How would I go about connecting an electric motor to the Boe-Bot?
Hi everyone, I just purchased an electric motor rated at 6V DC. If I wanted to connect the motor to the battery pack powering the Boe-Bot (4 1.5V alkaline batteries), would I connect the motor's positive terminal to vin and the negative terminal to vss? I'm not completely sure and I don't want to fry the electronics.
Im talking about the vin and vss in the X1 section of the circuit.
I would recommend 0.1uF caps between the two motor leads and between each motor lead and the motor's metal housing. 'Best to solder them on right at the motor itself. This will help to reduce noise on the power leads.
And, BTW, welcome to the Parallax forum!
