Preemptive Multithreading Example — Parallax Forums
cgraceycgracey Posts: 14,303
edited 2014-03-17 15:06 in Propeller 2
Here is a switcher I wrote to test the T3LOAD/T3SAVE instructions, which load and save all of task3's state data, plus DCACHE status and INDA/INDB. This switcher also saves and restores task3's LIFO stack and the WIDE registers, for a pretty thorough program context. It also remaps 16 blocks of 16 registers, so that each of the 16 threaded programs has its own register pool from $000..$00F.
At 80MHz, a complete thread switch takes about 750ns. This switcher changes contexts every 10us to run the 16 programs in a round-robin pattern.
' Preemptive Multithreading Demo
' - runs 16 threaded programs
' - use F11 to download
DAT		orgh	$380			'pad to $E00
		org				'cog assembler mode
' 16 blocks of 16 regsiters addressable from $000..$00F by each threaded program
		long	0[16*16]		'(nops, initially)
' Thread switcher
		setwide	$1E8			'locate wide registers from $1E8..$1EF
		getcnt	time			'get initial time
:loop		setmap	thread_cnt,#%00_100_100	'remap registers for next program thread
		locptra	#context0		'get address of next 3-wide context
		mov	x,thread_cnt
		mul	x,#3<<5
		addptra	x
		rdwideq	ptra[0]			'load task3 state data
		t3load
		rdwideq	ptra[1]			'load task3 lifo stack without affecting dcache status
		tpush	$1EB,#3
		tpush	$1EA,#3
		tpush	$1E9,#3
		tpush	$1E8,#3
		rdwideq	ptra[2]			'load wides without affecting dcache status
		settask	thread_on		'give task3 15/16 slots
		add	time,time_delta		'wait for switch time
		passcnt	time
		settask	thread_off		'give task0 16/16 slots, task3 will empty from pipeline before next task0 executes
		wrwide	ptra[2]			'task3 dormant now, save wides
		tpop	$1E8,#3			'save task3 lifo stack
		tpop	$1E9,#3
		tpop	$1EA,#3
		tpop	$1EB,#3
		wrwide	ptra[1]
		t3save				'save task3 state data
		wrwide	ptra[0]
		incmod	thread_cnt,#15		'next program thread
		jmp	#:loop
' Thread switcher variables
time		long	0
time_delta	long	80_000_000/100_000	'context switches occur at 100KHz, threads run for ~9.25us, switches take ~0.75us
thread_cnt	long	0
thread_on	long	%%3333333333333330	'task3 gets 15 of 16 slots
thread_off	long	%%0000000000000000	'task0 gets 16 of 16 slots, task3 is starved of slots
x		long	0
' Program thread contexts - 3 wides per context
		orgh				'hub assembler mode
		orgw				'align to next wide
		'	t3load/t3save			lifo		wide
context0	long	@program0>>2,0,0,0,0,0,0,0,	0[8],		0[8]
context1	long	@program1>>2,0,0,0,0,0,0,0,	0[8],		0[8]
context2	long	@program2>>2,0,0,0,0,0,0,0,	0[8],		0[8]
context3	long	@program3>>2,0,0,0,0,0,0,0,	0[8],		0[8]
context4	long	@program4>>2,0,0,0,0,0,0,0,	0[8],		0[8]
context5	long	@program5>>2,0,0,0,0,0,0,0,	0[8],		0[8]
context6	long	@program6>>2,0,0,0,0,0,0,0,	0[8],		0[8]
context7	long	@program7>>2,0,0,0,0,0,0,0,	0[8],		0[8]
context8	long	@program8>>2,0,0,0,0,0,0,0,	0[8],		0[8]
context9	long	@program9>>2,0,0,0,0,0,0,0,	0[8],		0[8]
contextA	long	@programA>>2,0,0,0,0,0,0,0,	0[8],		0[8]
contextB	long	@programB>>2,0,0,0,0,0,0,0,	0[8],		0[8]
contextC	long	@programC>>2,0,0,0,0,0,0,0,	0[8],		0[8]
contextD	long	@programD>>2,0,0,0,0,0,0,0,	0[8],		0[8]
contextE	long	@programE>>2,0,0,0,0,0,0,0,	0[8],		0[8]
contextF	long	@programF>>2,0,0,0,0,0,0,0,	0[8],		0[8]
' Each of the following programs has virtual uninterrupted use of:
'	registers 0..15
'	the wide registers at $1E8, including dcache function
'	inda/indb
'	all task3 resources
' Use of big math circuits should be encapsulated within tlock/tfree instructions.
program0	notp	#0
		jmp	@program0
program1	notp	#1
		jmp	@program1
program2	notp	#2
		jmp	@program2
program3	notp	#3
		jmp	@program3
program4	notp	#4
		jmp	@program4
program5	notp	#5
		jmp	@program5
program6	notp	#6
		jmp	@program6
program7	notp	#7
		jmp	@program7
program8	notp	#8
		jmp	@program8
program9	notp	#9
		jmp	@program9
programA	notp	#10
		jmp	@programA
programB	notp	#11
		jmp	@programB
programC	notp	#12
		jmp	@programC
programD	notp	#13
		jmp	@programD
programE	notp	#14
		jmp	@programE
programF	notp	#15
		jmp	@programF
«13
  • ozpropdevozpropdev Posts: 2,793
    edited 2014-03-11 05:01
    Looks great! :)
    edited 2014-03-11 05:18
    Chip,
    That looks great - nice and simple, easy to read.
