Hydra Board and Simple IDE — Parallax Forums
seanyseany Posts: 1
edited 2014-03-11 10:47 in General Discussion
Hello,
I just started with Hydra, and I was using the SimpleIDE . However, the hello world code
  Welcome.c
  Welcome to SimpleIDE, the C programming environment that makes it easy to
  get started with the multi-core Propeller microcontroller!
  To run this program:
#include "simpletools.h"
int main()
  print("Hello world");
is producing Chinese characters like 迟¦ when ran in terminal.
I am using a baud rate of 57600
(all other baud rates till 9600 and 115200 above it also produced other similar chinese characters)
Did I do something perticularly wrong?
    edited 2014-03-11 06:08
    Works fine on my Hydra with SimpleIDE Ver 0.9.45
    Baudrate 115200
    716 x 619 - 190K
    edited 2014-03-11 10:01
    Did changing to Baud 115200 on the terminal fix the problem?
  • jazzedjazzed Posts: 11,803
    @Publison selected the Hydra board type (thanks!).
    That's pretty important. It is documented in the SimpleIDE User Guide.
