Time equation questions — Parallax Forums
Don MDon M Posts: 1,654
edited 2014-03-02 15:28 in Propeller 1
From an earlier thread I have applied some knowledge from Mike, Phil & Jonny Mac.
I am playing around with time equations. I recieve time of day from a RTC object in a string buffer. I was looking at a way of converting that string buffer back into a number and then being able to do some calculations with it like subtracting one time from another to figure the difference and be able to display it.
Here's my playground of code:
CON
        _clkmode = xtal1 + pll16x                                               'Standard clock mode * crystal frequency = 80 MHz
        _xinfreq = 5_000_000
        MS_001   = 80_000_000 / 1_000
VAR
  long  time, seconds, TimeBuffer1, TimeBuffer2
  byte  TimeString1[10], TimeString2[10]
OBJ
  term : "fullduplexserial"
PUB main | hours, minutes, secs, seconds1, seconds2, totalsecs1, totalsecs2, diffseconds
  term.start(31, 30, %0000, 115_200)
  pause(1000)
  seconds := 122
  time := time + seconds
  minutes := time / 60
  secs := time // 60
  term.dec(time)
  term.str(string(" Seconds = "))
  term.dec(minutes)
  term.str(string(" Minutes and "))
  term.dec(secs)
  term.str(string(" Seconds",13, 13))
  TimeString1[0] := "1"                                 ' Assign ASCII string numbers to buffer
  TimeString1[1] := "2"
  TimeString1[2] := ":"
  TimeString1[3] := "0"
  TimeString1[4] := "5"
  TimeString1[5] := ":"
  TimeString1[6] := "3"
  TimeString1[7] := "0"
  TimeString1[8] := 0
  TimeString2[0] := "1"
  TimeString2[1] := "1"
  TimeString2[2] := ":"
  TimeString2[3] := "0"
  TimeString2[4] := "8"
  TimeString2[5] := ":"
  TimeString2[6] := "5"
  TimeString2[7] := "5"
  TimeString2[8] := 0
  term.str(@TimeString1)                                ' Display ASCII strings
  term.tx(32)
  term.str(@TimeString2)
  term.tx(13)
  TimeBuffer1 := (StrToDec(@TimeString1))               ' Convert ASCII number strings to decimal number
  TimeBuffer2 := (StrToDec(@TimeString2))
  term.dec(StrToDec(@TimeString1))                      ' Display decimal number
  term.tx(32)
  term.dec(StrToDec(@TimeString2))
  term.tx(13)
  term.dec(TimeBuffer1 // 10)                           ' Play wih Modulus function to see what it does
  term.tx(" ")
  term.dec(TimeBuffer1 // 100)
  term.tx(" ")
  term.dec(TimeBuffer1 // 1000)
  term.tx(" ")
  term.dec(TimeBuffer1 // 10000)
  term.tx(" ")
  term.dec(TimeBuffer1 // 100000)
  term.tx(" ")
  term.dec(TimeBuffer1 // 1000000)
  term.tx(" ")
  term.dec(TimeBuffer1 // 10000000)
  term.tx(13)
  term.dec(TimeBuffer1 / 10000)                         ' Divide number by 10,000 to get hours
  term.tx(13)
  seconds1 := (TimeBuffer1 // 100)                                              ' Seconds
  seconds1 := seconds1 + ((((TimeBuffer1 // 10000) - seconds1) / 100) * 60)     ' Minutes converted to seconds
  seconds1 := seconds1 + ((TimeBuffer1 / 10000) * 3600)                         ' Hours converted to seconds
  seconds2 := (TimeBuffer2 // 100)                                              ' Seconds
  seconds2 := seconds2 + ((((TimeBuffer2 // 10000) - seconds2) / 100) * 60)     ' Minutes converted to seconds
  seconds2 := seconds2 + ((TimeBuffer2 / 10000) * 3600)                         ' Hours converted to seconds
  term.dec(seconds1)
  term.tx(32)
  term.dec(seconds2)
  term.tx(13)
  diffseconds := seconds1 - seconds2                    ' Figure time difference in seconds
  term.dec(diffseconds)
  term.tx(13)
  hours := diffseconds / 3600                           ' Convert seconds difference into Hours, Minutes and Seconds
  minutes := diffseconds / 60
  secs := diffseconds // 60
  term.dec(hours)
  term.str(string(" Hours, "))
  term.dec(minutes)
  term.dec(secs)
PUB StrToDec(stringptr) : value | char, index, multiply
    '' Converts a zero terminated string representation of a decimal number to a value
    value := index := 0
    repeat until ((char := byte[stringptr][index++]) == 0)
       if char => "0" and char =< "9"
          value := value * 10 + (char - "0")
    if byte[stringptr] == "-"
       value := - value
pub pause(ms) | t
  t := cnt
  repeat ms
    waitcnt(t += MS_001)
I take 2 different time buffers that were stored as ASCII strings, convert them to decimal number, break them apart (parse?) to get the hour, minutes and seconds. Then convert the hours and minutes to seconds. Then add all the seconds together. I do this for both strings and then find the difference in seconds then go and convert the difference in seconds back into hours, minutes and seconds.
Seems like I took the long way around to get to the answer.
My question- is there a simpler / easier way to take 2 ASCII time strings and find the difference in hours, minute & seconds?
Thanks.
Don
  • JonnyMacJonnyMac Posts: 9,835
    edited 2014-03-02 14:48
    Probably not. With longs you can easily convert a formated time string to seconds; those this for both strings and the math becomes trivial. I've already shown you how convert raw seconds to a formatted time string.
    pub tstr_to_seconds(p_tstr) | s
    '' Converts formatted time string to seconds
    '' -- format is "HH:MM:SS"
      s := (byte[p_tstr][0] - "0") * 36000                          ' 10s hrs
      s += (byte[p_tstr][1] - "0") *  3600                          '  1s hrs
      s += (byte[p_tstr][3] - "0") *   600                          ' 10s mins
      s += (byte[p_tstr][4] - "0") *    60                          '  1s mins
      s += (byte[p_tstr][6] - "0") *    10                          ' 10s secs
      s += (byte[p_tstr][7] - "0")                                  '  1s secs
      return s
    Here's another method for converting seconds to a string -- it doesn't add a terminator so you can insert the formatted time anywhere you'd like.
    pub seconds_to_tstr(s, p_tstr)
    '' Converts seconds to formatted time string
      byte[p_tstr][0] := s / 36000 + "0"
      s //= 36000
      byte[p_tstr][1] := s / 3600 + "0"
      s //= 3600
      byte[p_tstr][2] := ":"
      byte[p_tstr][3] := s / 600 + "0"
      s //= 600
      byte[p_tstr][4] := s / 60 + "0"
      s //= 60
      byte[p_tstr][5] := ":"
      byte[p_tstr][6] := s  / 10 + "0"
      byte[p_tstr][7] := s // 10 + "0"
  • Don MDon M Posts: 1,654
    Thanks Jon. That simplifies things somewhat.
    Thanks again.
    Don