  • cgraceycgracey Posts: 14,303
    edited 2014-03-11 05:25
    Chip,
    I'm changing the RDWIDEQ instruction so that it waits for three more clocks, allowing us to get rid of the WAITs. I'll just change that in the code listing now... done. I also got rid of the '#0,' write mask in the WRWIDE instructions, since I'll have the assembler be smart about that.
    edited 2014-03-11 05:33
    Even better - that removes the need for wait #2's
    edited 2014-03-11 05:41
    Here is a version of Chip's switcher, modified for cooperative multi-threading:
    ' Cooperative Multithreading Demo (slight modification of preemptive demo), untested
    CON
                    YIELD = 1
    ' Thread switcher
    		mov	x,thread_cnt
    		mul	x,#3<<5
    		addptra	x
    		t3load
    		tpush	$1EB,#3
    		tpush	$1EA,#3
    		tpush	$1E9,#3
    		tpush	$1E8,#3
                    mov         t3request, #0           ' release YIELD, moved after Chip's correct comment
                    JZ            t3request,@$          ' wait for request
    		tpop	$1E9,#3
    		tpop	$1EA,#3
    		tpop	$1EB,#3
    		wrwide	ptra[1]
    		wrwide	ptra[0]
    		jmp	#:loop
    t3request long 0
    thread_cnt	long	0
    x		long	0
    '	registers 0..15
    '	inda/indb
    program0	notp	#0
                    tcheck  t3request,#YIELD
    		jmp	@program0
    program1	notp	#1
    		jmp	@program1
    program2	notp	#2
    		jmp	@program2
    program3	notp	#3
    		jmp	@program3
    program4	notp	#4
    		jmp	@program4
    program5	notp	#5
    		jmp	@program5
    program6	notp	#6
    		jmp	@program6
    program7	notp	#7
    		jmp	@program7
    program8	notp	#8
    		jmp	@program8
    program9	notp	#9
    		jmp	@program9
    programA	notp	#10
    		jmp	@programA
    programB	notp	#11
    		jmp	@programB
    programC	notp	#12
    		jmp	@programC
    programD	notp	#13
    		jmp	@programD
    programE	notp	#14
    		jmp	@programE
    programF	notp	#15
    		jmp	@programF
    edited 2014-03-11 05:47
    Chip,
    Looks really impressive!
    edited 2014-03-11 05:55
    Bill, I think you forgot to put the 'JZ t3request,@$' instruction before the 'MOV t3request,#0'.
    edited 2014-03-11 06:05
    OOPS!
    Thanks, you are right of course.
    That should teach me about trying to modify code before coffee...
    cgracey wrote: »
    edited 2014-03-11 06:11
    OOPS!
    I made your changes and it runs as expected.
    edited 2014-03-11 06:16
    Thanks!
    Now the people who prefer cooperative threading can easily do so.
    I am really looking forward to all the neat features we can implement with TCHECK.
  • roglohrogloh Posts: 6,366
    edited 2014-03-11 06:22
    cgracey wrote: »
    Great effort Chip. All proceeding very nicely right now. It will pay dividends down the track. :thumb:
    edited 2014-03-11 06:36
    We're going to be like kids in a candy store!
    C.W.
    edited 2014-03-11 06:39
    OOPS!
    Actually, it needs to be a little different than what either of us thought. You'd want to clear the 'request' register BEFORE starting the thread by giving it time slots. Then, you'd wait for it to go non-zero. When it's non-zero, then you switch threads. The THALT will be cleared next time around.
    edited 2014-03-11 06:48
    You are absolutely right!
    I fixed the example, and I am currently drinking a BIG cup of strong coffee...
    cgracey wrote: »
    edited 2014-03-11 07:17
    ctwardell wrote: »
    C.W.
    Couldn't agree more!
    There is certainly going to be a lot to try with the coming release ;)
  • RaymanRayman Posts: 16,363
    edited 2014-03-11 11:54
    Can one combine this multithreading with hubexec mode?
    I mean, can these 16 threads be running code from the hub?
    edited 2014-03-11 12:00
    Yes :)
    Rayman wrote: »
    edited 2014-03-11 12:08
    Thanks Bill. Also, is the choice of 16 for # threads in this example is arbitrary, right?
    Is there any limit on # of threads this way? I think the other way has a limit of 4 threads...
    BTW: Why did Chip pick task#3 for this?
    edited 2014-03-11 12:12
    You are welcome.
    The number of threads is arbitrary... thousands of tiny threads are possible.
