QuickStart REV A power questions/concerns (revisited)
I just got a couple of QuickStart boards REV A (from Radio Shack clearance).
Since I recalled seeing posts regarding powering QuickStart boards externally (rather than from the USB port), I have been searching the forums and found several relevant discussions. But I still have some questions/concerns:
QuickStart Rev A
QuickStart Rev A
- Can external power (3.3V) be supplied to pin 38 (VDD) or 4V-9V to pin 40 (VIN) while the board is connected via the USB port without damaging anything?
- According to the User Guide v1.0, the USB_PWR_EN pin is
Pulled to USB 5 V supply.Internally driven low after successful USB power negotiation. Can be externally driven low to force the USB power input to drive the QuickStart power supply, such as when powering from a USB charger.Does not support USB charging specification, so it can only be powered from a computers USB port, not a USB charger
- If I wanted to provide power thru the USB port with a power-only cable, I would need to pull the USB_PWR_EN pin 30 low (as in this post), correct?
With either revision of the Propeller QuickStart board, the 3.3-volt supply on pin 38 is directly connected to the output of a linear regulator. If you connect an external 3.3-volt supply to the same pin, it won't damage the regulator or the Propeller QuickStart board, but it you will also need to be sure that you can connect 3.3 VDC to the output of the external supply without damaging it. Rev A boards do not work with USB charges, because they require successful USB power negotiation. Only a USB host can negotiate power and a USB charger does not function as a USB host. You can drive the /USB_PWR_EN pin low to force USB power on.
— David Carrier
Parallax Inc.
David,
Thanks for your prompt reply. Just wanted to be safe rather than sorry!
