While Loop Problems
Hey all! Working on a project to control a stepper motor on a power drawbar for a milling machine. The program should run the motor in one direction if the UnclampSwitch is triggered until the UnclampedSwitch is triggered, with the same being true for the ClampSwitch and ClampedSwitch. In addition, lights should turn on if either the UnclampedSwitch or ClampedSwitch are triggered (UnclampedLight and ClampedLight, respectively). Here's the code I have so far:
I'm suspecting that its some small syntax problem somewhere, but I've got no clue what it might be. Anyone got any ideas?
CON _clkmode = xtal1 + pll16x 'Standard clock mode * crystal frequency = 80 MHz _xinfreq = 5_000_000 UnclampSwitch=0 UnclampedSwitch=1 UnclampedLight=18 ClampSwitch=2 ClampedSwitch=3 ClampedLight=19 PulseFrequency=1000 {In Hz} PulseWidth=50 {In uSeconds} StepPin=16 {Step pin of driver} DirPin=17 {Direction pin of driver} VAR long Period long PauseTime PUB Monitor dira[UnclampSwitch]~ dira[UnclampedSwitch]~ dira[UnclampedLight]~~ dira[ClampSwitch]~ dira[ClampedSwitch]~ dira[ClampedLight]~~ dira[StepPin]~~ dira[DirPin]~~ Period:=clkfreq/PulseFrequency PauseTime:=Period-PulseWidth Repeat If ina[ClampSwitch]~~ & ina[ClampedSwitch]~ Clamp Elseif ina[UnclampSwitch]~~ & ina[UnclampedSwitch]~ Unclamp If ina[ClampedSwitch]~~ outa[ClampedLight]~~ Elseif ina[UnclampedSwitch]~~ outa[UnclampedLight]~~ waitcnt(clkfreq/1000) PUB Clamp outa[DirPin]~ Repeat While (ina[ClampedSwitch]~) outa[StepPin]~~ waitcnt(PulseWidth+cnt) outa[StepPin]~ waitcnt(PauseTime+cnt) RETURN PUB Unclamp outa[DirPin]~~ Repeat While (ina[UnclampedSwitch]~) outa[StepPin]~~ waitcnt(PulseWidth+cnt) outa[StepPin]~ waitcnt(PauseTime+cnt) RETURN
I believe you need to relate what the problem is. That part seems to be missing.
Your code below:
looks like it's attempting to set the ina values. I don't recall ever seeing comparisons done this way and my guess is they wouldn't work as expected.
I'd suggest changing this and other comparisons to something like this.