    Only a single task supports saving its whole state, and I am guessing that Chip chose the last one so that 1&2 could theoretically run cog drivers.
    Personally, I expect I will always run the scheduler/debugger in #0, not use 1&2, and use #3 for threads - by not using #1&#2, #3 will get much more benefit from the single dcache line and the four icache lines.
    But in case we run out of tasks, it is nice to have the capability to run drivers in 1&2 (sharing the scheduler/thread cog)
    Rayman wrote: »
  • pjvpjv Posts: 1,903
    edited 2014-03-11 12:14
    Hi Bill;
    Say, I'm curious how fast that will run (exclusive of each task's own code) if you had 4 cooperative tasks running at once.
    Cheers,
    Peter (pjv)
    edited 2014-03-11 12:36
    There would be a fixed overhead of 1/16 cycles for the scheduler task, after that Chip's thread save/restore takes 750ns @ 80Mhz, which translates to 300ns @ 200Mhz
    It would depend on how often a context switch occurred.
    Note that faster context saves are possible if you don't save the LIFO or the WIDE for the thread (in case you don't need to)
    Time to schedule = (200*1/16) overhead + num_context_switches * .3us
    So if you had 1000 context switches in a second, 300us for context switches, plus 65,500us for the scheduler idling... total of 6.58% overhead
    46.71MIPS/thread assuming each thread used 100% of its cycles
    If two of the threads only used 10% of their cycles, the other two would run a at about 80MIPS each.
    Four hardware tasks would run at 50MIPS/task
    To me, the more interesting case is being able to run tons of slower threads (so many threads can wait on sockets & USB endpoints)
    pjv wrote: »
    Hi Bill;
    Cheers,
    Peter (pjv)
    edited 2014-03-11 12:40
    FYI,
    If someone wanted, they could run cooperative threads only in task#3
    If they did that, by having a "YIELD" subroutine in the cog memory for task#3 they would not need the scheduler thread, and would only take the hit of thread state saving/restoring, avoiding the 1/16 cycle cost of the scheduler.
    Such theads would not however be able to pre-emptive.
    What I like about Chip's implementation is that a developer can use cooperative or pre-emptive threading - whichever is more appropriate to the problem the developer is solving.
    edited 2014-03-11 13:02
    Yes, I like that too.
    Wow! Now, that whole discussion was painful, but the result is nice and clean. Well done all around.
    And, the niceness of the PASM syntax for data really shines here, just saying.
    Hi Bill;
    Perhaps I should as the question with a specific simple example:
    How fast could 4 independent cooperative threads run where each thread is a simple XOR outa,BitN toggling a different port bit. With and without the optional saves you mentioned.
    Cheers,
    Peter (pjv)
    edited 2014-03-11 13:38
    With Chip's full state save, at 200Mhz, cooperative
    .3us per fask switch, ~30ns per task... .33us total... approx. 3M task swaps per sec
    With minimal state save (only PC etc wide, no LIFO, no WIDE save) approximately 50 cycles for task swap, 6 for task
    approx. 16M+ task swaps per sec
    So hooking up an LED to each thread...
    with full state save: ~.38Mhz square wave per LED
    with minimal state save: ~2Mhz square wave per LED
    with four hardware tasks using REPD with a count set at 2^32 - 1
    ~6.25Mhz square wave per LED
    Cheating version:
    Putting the four XOR's into a REPD block set to 2^32 - 1 repeats:
    ~25Mhz square wave per LED
    save/restore time dominates the non-cheating versions.
    edited 2014-03-11 13:58
    Bill Thanks;
    But a little thick in the head here..... does your statement "square wave per LED" mean that all 4 LED pins are toggling with ~ 2.6 uSec high, then 2.6 uSec low for the full save case, and ~ 0.5 uSec high with 0.5 uSec low for the minimal case ?
    I want to be sure to not mis-interpret your statements as that can be easily done in these cases.
    Cheers,
    Peter (pjv)
    edited 2014-03-11 14:02
    Yep, each LED toggling independently.
    FYI, the above numbers were quick off the top of my head approximations (except the cheating case); once we have the new FPGA image it will be possible to try out all sorts of schemes (albeit at 80Mhz)
    pjv wrote: »
    Bill Thanks;
    Cheers,
    Peter (pjv)
    edited 2014-03-11 16:39
    Having this Preemptive Multithreading opens the door to running an OS like Android, right?
    edited 2014-03-11 16:48
    Not without some XLMM type kernel - 256KB is not nearly enough for Android.
    For P3, I am sure there will be some kind of execute from DDR2/3/?, but it is waaaaaay too much to try to squeeze into P2.
    An LMM-like kernel for the SDRAM on the P2 module is possible, trading a performance hit for much larger programs and a simple OS (uCLinux?)
    Rayman wrote: »
    edited 2014-03-11 18:12
    I wonder if you could swap memory in and out from SDRAM to HUB for each of these threads...
    Maybe that would take too long, but if you could, you could then execute from a vast pool of memory...
