interface with something like a TFT screen? I have never done that before.
Thank you for everyones help,
Cameron.
Cameron.
Personally, I've been using 7" displays like the one you linked to, with an external VGA controller board; and then generating VGA from the prop.
There is still not enough memory for a bitmapped GUI, but you can do a lot with tiled drivers.
For any resolution you want to drive with a bitmap, you need (horizontal_pixels)*(vertical_pixels)*(bits_per_pixel)/8 bytes of memory. 800x480x24 bit color is 1,152,000 bytes (far more than using every available hub memory byte (32768 bytes))
Directly interfacing with such a TFT display requires more than 27 I/O's if you want 24 bit pixels. You are far better off using VGA, or an SSD1963 or similar external controller.
Have a gander at rayslogic.com http://www.rayslogic.com, a fabulous
site with lots of easy to access info.
http://www.rayslogic.com/Propeller/Products/VgaGraphics/VgaGraphics.htm
This link takes you to a true 24bit graphics display option.
Rich
Thank you for your response. I'm really looking at using the display directly and getting the data from a SSD card, but controlled by the micro-controller.
Do you have any code to control a display like this using an SSD or point me in another direction.
Thank you again for your help.
Cameron.
What do you mean by an SSD card?
rjo_ sent you some good links, I have one of Ray's cards, they work well.
